4.0 sucks too much fuel, replaced a bunch of junk, no difference. - JeepForum.com
post #1 of 43 Old 08-02-2012, 10:10 AM Thread Starter
DoctorTim
Rebuilt motor
New tps
New O2 sensor
New exhaust manifold
New fuel filter
Stock 355 gears
Fuel pump makes noise (constant high pitch)
31 tires (makes lots of noise)
Getting 11.5 mpg. A 10% adjustment for the gearing makes 12.6
Friend gets 14 with same setup.
Will get an 8.8 with 410 gears. Will thathelp?
New injectors?
New fuel pump?
New tires?
97+ intake?
What should i try?
Thanks
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #2 of 43 Old 08-02-2012, 10:42 AM
1CleanTJ
1CleanTJ's Avatar
how are you calculating fuel useage ?
what are you running for tire pressure ?
a/t or m/t tread ?
your xj full of stuff ?
and lastly, dont expect much mileage out of a lifted jeep
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #3 of 43 Old 08-02-2012, 10:54 AM
jeepkid03
Winning
jeepkid03's Avatar
Depends a lot on your gas also. 10% ethanol around here kills my mpg.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #4 of 43 Old 08-02-2012, 11:30 AM Thread Starter
DoctorTim
a/t or m/t tread ?
I fill the tank till the nozzle clicks twice. Set the odo to 0. The do mileage/ gallons the tank takes at next fillup. Then add 10% to itself. M/t tires, really chunky. I got diff covers, roof rack w/spare on top, thats about it. Not much junk
I use reg 87 fuel from costco
post #5 of 43 Old 08-02-2012, 11:31 AM Thread Starter
DoctorTim
Tire pres is at 35
post #6 of 43 Old 08-02-2012, 11:38 AM
chriskeenan
driving habits
chriskeenan is offline
post #7 of 43 Old 08-02-2012, 01:06 PM
Millermagic
Alignment. I went from about 10 to 15 by performing an alignment.
I also ruined a set of tires.
Obviously it's a poor way to perform measurement - but I would go from my place to my parents on half tank of gas ... now it takes a bit more than a quarter.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #8 of 43 Old 08-02-2012, 02:05 PM
bobthecatkiller
Iv heard the spare on top hurts gas mileage
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #9 of 43 Old 08-02-2012, 04:30 PM Thread Starter
DoctorTim
i havent done a proper alignment in a while and my steering linkage is pretty old. i guess it should be time to do that after i replace it.
also i threw the spare in the back just yesterday so it may be a while before i can get a good average mpg without it on top.
post #10 of 43 Old 08-02-2012, 07:38 PM
1CleanTJ
1CleanTJ's Avatar
i dont see you getting much more then 14-15 with mudders on.
removing the spare tire from the top should help
last time spark plugs were changed or gap checked ?
to be honest if your worried about milage, pick up a commuter car. I got a 93 honda civic for my daily driving. I drove my tj on 36's for years as a daily driver though, must of averaged about 12mpg on the highway my honda gets 37mpg on highway
1CleanTJ is offline
post #11 of 43 Old 08-02-2012, 07:45 PM Thread Starter
DoctorTim
yeah replaced sparkers when i did the rebuild.
im going to get 33" A/Ts after i get the 8.8 underneath the jeep. the spare will one day find its way on a swing out carrier.
post #12 of 43 Old 08-10-2012, 06:33 AM
xj_noob
Try the good old seafoam treatment. And get a more free flowing exhaust. That's what i do, I just have the magnaflow catback exhaust and I seafoam every now and then and i get at least 18 mpg city and 22-23 highway.
xj_noob is offline
post #13 of 43 Old 08-10-2012, 01:48 PM
Azzy
Seafoam doesnt do squat. Other than waste money, overheat your cat, and annoy the neighborhood.
If your injectors are dirty, swap them with newer ones. Might help.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #14 of 43 Old 08-10-2012, 09:32 PM
xj_noob
It sure does help me out. :/ I just put it in my gas tank to clean my injectors and I get 320~ miles to the tank.
xj_noob is offline
post #15 of 43 Old 08-10-2012, 10:04 PM Thread Starter
DoctorTim
stock height and stock tires?
4.0 , mpg
Junk Yard Fuel Injectors DieselDreamer XJ Cherokee Technical Forum 2 05-15-2011 10:21 AM
who has replaced their fuel pump? ktmracer419 XJ Cherokee Technical Forum 33 10-18-2007 09:10 PM
!!!bunch of questions with bunch of pics!!! wojtizzlator XJ Cherokee Technical Forum 23 05-30-2007 04:37 PM
Help! Replaced fuel pump and still no go!!! Bornwinnr XJ Cherokee Technical Forum 8 06-06-2006 05:54 PM
Replaced fuel pump t bell XJ Cherokee Technical Forum 4 01-30-2006 08:05 PM
