Quantcast 4.0 still overheats after new parts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 4.0 still overheats after new parts
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 09-19-2009, 03:58 PM   #1
sterfry2004
1997 XJ Cherokee
My 97 Cherokee Sport overheats after idling between 2 and 3 RPM for several minutes. It gets to 210 at a normal rate, then eases up to the next line and maintains that temp for a while. Even at that temp, the engine will start to steam/smoke and wreak of coolant. Coolant is not leaking anywhere.
Things I've done:
1) Radiator was new as of August '08.
2) Water pump just replaced.
3) Thermostat (190 degree) just replaced.
Other (related?) problems:
1) Bad Compression on cylinders 2 and 4. I didn't test this, but was told by my mechanic. He said the culprit was warped piston rings due to the overheating.
Coolant seems to be flowing properly through the upper and lower radiator hoses. Oil still looks good on the dipstick. All of the hoses seem to be in good condition; no leaks or anything.
What's my next step? Will fixing the compression issues fix the overheating issues also, or are they most likely separate?
1997 Jeep Cherokee XJ Sport 4.0L
sterfry2004 is offline   Reply With Quote
Old 09-19-2009, 04:25 PM   #2
RCHavok797
Why is it idling between 2 and 3 thousand rpms?
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline   Reply With Quote
Old 09-19-2009, 04:57 PM   #3
sterfry2004
1997 XJ Cherokee
I should have specified. I keep it revved that high because it will stall if allowed to idle at its normal idle speed.
Old 09-19-2009, 05:16 PM   #4
Cdn96XJ
Junior Member
Bad head gasket could be a possibility. Coolant is getting into your cylinder walls and burning up. You said coolant is not leaking anywhere however do you need to top it up every once in a while?
Black 1996 XJ 4.0L SE, 4x4, AX-15. Street modded mall crawler.
Cdn96XJ is offline   Reply With Quote
Old 09-19-2009, 06:14 PM   #5
sterfry2004
1997 XJ Cherokee
Well, the jeep has been out of commission since January '09 due to the overheating issue. I'm just now getting the time and funds to start working on it. Prior to the initial overheating in January, though, I don't recall having to add coolant to it, and it didn't have any overheating issues.
Old 09-19-2009, 06:29 PM   #6
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
Overheating at idle or at low speeds in traffic is a sign of low airflow. I would replace the fanclutch and make sure the electric fan is working correctly.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 09-19-2009, 06:33 PM   #7
duntov
Pressure check your radiator...mine had a small leak in the radiator and it wreaked antifreeze but I couldn't see it leaking out anywhere. I replaced the radiator and cap and it worked like a champ.
1998 Jeep Cherokee Classic, Chili Pepper Red, 4.0, 4WD, 3" OME Full Leaf, JKS QD, JL Sub, Sony CD w/Ipod adapter, Polk Audio Speakers. C4X4 Tow hooks, Reese hitch, Yakima Rack, Mopar spare tire rack.
2004 Jeep Grand Cherokee, Lighter Pewter Metallic, 4.7 V8, 4WD, Factory Tow hooks, Factory Skids and other goodies.
duntov is offline   Reply With Quote
Old 09-19-2009, 09:22 PM   #8
sterfry2004
1997 XJ Cherokee
Both fans are operational. Does that mean they're fine, or could they both spin and be faulty?
Is a pressure check something I could do myself, or does the jeep need to be taken somewhere like Autozone? What tools would I need?
Thanks for all your input!
Old 09-19-2009, 09:32 PM   #9
sterfry2004
1997 XJ Cherokee
Old 09-19-2009, 09:43 PM   #10
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
The fan will still spin if the clutch is bad, it just doesn't spin fast enough to cool the coolant in the radiator. Have you been able to drive the jeep? And if so does it overheat at road speeds?
Old 09-19-2009, 09:47 PM   #11
DannyRoark89
DannyRoark89's Avatar
1995 XJ Cherokee
pull your thermostat and see if that helps, you can get bad ones that are new, you can check it by puttin it in boiling water and seeing if it opens, also check your overflow hose, if its clogged there is no place for the steam to escape to, it happened to me and caused a giant mess and an expensive one for a 3 dollar hose
DannyRoark89 is offline   Reply With Quote
Old 09-19-2009, 11:51 PM   #12
sterfry2004
1997 XJ Cherokee
Right now I have the rear diff taken apart, but I feel like it would overheat. Before I replaced the therm and pump, it let me drive normal speeds for about 15 miles before overheating. Doesn't seem like the pump was the real issue.
The thermostat is definitely opening, and the overflow hose was replaced two days ago due to a split.
Old 09-20-2009, 12:52 AM   #13
newxj
1990 XJ Cherokee
Originally Posted by sterfry2004 View Post
...and the overflow hose was replaced two days ago due to a split.
And you still feel it will overheat? I suggest putting the rear diff. back together and road test it.
newxj is offline   Reply With Quote
Old 09-20-2009, 06:52 AM   #14
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
I would pressure test the system to check for leaks/head gasket.
Old 09-20-2009, 07:10 AM   #15
wills88xj
1988 XJ Cherokee
i dont remember what years it was but some of the 4.0's had a problem with air getting traped in the head after complete draining .the way to fix this is to get the front of the jeep at as much of a angle (the closer to 45 deg the better ) then top off coolant and let it run for a while . it will burp its self .
the way to tell if your fan clutch is working is .when its cold it should have very little resistance ( spin pretty easy) with the engine off!!!!
after it warms up turn the engine off ,it should be harder to spin
it is thermostaticly controled
wills88xj is offline   Reply With Quote
Glock Forum
