4.0 running to rich. - JeepForum.com
post #1 of 5 Old 07-27-2004, 06:43 PM Thread Starter
ptipton
I have changed the map, cts, iat and o2 sensors and it is still running very rich, any more suggestions would be helpful.
ptipton is offline
post #2 of 5 Old 07-28-2004, 06:38 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I am assuming you have a 96+ XJ. Take it in to AutoZone or hook up a scanner and see if any codes com eup. Also clear any that are on there after documenting them and see if they return.
Double check the connection on the MAP, and what brand O2 did you use. There have been several guys here that have bought the bosch and have had to return them. Most get Dealer stock replacements and have had better luck with them.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 5 Old 07-28-2004, 09:20 PM
mans
mans's Avatar
What's a CTS and IAT?
-- mans --
The journey of a thousand miles begins with a broken fan belt and a leaky tire ;)
Belief ... halfway into Being ...
'87 Cherokee XJ Limited I-6 4.0 166,000 miles
Simota Racing Air Filter / Homebrew Air Tube / CAT-less Exhaust System
Pioneer P7650 & 1000 watt AMP/Blaupunkt Velocity/Rockford Punch 1000 watt Ultimate Sound Setup :)
mans is offline
post #4 of 5 Old 07-28-2004, 09:27 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I assumed he meant cPs and iaC.
Of course you know what happens when you assume!!!!!!!!!!!!!!
93 Sport
Specs in Profile.
balloo93 is offline
post #5 of 5 Old 07-28-2004, 09:28 PM
98XJVT
IAT = intake air temp, cts = coolant temp sens
98 XJ 4.0L I6
62mm tbody, 62mm spacer, custom intake
Dynomax Catback, Carsound Cat
98XJVT is offline
Running Rich Meltedmechanic XJ Cherokee Technical Forum 21 05-10-2008 11:01 AM
running rich freedomhunter XJ Cherokee Technical Forum 3 12-30-2007 10:36 PM
xj running rich christerxj XJ Cherokee Technical Forum 2 01-31-2007 03:02 PM
Running really rich Scooter98xj XJ Cherokee Technical Forum 20 05-18-2006 11:25 PM
87' 4.0 running rich? mgriff1969 XJ Cherokee Technical Forum 0 06-13-2005 09:12 PM
