4.0 overheating problem - JeepForum.com
post #1 of 19 Old 04-19-2009, 07:50 PM Thread Starter
89jpcherokee
ok i got a mystery on my hands my cherokee will overheat... replaced the thermostat with housing and the water pump (which WAS bad) still is getting too hot at about 180 the warning light kicks on but dosnt seem like its gettin that hot yet also my electric fan doenst kick on... seems fine sitting there at idle but as soon as i drive it anywhere it starts to overheat
89jpcherokee is offline
post #2 of 19 Old 04-19-2009, 08:08 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The electric fan shouldn't kick on until around 212*. The normal operating temp is 210*. How hot is it getting? And it getting hotter while driving leads to a low flow problem. You most likely have some blockage in the radiator.
xjfever is offline
post #3 of 19 Old 04-19-2009, 08:12 PM Thread Starter
89jpcherokee
we flushed the system twice seems like its fine another thing is that how this all started was it blew the lower radiator hose then the next morning it blew the upper
post #4 of 19 Old 04-19-2009, 08:13 PM
jeepkid03
Winning
jeepkid03's Avatar
your warning light kicks on at 180 degrees??? Cherokees are designed to run at 210. You may have more than one problem. Mine overheated once and it turned out to be a bunch of things at once that made the cooling system weak. Once the temp goes past 210 degrees you should hear the electric fan kick on. If it doesnt and the temp keeps rising than you have to check the wiring for the electric fan and see that its working properly. You said that you replaced the water pump... what about the fan clutch? They only last about 5 years. Some other issues could be the thermostat or the radiator. Mine was all blocked up once and the radiator looked pretty nasty as well as the coolant. What year is your jeep? Your user name has "89" in it so if your jeep is an '89 then it has the "closed" cooling system. My old '90 had the same thing. Make sure your coolant bottle isnt leaking or cracked and try putting a new cap on it to hold the pressure. Did you make sure and "burp" the air out of the system when you put in the new water pump? Hope these things can help you track down the problem...also check to make sure the jeep is actually overheating and that your gauge isn't messin' with ya
Edit: took me too long to type this so didnt see the posts above...sounds like a blocked radiator
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #5 of 19 Old 04-19-2009, 08:34 PM
keepishop
1989 XJ Cherokee
OP has a closed cooling system, which is VERY prone to air bubbles messing things up. You need to let out the air, and you should be fine. You should be able to remove the temperature gauge sender near the back of the head to get most of it out.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #6 of 19 Old 04-19-2009, 08:38 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I completely looked over the year model, and would agree completely that you have air trapped in the system. Burping the system should fix your problems.http://www.lunghd.com/Tech_Articles/...BurpAirMod.htm
xjfever is offline
post #7 of 19 Old 04-19-2009, 08:40 PM Thread Starter
89jpcherokee
yes it is an 89 and the fan and the radiator do seem "old" to say the least we did burp the system and the collant bottle is new also (was doing the plugs one day and was too short to reach the last one and slipped sitting on the engine and my elbow landed on the bottle) also another thing is that if you let the truck heat up the coolant in the bottle will surge up and down and spill out of the bottle the hotter the engine gets the more violent the surge (splashing and what not) i dont know if im missing something or adding too much coolant, not enough coolant or if its another broken part radiator etc... also i dont have a garage im doing this in my backyard
i will burp the system again tomarrow and see if it helps any thanks a lot so far guys
post #8 of 19 Old 04-19-2009, 09:01 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Just a thought if you replaced the lower hose, did you get one with a spring in it? If not could be the hose collapsing and cutting off the flow of coolant while driving. That would explain the temp being okay when idling and it running hot when driving.
xjfever is offline
post #9 of 19 Old 04-19-2009, 10:12 PM Thread Starter
89jpcherokee
my orig hose didnt have a spring in it tho
post #10 of 19 Old 04-20-2009, 12:38 AM
1deadeye
1988 XJ Cherokee
Check to see if the upper radiator hose is rock hard when warmed up. Make sure the cap is on the resevoir. If it's rock hard you have a bad head gasket. Would explain everything in the quotes above.
Scott
1deadeye is offline
post #11 of 19 Old 04-20-2009, 05:01 PM Thread Starter
89jpcherokee
ok so i got home today added some coolant to it the bottle was bone dry... took it out and drove it for about 5 minutes with the heat on and the temp light started to come on very dim then getting brighter... i shut the heat off and almost immediately the light went out... drove it around for like 15 more minutes with no problem except everytime i turn the heat on the light comes on also the radiator hoses are kind of hard but not anything that seems too unusual when you say "rock hard" you should not be able to squeeze it easily i presume mine wasnt impossible to squeeze but did have some pressure
post #12 of 19 Old 04-20-2009, 05:03 PM Thread Starter
89jpcherokee
also its a cool day out today with heavy rain its about 50 here
post #13 of 19 Old 04-21-2009, 11:11 AM
kongpheng
burp the system with the Air Conditioner ON. lots of people forget about the air conditioner when burping. if there is air inside your heater core, you need to get it out! my .02
2001 Cherokee XJ Sport 4.0L
3" Rough Country Lift w/ Daystar 1.25" TC Drop Kit
Flowmaster Delta 40 Series
K&N Drop in Air Filter & Procomp 10" E-Fan
AirRaid TB spacer w/ 62mm Bored TB
BFG All-Terrain K.O. on Black ProComp 87's
kongpheng is offline
post #14 of 19 Old 04-21-2009, 12:33 PM
bhicks
I recently replaced my engine and went ahead and replaced the radiator, water pump, thermostat and all hoses at the same time. I oredered my radiator from radiatorbarn.com and it is the 3 layer kind. My engine actually runs hotter now then before. I assume I probably have all types of air bubbles. You mentioned the need to burp the system. How do you do that?
bhicks is offline
post #15 of 19 Old 04-21-2009, 06:55 PM Thread Starter
89jpcherokee
its says above how to. click on the link that xjfever posted i think i have a little more problem then trapped air i think air is getting added the system via the head gasket luckily i work at a jeep dealer and have the service manual so it should be very straight forward now
Overheating Problem '90 4.0L mattrendo XJ Cherokee Technical Forum 2 02-03-2009 07:00 PM
Please help. overheating problem. huntking24 XJ Cherokee Technical Forum 2 08-24-2008 06:19 PM
Overheating problem Altec88 XJ Cherokee Technical Forum 4 07-26-2006 12:42 AM
Overheating Problem b(k)ill94xj XJ Cherokee Technical Forum 13 08-17-2004 11:01 PM
Overheating problem XJ dREW XJ Cherokee Technical Forum 20 06-23-2003 06:19 PM
