4.0 oil on top of valve cover - JeepForum.com
post #1 of 8 Old 09-22-2013, 06:08 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
We all get tired of the oil film/leak on top of our 4.0 Jeep aluminum valve covers. Many times the biggest culprit is the loose fitting oil filler cap. Here’s a real easy fix:
Remove the plastic oil filler cap and wrestle the original rubber gasket from it using a small pick or screwdriver.
Make a duplicate of the gasket out of an old bicycle inner tube using scissors and a knife or razor blade.
Install the duplicate on the cap first, and then the original over top of it.
It will be a tight fit on the valve cover the first time, and may require some persuasion with a pair of pliers, but will get easier with time.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #2 of 8 Old 09-22-2013, 09:11 AM
CCKen
CCKen's Avatar
Originally Posted by cruiser54 View Post
It will be a tight fit .............the first time, and may require some persuasion with a pair of pliers, but will get easier with time.
That's what she said.
CCKen is offline
post #3 of 8 Old 09-22-2013, 10:52 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
I have ALWAYS wondered how to stop that. I tried two of the stock rubber pieces but it was way too thick. Thanks for this piece of info
1990JEEPXJ is offline
post #4 of 8 Old 09-22-2013, 04:08 PM
Paradise XJ
1988 MJ Comanche
Didn't think of just making the washer/gasket a bit thicker with the use of more material...I just went to the hardware store and bout a thicker rubber washer that fit over the cap and laid flat within the grooves.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #5 of 8 Old 09-22-2013, 08:13 PM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yeah, but no mention of the pliers..............
post #6 of 8 Old 09-23-2013, 06:55 AM
CCKen
CCKen's Avatar
Would tweezers be more applicable to you....
CCKen is offline
post #7 of 8 Old 09-23-2013, 07:09 AM Thread Starter
cruiser54
cruiser54's Avatar
1990 MJ Comanche
LOL. ChannelLocks.
post #8 of 8 Old 09-23-2013, 08:44 AM
STi954
Do you happen to have a pic of this? Sorry I come across this at work just now, knowing I have the same problem I thought I could make something here but I cannot picture what the gasket looks like. If not no worries I'll just look tonight and do it tomorrow.
Thanks
Yellow Jeep Club #954
K.C.C.O.
STi954 is offline
