4.0 Oil Pan Removal - JeepForum.com
post #1 of 5 Old 03-25-2012, 11:52 AM Thread Starter
GoCats
4.0 Oil Pan Removal
Hi All,
I have a '99 Cherokee Sport with the 4.0. I have been trying to remove the oil pan so that I can replace the rear main seal. I have run into a problem trying to get the two rear most bolts off of the pan. I have been working on them for a while and it doesn't look like it is even possible to get a socket around them. Does anyone have any tips or tricks to get to these? Are they a weird size?
GoCats is offline
post #2 of 5 Old 03-25-2012, 12:04 PM
LesterBurnham
There is an additional u shaped bracket at the back of the pan the "saddles" the pan below the RMS. It is the "oil pan support bracket". I had to chip away the rubber to access the bolt heads. Here is a little post I made on it when I changed mine:
http://www.jeepforum.com/forum/f11/o...-help-1107048/
LesterBurnham is offline
post #3 of 5 Old 03-25-2012, 12:36 PM Thread Starter
GoCats
Thanks for the info! What is the function of the bracket? Is it really necessary to replace it if I damage it?
GoCats is offline
post #4 of 5 Old 03-27-2012, 09:43 PM
robert644
1989 XJ Cherokee
I believe they are a different size bolt. Maybe metric, but not torx.
robert644 is offline
post #5 of 5 Old 06-14-2012, 11:42 AM
thirdslide
1991 XJ Cherokee
FYI, not to beat a dead horse, but you can push a 13mm socket against the "saddle" and force it on to the bolt. It's rubbery and will move out of your way enough to get the socket on the bolt head. The two rear are larger bolts than most of the oil pan bolts, which are 11mm if I recall correctly...
thirdslide is offline
96 XJ Cat Removal? Sirus789 XJ Cherokee Technical Forum 3 10-22-2009 11:44 AM
Tie Rod Removal girlcrazy_4 XJ Cherokee Technical Forum 7 12-31-2006 07:28 AM
Alt. removal ? XJ Xtreme XJ Cherokee Technical Forum 1 09-04-2006 08:01 PM
Oil Pan Removal ? stevenaa XJ Cherokee Technical Forum 3 04-05-2006 01:09 AM
need cat removal freakmonkey1423 XJ Cherokee Technical Forum 2 12-27-2003 09:49 AM
