4.0 help!!!!! - JeepForum.com
post #1 of 14 Old 12-08-2012, 06:43 PM Thread Starter
blackhelix1969
4.0 help!!!!!
hey so i have an 89 cherokee and it starts fine then after about 10 mins it starts freaking out and dropping idle or the idle will jump all over the place drop go back up drop again then it will just die but turn right back on. i replaced the icm and i am going to replace the iac but i need other ideas of what it could be.
blackhelix1969 is offline
post #2 of 14 Old 12-08-2012, 07:06 PM Thread Starter
blackhelix1969
i also have a emissions light on but didnt think anything of it. could a bad o2 sensor be causing it??
post #3 of 14 Old 12-08-2012, 07:20 PM
josh94xj
1994 XJ Cherokee
Sounds kinda like a sensor problem, o2 sensor, maybe but I'd guess TPS just my .02cents maybe wrong but it wouldn't hurt to test it, there are rite ups on here how to do it.
Sent from my 2 door Cherokee!
"Jeep. Go prepared."
Originally Posted by Teal2doorXJ View Post
i say screw it and just rawdog it!
Originally Posted by cherokeekid58 View Post
Selling your jeep is like selling your soul....
NEW JEEP PROJECT COMEING SOON!
josh94xj is offline
post #4 of 14 Old 12-08-2012, 07:42 PM
blackolive99
X2 on the TPS
blackolive99 is offline
post #5 of 14 Old 12-08-2012, 07:53 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Emissions light is on a timer/mileage guestimate. Means it's time to replace your oxygen sensor.
Are your intake manifold bolts tight?
Got a multimeter and know how to use it?
All your vacuum lines intact, especially the one from the throttle body to the MAP?
When was the last tuneup with plugs, wires, cap, rotor, and fuel filter?
Want some things to check?
Read some of these:
http://www.cherokeeforum.com/f51/cru...x-tips-153657/
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #6 of 14 Old 12-08-2012, 08:30 PM
87manche17
1987 MJ Comanche
Im having a somewhat similar issue, and Ive narrowed it down to my ECM. Hopefully in your case its just a bad sensor.
87manche17 is offline
post #7 of 14 Old 12-08-2012, 09:00 PM Thread Starter
blackhelix1969
well i tried the tps. it isnt that. how did you find out it was your ecu?
post #8 of 14 Old 12-08-2012, 09:47 PM Thread Starter
blackhelix1969
so if i unplug the iac shout it make a difference in idle or change anything? because i just did and it didnt make a difference
post #9 of 14 Old 12-08-2012, 10:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Not necessarily.
post #10 of 14 Old 12-08-2012, 10:01 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Did you adjust the new TPS?
post #11 of 14 Old 12-09-2012, 08:27 AM
87manche17
1987 MJ Comanche
I replaced every sensor on it
post #12 of 14 Old 12-09-2012, 01:14 PM
GetLifted
Sounds like a bad o2 after closed loop starts. Try unplugging the o2s and see if it still happens.
GetLifted is offline
post #13 of 14 Old 12-09-2012, 02:35 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Only has one O2, and yes that could be the cause. Still haven't found out yet if the OP adjusted his new TPS. Putting a new one on just willy-nilly can cause it to run as bad or worse.
post #14 of 14 Old 12-09-2012, 06:18 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
1. Adjust your TPS per below procedure from Cruiser54. The TPS for 87-90 4.0 engines MUST be adjusted.
2. Replace your oxygen sensor. They aren't that expensive and they can be the best money you spend. They have a finite lifespan and that lifespan is a little less on the RENIX engines. Bosch or NTK will be fine here. Spend the money.
RENIX TPS ADJUSTMENT
Before attempting to adjust your TPS be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up.
IMPORTANT NOTE: With the Key OFF, and using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS. The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. Wiggle the wiring harness where it parallels the valve cover and also over near the MAP sensor on the firewall. If you see more than 1 ohm of resistance, or fluctuation in your ohms reading, some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed.
MANUAL TRANSMISSION:
RENIX manual transmission equipped XJs have only a flat three-wire TPS mounted on the throttle bodyand it provides data input to the ECU. It has three wires in the connector and they're clearly embossed with the letters A, B, and C. Wire "A" is positive. Wire "B" is ground. Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Loosen both T-20 Torx screws attaching the TPS to the throttle body and rotate the TPS until you
have achieved your desired output voltage. Tighten the screws carefully while watching to see that your output voltage remains where it is supposed to be. If you can't achieve the correct output voltage, replace the TPS and start over.
Sometimes, after adjusting your TPS the way outlined above, you may experience a high idle upon starting. If that happens, shut the engine off and reconnect your probes to B and C. Start the engine and while watching your meter, turn the TPS clockwise until the idle drops to normal and then rotate it back counterclockwise to your desired output voltage.
AUTOMATIC TRANSMISSION: RENIX automatic transmission equipped XJs have a TPS with two connectors. There is a flat three-wire connector, same as the manual transmission vehicles have, and it is tested the same as the manual transmission equipped vehicles, as outlined above—FOR ALL ENGINE MANAGEMENT RELATED ISSUES.
However, the automatic TPS also has a square four-wire connector, clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. THIS SQUARE FOUR WIRE CONNECTOR IS USED FOR TRANSMISSION/SHIFTING RELATED ISSUES ONLY. Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU.
FOR AUTOMATIC TRANSMISSION RELATED ISSUES: Check the square four-wire connector side of the TPS.
If you have ENGINE ISSUES check the flat three-wire connector side of the TPS.
For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
bad , cherokee , idle , problems
