4.0 Flywheel Alignment ... Critical??? - JeepForum.com
post #1 of 4 Old 04-14-2010, 09:13 AM Thread Starter
bharris68
Daily Driver
Working on replacing the clutch in my friends 1992 4.0 AX-15 equipped Cherokee - I pulled the flywheel down to press a new bearing in, thinking that it was like my 2.5L - lo and behold the bearing is pressed into the crank, ick!
I can deal with that based on the threads here but my fear here is that I did NOT mark the position of the flywheel vs. the crank before I popped it down!!! I did my best there when I got it back up..
I marked the freaking bolts - but not the flywheel and crank.. Genius...
looking over a few threads here, I'm a little scared that I'm going to have to open the tranny and engine over and over to readjust it... However, I'm wondering if the engine computer will look at the position of the flywheel and then just balance out the fact that it's the factory flywheel and the tone windows are the same, it will just need to adjust the timing?????
bharris68 is offline
post #2 of 4 Old 04-14-2010, 01:40 PM
AZ Jeff
2014 JK Wrangler
If the flywheel is position sensitive, there two methods used commonly:
1. one bolt (or more) is offset from the others, thus preventing installation in more than one position.
2. one or more dowel pins will be used, with an offset pattern, to locate the flywheel.
If you do not see those, assume it is not position sensitive.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 4 Old 04-14-2010, 02:40 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Yes. AMC-patterned cranks have asymmetrical patterns so that the flywheel (or flexplate in the case of an automatic) only goes on one way for proper counterweight clocking purposes.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #4 of 4 Old 04-14-2010, 10:17 PM Thread Starter
bharris68
Daily Driver
Yep - final word - THANK HEAVEN it is ONLY possible to put it on one way! Success!! Then... the clutch PEDAL broke... New thread for that...
4.0 , cps , flywheel , timing
HELP Iron Rock 6.5" Critical Path Long Arm Lift Kit HELP Daltanic XJ Cherokee Technical Forum 9 05-05-2010 05:59 AM
iron rock critical path 6.5 lift feedback ... HEAT XJ Cherokee Technical Forum 3 12-03-2008 07:10 PM
YAY! My 6.5" Critical Path Long Arm from Iron Rock Offroad came today PICS!!! Offroadss350 XJ Cherokee Technical Forum 17 11-16-2007 09:30 PM
Flywheel drewguere XJ Cherokee Technical Forum 3 05-19-2006 11:50 AM
Flywheel R&R BlackWhyJay XJ Cherokee Technical Forum 6 04-01-2004 10:53 PM
