#1 | |
4.0 engines
1997 4.0L HO engine vs. 1998 4.0 engine.
Back when I bought my 98 Cherokee, I had also purchased a 1997 Cherokee with the 4.0 "high output" engine. While I don't have the '97 anymore, what is the difference, if any between the two, and what are the HP/torque specs? TIA.
1994 Safari Sarengeti 37' DP RV (92K) 1995 Daihatsu Hijet (82K Km's) 1997 Ford F150 (164K) 1998 Jeep Cherokee SE (154k) 2006 Chevy Aveo LS (28k) |
#2 |
It pretty much is the same HP and Torque, except that Chrysler made the exhaust ports on 98+ 4.0's itty bitty so it would be more environmentally friendly.
#3 |
4.0L I6
Bore x Stroke 3.88" x 3.41" Displacement 242 (4.0L) Compression Ratio 8.8:1 Horsepower (net) 180@4750 Torque (net) 220@4000 Main Bearings 7 Valve Configuration OHV Fuel MPI The 4.0L I6 that is used in the XJ and ZJ is rated slightly higher than the YJ and TJ 4.0L engine probably due to a different exhaust system. 4.0L I6 Bore x Stroke 3.88" x 3.41" Displacement 242 (4.0L) Compression Ratio 8.8:1 Horsepower (net) 185@4750 Torque (net) 220@4000 Main Bearings 7 Valve Configuration OHV Fuel MPI The Jeep 4.0 litre I6 engine is a pushrod overhead valve design with 2-valves/cylinder. The factory power ratings are as follows: '87...... XJ: 173hp at 4500rpm, 220lbft @ 2500rpm, redline 5000rpm '88-'90 XJ: 177hp at 4500rpm, 224lbft at 2400rpm, redline 5000rpm '91-'95 XJ: 190hp at 4750rpm, 225lbft at 3950rpm, redline 5250rpm '96-'99 XJ: 190hp at 4600rpm, 225lbft at 3000rpm, redline 5300rpm '00-'01 XJ: 193hp at 4600rpm, 231lbft at 3000rpm, redline 5300rpm '91-'95 YJ: 180hp @ 4750rpm, 220lbft @ 3950rpm, redline 5250rpm '96-'99 TJ: 181hp @ 4600rpm, 222lbft @ 2800rpm, redline 5300rpm '00-'06 TJ: 190hp @ 4600rpm, 235lbft @ 3200rpm, redline 5300rpm '93-'95 ZJ: 190hp @ 4750rpm, 225lbft @ 3950rpm, redline 5250rpm '96-'98 ZJ: 185hp @ 4600rpm, 220lbft @ 2400rpm, redline 5300rpm '99-'05WJ:195hp @ 4600rpm, 230lbft @ 3000rpm, redline 5300rpm This is a bit from "jeeptech" pages. Yes the HO made more ponies |
#4 | |
Thanx. This is exactly what I was looking for.
#5 | |
#6 | |
#7 | ||
Universal Cereal Bus
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
