4.0 engine compatibility - Page 7 - JeepForum.com
post #91 of 123 Old 08-01-2016, 03:34 PM
drewjbx
XJ to ZJ accessories
hello all, I want to put in a 1998 XJ motor into a 1998 ZJ... Posts in this thread does show the blocks are interchangable.. my question is will everything else bolt into place, fuel injection, AC, steering pump, etc...
drewjbx is offline
post #92 of 123 Old 08-01-2016, 03:51 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Remove and re-use as needed or required from your original engine: Intake/Exhaust manifolds, flex plate/flywheel, cylinder head, distributor-less ignition or distributor assembly, engine sensors, motor mounts, fan belt driven accessories and/or mounting brackets. They will all bolt on.
CJ7-Tim is offline
post #93 of 123 Old 08-21-2016, 10:46 AM
ptuttle78
If I wanted to put a 2000 Cherokee motor into a 97 TJ wrangler. What all would I need from Cherokee besides the motor?
Sent from my iPhone using Tapatalk
ptuttle78 is offline
post #94 of 123 Old 08-21-2016, 11:25 AM
CJ7-Tim
CJ7-Tim's Avatar
Nothing.
Remove and re-use ( or replace with new ) as needed or required from your original engine: Intake/Exhaust manifolds, flex plate/flywheel, cylinder head, distributor-less ignition or distributor assembly, engine sensors, motor mounts, fan belt driven accessories and/or mounting brackets.
CJ7-Tim is offline
post #95 of 123 Old 10-17-2016, 12:46 PM
Whitelx1
I have a 2003 Grand Cherokee and will be needing a motor.
Will a motor from a 1998 Cherokee work..
Thanks in Advance..
Whitelx1 is offline
post #96 of 123 Old 10-17-2016, 02:02 PM
bluejunior
bluejunior's Avatar
Thanks in Advance..
You'd have to swap your head over to it to maintain the coil less ignition and thus your PCM, but as far as I know the block would fit. Some of the bolt ons are likely different as well. Almost definitely the exhaust, good chance the intake as well as accessory brackets. Hopefully others have more for you.
Lifted, Locked, Stiffened
bluejunior is offline
post #97 of 123 Old 10-17-2016, 04:44 PM
CJ7-Tim
CJ7-Tim's Avatar
I have a 2003 Grand Cherokee and will be needing a motor. Will a motor from a 1998 Cherokee work..
No, it will not work.
TJ/WJ 4.0L Engine blocks underwent significant design changes effective in the 1999 WJ Grand Cherokee and 2000 TJ Wrangler. These blocks are not interchangeable with any XJ/ZJ engine blocks. The reason why is because motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
CJ7-Tim is offline
post #98 of 123 Old 10-17-2016, 07:20 PM
Whitelx1
Thanks for your reply...
What about a 05 Wrangler...
Whitelx1 is offline
post #99 of 123 Old 10-17-2016, 08:58 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange.
2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange.
XJ/ZJ blocks, and the 2000+ TJ/WJ blocks do not interchange without significant modifications. (1991 to 1995 YJ and 1997-1999 4.0L TJ Wrangler blocks will interchange in XJ/ZJ and visa-versa).
TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
XJ: "Regular" (not Grand) Cherokees 84-01
ZJ: Grand Cherokee 93-98 (Gen1)
WJ: Grand Cherokee 99-04 (Gen2)
YJ: Wrangler 87-95 (Gen1)
TJ: Wrangler 97-06 (Gen2)
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #100 of 123 Old 02-19-2017, 11:37 AM
KJinAZ
I am looking to swap the engine out of my 2001 TJ. I bought an engine from a 1999 TJ that I want to put a stroker kit in before making the swap. I have read through the posts and I am sure this question has been answered many times, but I am still confused if this swap is compatible. I did notice when disassembling the donor engine that there were some differences in the accessory mounting brackets, but did not look close enough to see if the holes were in the same place. Is there any modifications that would be needed if it is not a straight swap. Any advise is appreciated.
KJinAZ is offline
post #101 of 123 Old 02-19-2017, 12:28 PM
bluejunior
bluejunior's Avatar
One difference off the bat: 99 uses a distributor. 01 uses distributorless. You'll need to either swap the 99 PCM and such over to controlled the distributor ignition or else find a good 00+ head (preferably 03+ to avoid the bad 0331 casting) that had the proper mounting for the coil on plug setup. I don't know of any other big differences but I'm not a TJ guy so Idk their brackets.
post #102 of 123 Old 02-19-2017, 12:51 PM
CJ7-Tim
CJ7-Tim's Avatar
I am looking to swap the engine out of my 2001 TJ. I bought an engine from a 1999 TJ ......
This question would best and most completely be answered in the TJ forum. It is likely that this is not a simple bolt in swap.
As detailed above, the belt driven accessory locations and possibly the motor mount bolts holes are not compatible. This specific TJ to TJ swap will likely require modifications to the engine bay wire harnesses and A/C lines in addition to possible engine mount modifications.
CJ7-Tim is offline
post #103 of 123 Old 02-19-2017, 01:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
See Post 3.
post #104 of 123 Old 04-11-2017, 01:42 PM
drewjbx
Hello... we are doing an engine swap.. both a XJ? (grand cherokee) 98 4.0 engine... wire adapters to exhaust manifold under the carb is different, plus a connector isnt even there on one of the engines (manifold area)
are there are 2 variations for this year? what other changes could there be?
drewjbx is offline
post #105 of 123 Old 07-21-2017, 10:54 PM
jjstrom
If I understand this info correctly a 4.0 from a 93 Cherokee will interchange with the 4.0 in my 97 Grand Cherokee. Understanding that I may have to reuse a few parts. If I have to reuse my intake will it bolt up to the head of the 93 motor. Thanks
Sent from my SM-G930V using Tapatalk
jjstrom is offline
cherokee , compatibility , engine
Engine Compatibility bullydad XJ Cherokee Technical Forum 2 03-03-2012 09:28 AM
Engine Compatibility stinealbert XJ Cherokee Technical Forum 1 12-14-2011 12:20 AM
engine compatibility nhlnms XJ Cherokee Technical Forum 12 06-16-2010 01:55 PM
2.5 engine compatibility 01xjltd MJ Comanche Technical Forum 1 04-03-2010 09:01 PM
Engine compatibility Lkhoyt XJ Cherokee Technical Forum 9 06-08-2007 09:49 AM
