4.0 Crate Motor ?? - JeepForum.com
post #1 of 10 Old 03-11-2006, 06:45 PM Thread Starter
dforeid
4.0 Crate Motor ??
GM, Ford, Mopar, all have crate motor programs. My '95 4.0 is starting to age and was wondering if there is a place to get a 4.0 crate motor?
Any help ???
Thanks,
Don
dforeid is offline
post #2 of 10 Old 03-11-2006, 06:56 PM
AllXJ96
not that i know of, but for the price of an engine swap, you could have a stroker kit done, which will basicly give you a new engine with more power.
(Rust In Peace) 07 JK 2 Door 4" Superlift 37"MT's
01 4-Door Cherokee, 62mm TB, DD
For all your Jeep Needs, Morris 4x4 1-877-553-5337 ext 484 (10%)
AllXJ96 is offline
post #3 of 10 Old 03-11-2006, 06:57 PM Thread Starter
dforeid
With a stroker motor, do you need to change the injectors?
dforeid is offline
post #4 of 10 Old 03-11-2006, 07:03 PM
XJ4oh
1997 XJ Cherokee
Jasper Engines sells 4.0's with a 3 year 36k warrenty or so... as do a few other companies.
Is there anything wrong with your engine? Does it smoke, tick, knock...? Generally 4.0's will last a long time, so thats why I am asking.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #5 of 10 Old 03-11-2006, 08:15 PM
twisted_ed
twisted_ed's Avatar
well my local dealership does, 3000 for a rebuild (install, labor parts, all inclujsive basicallyu) and 5000 for a crate motor... I intend to just purchse another motor from the wreckers and might stroke it if i can figure out a way to do it without having to use 97 octane or whateever redicously high octane level they insist on least for some of em... so it depends on what you want to do, oh prices i qouted are canadian. I will prob see what it costs for a crate motor and ill put it in... gotta be like 1500 cheaper at least
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
twisted_ed is offline
post #6 of 10 Old 03-11-2006, 09:12 PM
LEAD_NOT_FOLLOW
LEAD_NOT_FOLLOW's Avatar
1989 XJ Cherokee
For the $$ you'd have in a Jasper (or like) or a crate motor send your existing motor off to get rebuilt (ie. stroker). You'll be a lot happier in the end... (I know I am)
LEAD_NOT_FOLLOW is offline
post #7 of 10 Old 03-11-2006, 09:21 PM
iwishihad1
i would have done a stroker.. but my block had 3 holes in it i could put my fist into..lol.
i went with a jasper 4.0 replacement. 1900 installed and running
iwishihad1 is offline
post #8 of 10 Old 03-11-2006, 10:50 PM Thread Starter
dforeid
Where is Jasper engines located, and will they do a stroker engine? To answer earlier question, motor runs good now, uses no oil, just in the mood to tinker I guess.
dforeid is offline
post #9 of 10 Old 03-12-2006, 09:50 PM
greenbeater
greenbeater's Avatar
1968 FSJ Wagoneer
not to be an a$$ but if your gonna tinker why fix something that aint broke?? if your gonna do that much (time and money) why not upgrade insted of just replace?? (ie. stroker).. i mean no disrespect and do what makes you happy its your ride and money just dont make much sense to me is all
his - 68' Wagoneer, 455 Pontiac, tons
hers - 00' XJ tail rig D44, C9.25, 4.56
ours - 01' WJ 4.0
greenbeater is offline
post #10 of 10 Old 03-12-2006, 10:05 PM
Bgeddes
Bgeddes's Avatar
1978 CJ5
There are some good simple strokers out there, check here first:
http://www.jeep4.0performance.4mg.com/stroker.html
He lists lots of options, and fairly inexpensive too.
As others have said, if you want to tinker, the 4.0 is hardly a component in need of it, better time and money would be spent on armor, diffs, axles, etc, the 4.0 is legendary in it's reliability, other XJ parts are not. If you want to do some underhood work, try an On Board Air or an On Board Welder, both are tinkerer type projects.
'00 XJ Classic > Stock DD
'88 Grand Waggy - Bone stock pseudo-barnfind
'78 CJ5 - Under minor rehab
Bgeddes is offline
crate d44 lilnapsak XJ/MJ Cherokee Non-Technical Forum 9 12-27-2009 09:57 AM
Possible diesel crate engine for your XJ? MGrobe XJ Cherokee Technical Forum 6 11-17-2009 10:48 PM
4.0L v6 crate motor?? Efekt98XJ XJ Cherokee Technical Forum 3 03-26-2009 12:01 PM
Which Crate Engine to choose?? jdcountryboy91 XJ Cherokee Technical Forum 12 09-12-2008 10:05 PM
might be picking up a beater XJ. where to buy crate motor from? Magic2979 XJ Cherokee Technical Forum 3 07-06-2005 12:28 PM
