4.0 Cranking Issues - JeepForum.com
post #1 of 3 Old 12-17-2009, 09:20 AM Thread Starter
matt62485
4.0 Cranking Issues
Recently purchased a 98 XJ Sport. Had top engine problems (smoked and coolant in the oil) . PO says they changed the headgasket (doesn't look like it though) and it still smoked. Anyways, I got another motor for it waiting to be put in.
I did try to turn the other motor over, however, it won't turn over.
I jumped underneath and took a screwdriver to the starter solenoid lugs and it turned right over, but wouldn't start.
Went back up, and checked all the fuses visually and with a DMM and all of them checked out good.
Could a relay be causing this issue? If so, which should I look for and what's the best way to check it?
I'm pretty electronics/electrical savvy but not very much with vehicle ignition systems.
Any ideas? I would like to get this figured out so when I put the new motor in it'll be ready to go.
[]IIIIII[]
matt62485 is offline
post #2 of 3 Old 12-17-2009, 01:57 PM Thread Starter
matt62485
bump
char count
[]IIIIII[]
post #3 of 3 Old 12-17-2009, 04:19 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Check the relays under the hood in the power distribution center on the passenger side of the engine bay. The relays have the same part number and can be swapped around. There should be one for the starter.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
Jeep is cranking and cranking, no start HeavyMetal XJ Cherokee Technical Forum 32 06-11-2010 08:44 AM
cranking and cranking no start heep of feces XJ Cherokee Technical Forum 29 11-28-2007 08:18 AM
when cranking 91xjgawes XJ Cherokee Technical Forum 2 01-25-2006 10:13 AM
Cranking but won't start Death-Mobile XJ Cherokee Technical Forum 3 09-17-2005 06:00 PM
Odd cranking... The_Other_One XJ Cherokee Technical Forum 3 01-07-2005 11:14 AM
