4.0 6 quart oil capacity, not me.... - JeepForum.com
post #1 of 13 Old 05-09-2013, 01:34 AM Thread Starter
hshark
Ok so I've owned my jeep for around two months now and performed an oil change soon after purchase. So when I looked up the oil capacity I found some controversy. Most say 6 quarts and some (very few) say 5 quarts. I've even read that one of the popular repair manuals has it at 5 quarts. So being that the Jeep is new to me I check everything out often and listen for noises, rattles etc. I do this to get a feel for my XJ. So with that said I check my oil level often and noticed that I'm in the safe zone and I only used 5 quarts of oil. The dipstick is not aftermarket so that rules out dipstick issues anyone else have similar results? My XJ is a 96 sport which should be the same 4.0 engine in most XJ. Oh and I don't have a factory manual either. What do you guys think?
hshark is offline
post #2 of 13 Old 05-09-2013, 04:09 AM
Timo_90xj
Timo_90xj's Avatar
When replacing engine oil and oil filter, fill up to top level on the oil dipstick. It usually requires about 5.5 quarts, but depending on oil filter etc. it's something between 5-6 quarts. 6 quarts is the fill level for a dry engine, ie. after a rebuild. Some oil always remains in the engine when changing oil.
***Under construction***
Timo_90xj is online now
post #3 of 13 Old 05-09-2013, 06:16 AM
Kalali
My 00XJ requires 6 Qts according to the OM and that's what I have used for the past 180K miles since I've owned the car new. The oil capacity is not a debatable topic. It is what the manual calls for.
Kalali is offline
post #4 of 13 Old 05-09-2013, 09:43 AM
Timo_90xj
Timo_90xj's Avatar
So according to you, if let's say 0.3 quarts of oil does not drain out from the engine, you nevertheless pour in 6 quarts of oil and overfill the engine? Fact is, you pour in oil until dipstick reads oil level is at maximum. It could be 5.5 quarts, it could be 5.9 quarts, or whatever depwnding on how much oil did not drain out. Overfilling oil is not what you want to do.
post #5 of 13 Old 05-09-2013, 09:47 AM
PaYankee
I always end up using 5.5 quarts or I don't get in the safe zone.
99 xj 2wd/94xj 4wd np231 3lift
PaYankee is offline
post #6 of 13 Old 05-09-2013, 11:06 AM
98GooseXJ14
1997 XJ Cherokee
All of mine with a filter have taken 6.5 qts to get to the top of the dipstick. Never understood why..
2000 Jeep Cherokee XJ 95k miles - Sold
1998 Jeep Cherokee XJ 160k miles - Killed/Sold
1997 Cherokee XJ 173k miles 5spd Killed/Sold
98GooseXJ14 is offline
post #7 of 13 Old 05-09-2013, 12:29 PM Thread Starter
hshark
See this is why I'm confused. Timo brought up an interesting point about engine oil staying inside engine, I guess I will just go off my dipstick. From now on when someone asks oil capacity I will answer till dipstick reads full or safe our manual which I don't have might say six, but I'm good at 5. Beats me......
hshark is offline
post #8 of 13 Old 05-09-2013, 12:33 PM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
My 00XJ requires 6 Qts according to the OM and that's what I have used for the past 180K miles since I've owned the Jeep new. The oil capacity is not a debatable topic. It is what the manual calls for.
Fixed that bad mistake for you.
TheBoogieman is offline
post #9 of 13 Old 05-09-2013, 02:08 PM
buildin1XJ
I agree with TIMO add 5 quarts check the dip stick and add from there. Start the engine to fill oil filter shut off let sit for 5 minutes and recheck the oil level.
buildin1XJ is offline
post #10 of 13 Old 05-09-2013, 08:32 PM
djb383
Somewhere between the 2 marks is "perfect". The top mark is "max", the bottom mark is "minimum". If the top mark were "perfect" (where oil level should always be), there would only be 1 mark, no?
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #11 of 13 Old 05-09-2013, 11:10 PM
xjdantheman
1993 XJ Cherokee
you know i changed the oil in my jeep and i put in 6 quarts and it only read at the add line. that was right after the oil change and then a couple days later, level never changed.
so i added one more quart and its right on the money. as far as i can tell the dipstick is original and seats fine, so i am either a quart over or somehow my oil filter is over sized.
xjdantheman is offline
post #12 of 13 Old 05-10-2013, 01:52 AM
Timo_90xj
Timo_90xj's Avatar
Nope, top mark is perfect and anything below that affects in quite a few things. Minimum is the minimum amount that you can safely run the engine under normal use. Don't consider, for example, extremely steep up- or downhills when wheeling to be "normal use"
post #13 of 13 Old 05-10-2013, 05:18 AM
mschi772
1997 XJ Cherokee
Changing oil after running the engine and warming it up helps the oil flow out better allowing you to get slightly more out. If you're messy/clumsy, you can get burned this way though. The bottom line is: buy more than 5 qts for a 4.0 oil change. Changing the oil warm, I used nearly 6 qts with the stock oil filter size. I run a larger oil filter now and have to add just a little bit more. I just buy two 4 or 5 qt jugs for each oil change. Having some extra oil around can be quite handy or I'll just use it when I change the oil in my girlfriend's Outback since that EJ25 loves the same oil the 4.0 does.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
