Quantcast 35s on the way...trimming fenders questions - Page 2 - JeepForum.com
Truck-Lite 7" Round Headlamp Giveaway! - Drive OffRoad Gift Certificate Contest!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 35s on the way...trimming fenders questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSwag Off Road BIG-HIT TJ-YJ Rear BumperNEW Fawkes modular recovery & bull bar mounts for WJs.
Unread 05-21-2008, 10:15 PM   #16
gregmondro
I used this guide with mine (RE 5.5" kit on 35" tires)
http://www.rocklizardfabrications.com/fender_trimming.htm
finished it up with protekto trim afterwards.
Don't forget to hammer in the pinch seam inside the front fenders.
99 Jeep XJ - NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
FiveZeroFive
XJ 8.25 Rear End Disc Brake Conversion For Sale!
gregmondro is offline   Reply With Quote
Unread 05-22-2008, 06:25 AM   #17
Power5
I cut to the top of the flareout on the metal of the fender. I just barely rub on the top. For the back edge of the front fender opening, you should cut till there is only 1 bolt left on the front fender. I believe there are 2 bolts on the bottom edge of the front fender. Cut to between them. That is where I get most of my rub from. My front edge barely rubs as well so you might need to deviate from the line a tad.
Aaron
1999 XJ @ 6” on TSL 35s w/ Aussie D44 & XRC8
Power5 is offline   Reply With Quote
Unread 05-22-2008, 06:48 AM   #18
b1gkyl3
http://secure.terrys.net/browse.php?categoryID=200
b1gkyl3 is offline   Reply With Quote
Unread 05-22-2008, 07:52 AM   #19
jnance50
1997 XJ Cherokee
Personally I like the Armacel Pipe Insulation for trim. And everyone is right, just cut and fold the back - it's easy and trim how ever much you want off the front - an angle grinder makes short work of it
Pipe Insulation Trim
"Geez, your XJ must be different than mine. My XJ has the optional 'Every-bolt-must-break' option combined with the ultra-rare 'Find-rust-under-everything' package" -- 4.0H.O.XJ
I once got a ticket for jerking while driving it. The cop wouldnt let me use his pen to sign the ticket. -- 4.0H.O.XJ
jnance50 is offline   Reply With Quote
Unread 05-22-2008, 12:10 PM   #20
Cherokeekid88
If i were you man, i would put the tires on first, I mean your sittin at 6.5" right? you might not need to trim that much.
97 XJ 4.0 Auto D30/29 Sp. 8.25. Yukon 4.10's
4.5" IRO Long Arm
IRO HD Tie Rod/IRO Adjustable Trac Bar
33x12.50x15 BFG AT's on 15x8 Soft 8's
2.5" Exhaust with Hi flow Cat/FM Super 10
Cherokeekid88 is offline   Reply With Quote
Unread 05-22-2008, 12:12 PM   #21
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
only if he just drives it on the road. lift height as nothing to do with tire clearance offroad when the suspension flexes.
Jason West - Jeepin.com | JeepinOutfitters.com
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline   Reply With Quote
Unread 05-22-2008, 05:50 PM   #22
RogueXJ
1997 XJ Cherokee
Hey does anybody have a picture of the cut and fold method from the inside of the wheel well. I just dont understand fully what is meant by the technique.
Jeep XJ 97' 4.0 I6 60 mm TB Bore,
______________________________________
My Jeep isn't getting LIFTED....its EVOLVING.
RogueXJ is offline   Reply With Quote
Unread 05-22-2008, 06:11 PM   #23
GottaBeJeep
Use these together:
http://www.rocklizardfabrications.com/Adjusting_Bumpstops.htm
IMHO, if you are only running 35's, the cut and fold method is overkill and looks like arse. Trim to the pinch welds, use the protecto trim, adjust your bumpstops properly, and call it a day. You have 1.5" more lift than me and 5" narrower with your 15x8" 4" backspaced rims, and I don't rub my 35's and I haven't trimmed past any pinch welds (trimmed into some of them since they aren't in a perfect line, but no cut and fold here).
Rock Lizard Fabrications
...Off Road Armor that's "Tough as Scales"
GottaBeJeep is offline   Reply With Quote
Unread 05-22-2008, 06:45 PM   #24
dudeinatj
http://www.jeepforum.com/forum/5106208-post21.html
dudeinatj is offline   Reply With Quote
Unread 05-22-2008, 07:47 PM   #25
Cherokeekid88
oh yeah i understand, but what im saying is, if he gets the tires and bolts em on and lets it sit, you can pretty much visualize how much fender needs to go. When i did mine, i didn't want to have to cut too much fender off, so i trimmed, then tested flex and then smoothed out as needed. The rear will be easy, because you just hammer up more metal if you need more room.
4.5" IRO Long Arm
Unread 05-22-2008, 10:08 PM   #26
BftXJ
where can you get the protectko trim casue according to rocklizards website there sold out
Rustys 3 inch lift
DC-1 rims with 31x10.50 Mickey Thompson MTZ's
JCR Stage 3 Front Bumper
JCR stage 2 sliders
Detours Tailbone Tire Carrier
Flowmaster 40, dumped after axle
BftXJ is offline   Reply With Quote
Unread 05-23-2008, 05:20 AM   #27
bmyohn
Youngin'
bmyohn's Avatar
ill probably get them mounted and stuff, then decide exactly how i want to trim them.
2011 Dodge Ram 1500 Big Horn 4x4
5.7L V8 Hemi
"The Tow Rig"
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline   Reply With Quote
Unread 05-23-2008, 06:09 AM   #28
GottaBeJeep
Dirk at www.dpgoffroad.com
Unread 05-23-2008, 06:19 AM   #29
Vendor
1995 XJ Cherokee
cut:
fold:
then mask off and paint.
