Quantcast 350 lt1 or chevy 350 swap anyone? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 350 lt1 or chevy 350 swap anyone?
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 10-19-2004, 12:37 AM   #1
Phoenix916
Has anyone put an LT1 350 in a Cherokee? will a sbc motor fit in an XJ and is there an adapter to keep my transfer case and tranny? Will I need a bigger radiator and will any junkyard radiators work? Is there a cheapy replacement fuel pump or will the stocker put out enough fuel (what psi do XJ's run)? I have done the LT1 swap into a 92 firebird so the wiring and basic stuff like that will be no problem but how many more hasles will there be to put one in an 89 Cherokee 4.0? Any help would be awesome I just want to see how much of a project this would be.
Thanks
Brett
Phoenix916 is offline   Reply With Quote
Old 10-19-2004, 12:49 AM   #2
Xride
for the rad, use a LT1 one.
keeping your tranny... umm maybe with a custom bell housing, but uhh can you say BANG! the LT1 puts out a good amount more power then a 4.0
getting it to work with the transfer case shouldnt be hard.
fuel pump from yours will not work, you are carb, so ~6 psi the Lt1 needs ~40
I amagine custom motor mounts will be the hardest thing if it even fits. the Fbody is a good amount winder then the XJ and it hardly fits in them, but people get them into YJ's so it cant be too hard.
Xride is offline   Reply With Quote
Old 10-19-2004, 12:55 AM   #3
Phoenix916
My Cherokee iseither Multi port or tune port injection(89 was the first year), I put new HO injectors in it. It shouldn't be too hard for me to find an fbody radiator. Does anyone sell a bellhousing for this swap?
thanks
Brett
Old 10-20-2004, 12:22 AM   #4
Phoenix916
ttt. What about going with the Grand Cherokee 318, Anyone do that?
Brett
Old 10-20-2004, 12:15 PM   #5
Koenig
Check out this link guys...best one i've found and deals only with Jeep powertrain conversions!
http://www.novak-adapt.com/knowledge/knowledge_gateway.htm
Hope that helps!
[SIZE=1][URL=http://www.cardomain.com/id/koenig1]1989 Jeep Cherokee Laredo [I]"Betsy"[/I][/URL]
~147,000km, 4.0l, AW4, K&N custom cone intake,
Dark Cordovan Pearl Metallic in color, 4 Dr. w/ chrome trim.[/SIZE]
Koenig is offline   Reply With Quote
Old 10-20-2004, 12:18 PM   #6
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
grand cherokee 360
Anyway, a guy I know has an LT1 in his 89 Cherokee. He said it was the worst thing he has ever done, however it is pretty cool. He also upgraded the tranny, t-case, and axles. You know its bad when you have to pull the engine to change spark plugs.
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Old 10-20-2004, 12:36 PM   #7
Lucky13
for the amount of money you would spend dropping a chevy 350 in with the trans and other stuff you could just buy a supercharger for you 4.0 or get a 4.7 stroker and stil have money lft over. but if you are hell bent on dropping a chevy small block in your xj, i have a 383 stroker that dyno'd at 587 hp @ 6200 rpms and 634 ft. lbs. @ 2300 rpms that i'll sell you for $5,000 i also have lots of other engines and tranmissions that would work for your swap idea.
Me and my friends did acid in the woods, 'cuz there was much less chance of running into an authority fugure. But we ran into a bear. And that is way more of a buzz kill. I looked around and saw my friend swearing to prevent forest fires. Later, he came up to me and said, "Mitchell. Smokey is way more intense in person.- Mitch Hedberg
Lucky13 is offline   Reply With Quote
Old 10-20-2004, 12:57 PM   #8
98XJVT
Matt, if you like the 360, youd love the 408... I know if I was going through the trouble of a 360 swap, Id stroke it out to 408 and really make some power.
98 XJ 4.0L I6
62mm tbody, 62mm spacer, custom intake
Dynomax Catback, Carsound Cat
98XJVT is offline   Reply With Quote
Old 01-14-2009, 12:48 PM   #9
memphisxj
1993 XJ Cherokee
There is a company that makes a plate to mount an AX-15 to a 350 block. Im getting ready to start building my LT1 for this same swap. If anyone has pictures of an LT1 or any 350 for that matter in a cherokee, could you please post them. Thanks
memphisxj is offline   Reply With Quote
Old 01-14-2009, 01:00 PM   #10
josh25050
with a big enough shoe horn you can put in anything you want....as for how you do it i have no idea but it would be sweet.my freind swaped a 4.3L F/I v6out of a chevy s-10 blazer into his xj and thats awsome he ordererd a manual from some web site that gave him step by step info on how to do it....it had pics and every thing it even told you what parts you need form diff vehicals..just look around you'll find something.
josh25050 is offline   Reply With Quote
Old 01-14-2009, 01:50 PM   #11
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
It's not mine, but it sure was cool to see and hear.
LS1 with new tranny, Tcase, computer, motor mounts, alum radiator, Ford 9" rear axle
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 01-14-2009, 02:08 PM   #12
warrior_oh58d
1991 XJ Cherokee
dear god!!!!!!!!! i...i....i...don't know what to say to that.........shaaawwwing
warrior_oh58d is offline   Reply With Quote
Old 01-14-2009, 02:13 PM   #13
RcCola
2011 JK Wrangler
Originally Posted by CJ7-Tim View Post
LT1 with new tranny, Tcase, computer, motor mounts, alum radiator, Ford 9" rear axle
You mean LS1
RcCola is offline   Reply With Quote
Old 01-14-2009, 02:44 PM   #14
dcorn
A friend of mine put a 5.3L Vortec motor from an Envoy into his Wrangler. Aftermarket heads and cam, 4L60E trans, 231 T-case and stock Rubicon D44 front and rear. He did all the wiring and stuff himself, super clean install.
I keep bugging him to help me put one in mine, I'll let you know what it happens lol.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is online now   Reply With Quote
Old 01-14-2009, 03:35 PM   #15
bhicks
I just finished cleaning the drool off my face after I saw this thing. I now have a new mission in life. I need a V8 Cherokee.
bhicks is offline   Reply With Quote
Glock Forum
