350 Engine Swap - JeepForum.com
post #1 of 8 Old 10-27-2010, 01:12 PM Thread Starter
BeavisButthead
1990 XJ Cherokee
350 Engine Swap
Ive got a fully built 350 and want to swap with my 4.0 any suggestions on how I should go about this
BeavisButthead is offline
post #2 of 8 Old 10-27-2010, 01:20 PM
ChicoXJ
1986 XJ Cherokee
Be prepared to use the GM tranny, it will work much better for you. Also cooling will be a problem and will not be cheap. Basically you will end up changing everything before you are done. You will also need to vent the hood so you can cool it.
ChicoXJ is offline
post #3 of 8 Old 10-27-2010, 01:26 PM
jkh
All the information, and many of the parts, you need:
Novak Jeep Conversions - Home
Jason
'98 XJ: UpCountry, bastard pack, 2" spacers, JK shocks, 31" BFG AT's
'81 Honda GL500
Colorado Jeep Club Member #399
jkh is offline
post #4 of 8 Old 10-28-2010, 11:34 AM
450rracer22
1990 XJ Cherokee
i actually just finished put a 350 in my 90 cherokee. it was a bit of a bear. the best thing you can get is an entire donor vehicle. i used a 97 silverado with the 5.7L and a 700r4. that way you can basically just swap everything under the hood over to the jeep. your deffinently going to need to go to a GM transmission for sure because a 350 will destroy a jeep tranny very very quickly. I would recomend a 700r4. if you have a 231 transfercase it will be fine, if not better get one or go better.. I had to do a bit of fab work on the front end to get the chevy rad and trans cooler in. i ran dual electric fans instead of the clutch fan. you have plenty of electrical power now. i made a cowl induction hood and it runs around 180. i would not recommend leaving the D35 in the rear if your going to wheel it at all. it will not hold up. i drivetrain upgrade of some sort is in order. the front will be fine unless your really beaten it or have bigger than 33intires on it. i would swap the rear for a ford 8.8 out of a 97-2000 explorer if you wanna do the sye kit or a 8.25 out of a jeep. its quite a project but worth it. i just got back from blackmountain in Harlan ky and i made it way more places with all the extra power. Oh and if the motor is a vortec the hood will most likely not close when your finished.
450rracer22 is offline
post #5 of 8 Old 10-28-2010, 02:38 PM
jkh
Any chance you did a build thread for the swap?
So you put the Chevy radiator in the XJ? How much fab was needed to fit it in? If it's not much, it'd be better than shelling out $500+ for the Novak one.
Jason
'81 Honda GL500
jkh is offline
post #6 of 8 Old 10-28-2010, 04:52 PM
450rracer22
1990 XJ Cherokee
alot of fab work is needed. the Chevy rad is roughly 41in wide which takes you just inside the headlight buckets on the jeep. the core support must be redone completely as well as the grill and some of the doghouse. not runnign the clutch fan gives you alot more room . I would just get a new radiator if i had to do it again. if you run the dual electric fan setup there is really no need for that size radiator, but the bigger the better. i have herd of people using 4.3L chevy radiators and the dual fan setup and being fine.
post #7 of 8 Old 11-15-2010, 07:18 PM
gregamuffin
do you think the chevy 4.3l radiator plus the dual electric fan setup would cool a gm diesel 6.2?
gregamuffin is offline
post #8 of 8 Old 11-15-2010, 11:30 PM
g19n87r
a 97 chevy without a 4l60e?
g19n87r is offline
engine swap!!! pudjohnson XJ Cherokee Technical Forum 3 12-28-2009 12:18 PM
High Performance engine options? Stroker? Engine swap? fast64 XJ Cherokee Technical Forum 1 04-27-2007 05:34 AM
Engine swap Mateo94XJ XJ Cherokee Technical Forum 1 10-09-2006 12:32 PM
Engine Swap jeepxj89 XJ Cherokee Technical Forum 8 10-21-2004 09:10 AM
engine swap XJBill XJ Cherokee Technical Forum 26 11-07-2002 04:56 PM
