35"s... Axles? - Page 2 - JeepForum.com
post #16 of 20 Old 07-11-2012, 03:13 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Go 4.88 for sure
1990JEEPXJ is offline
post #17 of 20 Old 07-11-2012, 11:39 PM
xGArfx
def go 4.88 over 4.56s. I paid roughly 1500 for gears, full install kits, a new front carrier, and labor. Do NOT cheap out on the labor, this isn't something you take to "joe bob" down at the corner gas station to do, the installers must know what their doing and do it well. If you get a ****ty install you will have issues with worn out bearings, broken gear teeth, noise, vibrations, ect ect ect.
For the 8.25 I think it costed my 10 bucks more for the 4.88 over the 4.56s... hardly a difference in price. I went with Yukon gears front and rear, technically they sent me USA Standard for the front dana 30 but USA is a "brother" company to Yukon so its basically the same. Go with high quality install kits as well something like Timken or Koyo would be your top choices.
xGArfx is offline
post #18 of 20 Old 07-12-2012, 07:17 AM Thread Starter
acurrier2012
Looks like ill be going 4.88. Id say spending the extra money and doing it the right way will be worth it. Thanks for the info guys.
acurrier2012 is offline
post #19 of 20 Old 07-12-2012, 09:37 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
That's the right way to do it. Do it once. Do it right.
post #20 of 20 Old 07-12-2012, 09:52 AM Thread Starter
acurrier2012
Ive gone the cheaper way a couple times with previous vehicles. That never worked out. Usually paid for it to be fixed the cheaper way, it broke again, and then i spent more fixing it the right way. Worth it in the long run. Thanks again!
33s , 35s , axle , cherokee , help needed
16" or 17" wheel on tj with jk axles redlined67 Tires & Wheels 5 08-27-2009 10:11 PM
33"s, Need recommendations for gearing my axles Yurco4x4 Engines & Drivetrain 6 07-02-2008 08:49 PM
Will 16" tires fit on 07-08 Rubi axles? Replayray Tires & Wheels 6 06-27-2008 06:15 PM
Need help figuring ZJ axles for a DD 35"+ gunthagunth Engines & Drivetrain 6 01-13-2007 03:04 PM
44" tires and axles samsammy23 Tires & Wheels 24 02-25-2004 10:18 PM
