35"s... Axles? - JeepForum.com
post #1 of 20 Old 07-10-2012, 01:28 PM Thread Starter
acurrier2012
35"s... Axles?
Ive got an 01 Cherokee, 4.0L. Its lifted just over 7 inches. It has almost brand new 33"s, but id like to get 35"s.
Would they run fine with my stock Axles?
acurrier2012 is offline
post #2 of 20 Old 07-10-2012, 02:32 PM
saharacon87
Depends on what axle you have. If its a chrysler 8.25 you could run 35s but if its a dana 35 you're going to want upgrade your axle. Either way you're going to want to regear. Theres a big jump going from 33s to 35s. Its not just how much lift you have.. You have to think about steering, brakes, gears etc.
TJ 3" FT, Front Currie Arms, v8 zj steering, 30 locked/44 open, 33 m/t, Armor
saharacon87 is offline
post #3 of 20 Old 07-10-2012, 05:00 PM
ltrail
1984 XJ Cherokee
And 7" is a lot of lift. It will clear the 35 but like said if you have the 29spline chrysler axle you are good. The d35 or the 27spline chrysler no bueno.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #4 of 20 Old 07-10-2012, 05:55 PM
xGArfx
Like was already said, if you have an 8.25 rear and you swap a HP dana 30 front then yes. Thats with new 4.88s, a disk brake swap in the rear and definately some kind of OTK steering setup.
I would definately get some kind of heavy duty covers front and rear to help with ring gear deflection and protection of the gears. If you wheel with lots of wheel spin in the rocks then you might want to get some alloy/chromo front axle shafts or at the minimum full circle snap ring the u joint into your stock shafts.
xGArfx is offline
post #5 of 20 Old 07-10-2012, 06:11 PM
jeepinjeffrey
There you go! just what I was going to say!
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline
post #6 of 20 Old 07-10-2012, 10:48 PM
kelso1337
Me 2, 10char, post count raising FTL.
Stock 2003 Jeep TJ - 'Intense Blue'
Bought the jeep in April, found JF in May...
First Mod in June.
kelso1337 is offline
post #7 of 20 Old 07-11-2012, 07:24 AM Thread Starter
acurrier2012
Thanks for the info. I have a chrysler 8.25 (I believe). How would you recommend me going about regearing?
If its not obvious, im new at the Jeep thing.
post #8 of 20 Old 07-11-2012, 07:36 AM
austin6137
1990 XJ Cherokee
Honestly I take it to reputable gear shop, I've done everything on my jeep myself but gears are one thing I'd leave to the pros. Gears have to be set up dam near perfect and you need special tools, not saying you can't do it yourself its just not something I'd attempt.
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #9 of 20 Old 07-11-2012, 07:40 AM Thread Starter
acurrier2012
Ya i wouldnt do it myself.
Any estimates on how much id be looking at total? Like i said, not too familiar with jeeps yet as this is my first one.
post #10 of 20 Old 07-11-2012, 08:06 AM
saharacon87
I took mine to a friends shop and it was 150 per axle in labor plus the cost of the gears and install kit. Including the locker cost it cost me about a grand. If I could do it again I would swap in a HP30.
post #11 of 20 Old 07-11-2012, 08:21 AM Thread Starter
acurrier2012
Yeah thats not too bad. Ill definitly have to look into it.
Thanks for the info!
post #12 of 20 Old 07-11-2012, 09:07 AM
ltrail
1984 XJ Cherokee
I want to live near that shop! Gear setup here is 250-300. A guy could get two axles for the price of one where you're going. I did my own, its not that hard but takes some experience to get right. With 35" tire I'd go 4.56 or 4.88. Depending on driving status and how often you drive it. My area everything is pretty flat all around, until you get out of town some. If you Live somewhere with those rolling hills I hear about you may want the deeper 4.88.
ltrail is offline
post #13 of 20 Old 07-11-2012, 09:12 AM Thread Starter
acurrier2012
Id mostly be using the jeep on tar and flat dirt roads. Occasionally i take it through the mud, but everytime i go in, i tend to break something. So i try to stay out of it.. Lol.
Does gearing for 4.56 and 4.88 have a price difference?
post #14 of 20 Old 07-11-2012, 09:29 AM
saharacon87
Haha with great prices comes great responsibility.. I had to take both axles out of the jeep. Nothing comes without a catch.
post #15 of 20 Old 07-11-2012, 10:19 AM
ltrail
1984 XJ Cherokee
My axles were not originally in the vehicle lol. When I bought the gears they tried selling the installation. I asked at another shop when I bought install kit and they said about the same price per axle.
ltrail is offline
33s , 35s , axle , cherokee , help needed
16" or 17" wheel on tj with jk axles redlined67 Tires & Wheels 5 08-27-2009 09:11 PM
33"s, Need recommendations for gearing my axles Yurco4x4 Engines & Drivetrain 6 07-02-2008 07:49 PM
Will 16" tires fit on 07-08 Rubi axles? Replayray Tires & Wheels 6 06-27-2008 05:15 PM
Need help figuring ZJ axles for a DD 35"+ gunthagunth Engines & Drivetrain 6 01-13-2007 02:04 PM
44" tires and axles samsammy23 Tires & Wheels 24 02-25-2004 09:18 PM
