35's and 4.56..damage possible? - JeepForum.com
post #1 of 11 Old 09-07-2009, 06:28 PM Thread Starter
xtremexj59
1997 XJ Cherokee
hey yall,im regearing my axles(dana 30 up front & chrys 8.25 29 spline in the rear) and ill also be putting in a bearing rebuild kit(new bearings and such). i was curious to ask if i were to run 35's and 4.56 gears on open axles would this be an accident waiting to happen?
xtremexj59 is offline
post #2 of 11 Old 09-07-2009, 06:33 PM
99Greenmachine
Not necessarily...now your axle shaft strength and ujoints are going to come into question...not to mention if you run with lockers or not.
If it's gonna be a street beater, i dont think it would be a problem
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #3 of 11 Old 09-07-2009, 06:36 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
No damage worries, but why 4:56 and not 4:88? The 4:88 gears would get you back closer to stock.
xjfever is offline
post #4 of 11 Old 09-07-2009, 06:43 PM Thread Starter
xtremexj59
1997 XJ Cherokee
im running it open for the time being,i just cant afford a locker at the moment. dont burn for not doing it all at once. im running 4.56 because i have 33's on now and ill have them for awhile but i want to run 35's for the occasional mud pit or soft sand trails
post #5 of 11 Old 09-07-2009, 07:20 PM Thread Starter
xtremexj59
1997 XJ Cherokee
anyone else want to chime in. criticism is welcome
post #6 of 11 Old 09-07-2009, 07:20 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I gotcha, The 29 splined 8.25 is only margionally weaker than the d44 so I wouldn't worry about the 35's at all.
xjfever is offline
post #7 of 11 Old 09-07-2009, 07:25 PM Thread Starter
xtremexj59
1997 XJ Cherokee
how about transmission or transfer case failure due to the stress of the bigger tire? is it much more strain than what 33's put on it?
post #8 of 11 Old 09-07-2009, 07:29 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The brakes and steering will be the weak points with 35" tires. Running the lower gears will save the t-case and tranny. Lots of folks run 33" tires with stock gears and get by with that set-up, although I wouldn't recommend it. So 4:56's with 35" tires will be a lot easier on the drivetrain.
xjfever is offline
post #9 of 11 Old 09-07-2009, 07:34 PM Thread Starter
xtremexj59
1997 XJ Cherokee
what would be the weak points in the steering and what could i do to upgrade the brakes and said steering weak points?
post #10 of 11 Old 09-07-2009, 07:53 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
the tierod is the weak point in the steering, it is made of very thin tubing and will bend very easily. You can replace it with one from a V8 ZJ, which will be much beefier, or there are lots of aftermarket ones out there. The brakes are weak with stock tires and 35's will make them a lot worse. Some folks use WJ knuckles and steering, which will give you bigger brakes and a better steering set-up. There are many options for upgrading though.
xjfever is offline
post #11 of 11 Old 09-08-2009, 12:33 AM
bikedude189
1993 XJ Cherokee
for the most part the only parts DOWNSTREAM from the gears will be affected. since the engine is supplying the power to the tranny/tcase/driveshafts it will see absolutely no difference in power. if you have horrible axle wrap, then you'll maybe break a u joint, but no possibility of t case or tranny damage beyond stock. and when your tires are trying to spin the axle they have a HARDER time doing it with the lower gears, so lower stress.
long story short, you should be just fine on those axles with open diffs. like said the 8.25 is plenty strong and the 30 is quite beef as well especially with the larger u joints (especially if your running 760x joins) now your weak point is probably the carrier or ring and pinion.
good luck with gears, i just did mine this weekend. couple of tips-
-get a good quality bearing puller, i spent about 200 for one on ebay, definately made my life easier
- 400 degrees in the oven is TOO HOT! it will blue the bearings (at least if they have gear oil on them, we'll see how they hold up...) try 350 or 375 degrees max, and put your pinion in the freezer, the lower pinion bearing will slide on. this trick will save you from having to use a hydraulic press
-a 4 lb sledge will often be your best friend, as well as a large pry bar
-dont compromise and be patient! its so worth it!
-disregaurd all if your having a shop do it
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline
front end damage littleleonard XJ Cherokee Technical Forum 3 03-08-2009 08:49 AM
oil pan damage? howhedoesit XJ Cherokee Technical Forum 11 12-13-2008 10:07 PM
oil pan damage kanky1972 XJ Cherokee Technical Forum 4 04-17-2007 08:40 PM
Trail damage help Concept2w XJ Cherokee Technical Forum 3 01-14-2005 07:19 PM
damage DonEighties XJ Cherokee Technical Forum 1 10-06-2004 04:41 PM
