34x9.5 on Stock axles? - JeepForum.com
post #1 of 24 Old 04-12-2010, 06:45 PM Thread Starter
vallone530
1993 XJ Cherokee
I believe my rear is 8.25. will it work, thanks.
vallone530 is offline
post #2 of 24 Old 04-12-2010, 06:48 PM
MrZucchinihead
yeah, people run 35x12.50's on it, you'll be fine.
MrZucchinihead is offline
post #3 of 24 Old 04-12-2010, 06:59 PM
N2OJeep
Junior Member
you'll be fine as long as you dong drive like an asshat
N2OJeep is offline
post #4 of 24 Old 04-12-2010, 07:19 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Your power and mileage will suffer unless you regear the axles. If you have an auto transmission I would add a transmission cooler to help keep the transmission cool.
xjfever is offline
post #5 of 24 Old 04-12-2010, 07:21 PM
Nick
2006 WK
Words of wisdom here.
2001 WJ | 4.7L V8 |
Hemi Club Member 60
1990 White XJ Laredo [Sold]
2000 Silverstone XJ Classic [Sold]
2006 Dodge Charger RT Hemi [Sold]
2001 Jeep Grand Cherokee [Current]
Xbox Live gamertag: XJ Nickk
Originally Posted by DcMuff View Post
Banned for being the cooler Nick
Nick is offline
post #6 of 24 Old 04-15-2010, 07:52 AM Thread Starter
vallone530
1993 XJ Cherokee
Thanks I got a 5 speed, whats gears 4.56? I changed my mind to 33s and probably wanna throw a locker in. but someday wanna run 35s. If i was to run 35s will axles be able to handle it with gears and locker?
post #7 of 24 Old 04-15-2010, 09:24 AM
Willy36
1990 XJ Cherokee
You would certainly be pushing it and it may be cheaper in the long run to find a good junkyard 9 inch or something and fab it to work rather than run the risk of breaking them, but I have seen it done. You just have to be veeeerrrry easy on the skinny pedal.
Willy36 is offline
post #8 of 24 Old 04-15-2010, 09:28 AM
Nick
2006 WK
The 8.25 could probably handle it, but I think an axle swap would be better in the long run. With 35s and a locker you'll definitely want to regear and possibly look at new axle shafts. I'm 90 percent certain you can't fit anything past 4.56 gears in the 8.25- could be wrong, though.
2001 WJ | 4.7L V8 |
Hemi Club Member 60
Nick is offline
post #9 of 24 Old 04-15-2010, 09:32 AM
toates89
1989 XJ Cherokee
as a temp fix you could swap some stronger axles from an auto. and then your 5speed would be matched with higher auto gears. and it wouldnt be as bad.
I noticed going from 235's to 31's. just changed when i need to shift
toates89 is offline
post #10 of 24 Old 04-15-2010, 10:00 AM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
What year is your Jeep? '96 and earlier had weaker 27 spline shafts and '96 and later had stronger 29 spline shafts. You can upgrade both types with chromoly shafts for a little over $150.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #11 of 24 Old 04-15-2010, 10:05 AM
dcorn
I wheeled with an XJ on 35's and stock axles/shafts. He was locked front and rear as well and doing some pretty crazy obstacles. I thought he was gonna break something for sure but didn't have a single problem.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #12 of 24 Old 04-15-2010, 10:24 AM
Skwerly
1988 XJ Cherokee
The D44 is a tad stronger than the 8.25, and the Ford 8.8 trumps them all, but is more work to get installed.
However, I'm VERY active in driving off-road trails, and I know a handful of guys that run the 8.25 (29 spline) with 35s, locked, and haven't busted a shaft. They don't lay on the skinny pedal a lot though, either.
Personally, I believe that finding a junkyard Dana 44, slapping in 4.56 gears and a locker and forgetting about it is the way to go. The "best bang for your buck" way, anyhow.
Skwerly is offline
post #13 of 24 Old 04-15-2010, 11:02 AM Thread Starter
vallone530
1993 XJ Cherokee
its a 93 I probably wont run 35s for about a year just wanna run 33s for now should i still re gear, i probly wont be able to
re gear for a few months. i hear 33s are bit sluggish but tolerable right now its got 31s road tires, I'd be buying 33x10.5 km2s. thanks for the input
post #14 of 24 Old 04-15-2010, 11:41 AM Thread Starter
vallone530
1993 XJ Cherokee
My uncle runs 32 inch super swampers with stock gears, same exact jeep as mine I dont see that 33s would make a huge difference but i thought i would ask
post #15 of 24 Old 04-15-2010, 12:14 PM
Skwerly
1988 XJ Cherokee
They do. It significantly raises the gear ratio. Off the line you don't necessarily see too much slug, but wait til you are going up a hill and the tranny doesn't know where to be, or you try and pass someone. IMO, you should run at least 4.10s with 33s, and preferably 4.56 gears.
Skwerly is offline
34x9.5 LTBS hvaclu3 XJ Cherokee Technical Forum 3 01-20-2009 01:17 PM
34x9.5 cherokeewes XJ Cherokee Technical Forum 8 11-04-2006 05:22 PM
stock axles vs alloy axles ? NOS/86 XJ Cherokee Technical Forum 7 02-21-2006 08:22 AM
stock axles 35s? oscarxj XJ Cherokee Technical Forum 3 05-22-2005 11:15 PM
You still have stock axles? Myles XJ Cherokee Technical Forum 7 01-30-2002 01:05 PM
