31's or 30's - JeepForum.com
post #1 of 8 Old 03-07-2002, 09:41 AM Thread Starter
jeeptrailrunner
Question 31's or 30's
OK...I have heard people putting 31's with a lift on a 97+ cherokee...I have a 98 and want to get 31's, but people say that the 31's will stuff pretty badly with only a 2 inch lift. I heard of some people putting the 30 in w/o a lift. so...is it ok to get 31X10.5 or only 30's with a 2 inch lift?
thanks...cheers
2000 TJ Sport,5spd, BFG AT 31x10.5, XM sattelite radio....more to come....when the time comes:)
jeeptrailrunner is offline
post #2 of 8 Old 03-07-2002, 12:18 PM
hjeepxj
hjeepxj's Avatar
Post
what 2"? why not just go with rustys 3" its 245$ you will beable to run 31" tires easily, 30"s can go stock, little articulations, but perfect with a 2" 31"S can go on stock, you just need to trim 31"S could go on a 2" but not very good offroad
88 Jeep Cherokee, Lots of Mods.
hjeepxj0.tripod.com
"Im okay, im alright, just might get a little high tonight, im okay, im alright, CARRY ON!"
-Pat Green
hjeepxj is offline
post #3 of 8 Old 03-07-2002, 01:08 PM Thread Starter
jeeptrailrunner
Post
hey hjeepxj, you note was a little bit unclear...I can run 31 with a 2 inch lift?
I have the front blocks, so I just have to get the shackels in the back...I am a college student...so $$$ is not good for me.
post #4 of 8 Old 03-07-2002, 01:10 PM Thread Starter
jeeptrailrunner
Post
oh...one more thing...this sounds stupid...btu "trim" what?
post #5 of 8 Old 03-07-2002, 08:02 PM
CB89XJ
Post
Get 31's. You may rub on the LCA's (lower control arms), so just adjust the steering stops or your driving.
Chances are you will want to go to a bigger lift in the future, and then you will already have the tires for it. You should be ok for minor offroading w/ only a 2" lift.
Trimming would be to trim either the fender flares, or the fenders completely. That first cut is the hardest one.
Colin Beatty
'87 YJ, built 351W, T-18, NP-205, SOA, SRS, 35x12.50 ProComp MT's, cage, winch, Tomken bumper/carrier, d44/9"
www.bmja.org
CB89XJ is offline
post #6 of 8 Old 03-08-2002, 01:52 PM
hjeepxj
hjeepxj's Avatar
Post
i meant that you could run 31's on a 2" lift with rubbing but if you trim your fenders good you can run them good, also get good offset rims
hjeepxj0.tripod.com
-Pat Green
hjeepxj is offline
post #7 of 8 Old 03-08-2002, 05:44 PM Thread Starter
jeeptrailrunner
Talking
thanks for you help...cheers
jeeptrailrunner
post #8 of 8 Old 03-09-2002, 11:19 AM
Greenmachine
Post
You may need a SYE ( slip yoke eliminator) due to driveline vibration on 97 and newer XJ's, if you want to use a lift of 2 inchs or more..
so i'm told.
98 XJ stock. 235x15
Greenmachine is offline
30's or 31's 99xjjoe XJ Cherokee Technical Forum 4 10-16-2009 10:13 PM
30's or 31's? CrAlt XJ Cherokee Technical Forum 18 10-12-2007 06:23 PM
30's vs. 31's on BB? Need new tires soon... JBassXJ XJ Cherokee Technical Forum 11 09-21-2007 09:14 AM
31's or 30's 88wagon XJ Cherokee Technical Forum 10 08-29-2006 12:45 PM
30's or 31's with 2" lift? silverxj2001 XJ Cherokee Technical Forum 10 12-30-2003 12:09 AM
