#1 | |
$300 '92 Beater Build
If you have just stumbled onto this build thread for the first time....
STOP!!!! I am in the process of creating a table of contents or similar to post up, so that no one will have to suffer through reading 100+ pages. Instead you will be able to just hit up the highlights. Stay tuned..... Ok, I sarted posting about my new acquisition in the thread I had previously started "Cherokee won't go over 10mph". http://www.jeepforum.com/forum/f11/92-cherokee-wont-go-over-10mph-865770/index2.html#post8011648 Figured I'd start a new thread now that I actually purchased it yesterday, it's now sitting in my driveway, and now it's time to get to work Here are some of my posts from the other thread..... WOW!!! THAT was an experience My first thought was ..... eh..... $300 no matter what condition it's in I'll pick it up and if it's in too bad of condition I can at least sell a few things to break even or even go ahead a few $$'s When I got to this ladies TRAILER she had it running hhhhmmm... wonder why? Maybe because the starter is SHOT and you have to attempt to start the f'er 25 times before it finally catches and fires up? Yeah....probably. So, I knew it was in bad shape, but check out this list... Driver's side door top hinge needs rewelded. It's still attached to the door and needs tacked back on to the body, so anytime you open the door you have to hold it up and then get the f'er to close It has a sun roof but it leaks It leaked so long that it jacked up the headliner, so someone just yanked it all down... for the most part anyway...still has some crap hanging down The passanger side mirror got knocked off. That's an easy fix though. It's just the rear clip that broke. I'm just going to jb weld that bastard in place for now. She SAYS that the heat and A/C works, but the blower doesn't turn on. No rearview mirror a bunch of other little things inside.... and it SMELLS. If I get this running right the next thing I'm doing is stripping the seats out and attempting to salvage the carpet, but possibly just ripping it all out and spraying U-POL Raptor bedliner like I just did with my TJ. I actually considered just yanking the front doors off since they're jacked up anyway and going that route ok....now to the engine/exhaust. She said that the pipe connecting to the CAT was disconnected... YEAH, because the F'N muffler is missing While I drove it around town to get the title notarized it had pretty good pick up and although stupid loud it drove alright. Shocks could use replaced in the next year, tires as well, but overall not too bad for $300. THEN.....THEN.... I get it on the highway. The first 15 minutes it acted fine, but then I just started losing pwr. It just had no "oomph" I could go about 45mph and that was it. At first I was trying to force it to shift and go faster, but it didn't seem to matter what gear I was in. It still wouldn't get up and go. So, to avoid pushing it too hard and causing it more problems I laid off it a bit. Sat in the right lane at 40-45 with my flashers on. What could be causing this... here are my thoughts F'N exhaust TPS Clogged/Crappy fuel filter Oh, and checked the air filter and it looks pretty new IDEAS...THOUGHTS.... COMMENTS....LAUGHTER Let me have it
#2 |
I picked up a new starter for it last night that will get replaced first. I'm removing the driver's side door, so I don't have to keep holding it up to get in and out. Well, either that or swinging by somewhere to get the hinge tacked on real quick. My original plan was to JB Weld that biznatch on and call it a day
Not sure it would be strong enough though and should probably do it right. I need to get a welder and learn how to weld. What a better opportunity to do so than this beater, right? Ok, so that's starter, door, and then the exhaust needs sorted out. I'm trying to decide if I should just pick up a CAT and cat back exhaust off of ebay and install myself or go to a muffler shop and see what they can do for me for dirt cheap..... Starter comes first though, because that **** is EMBARRASSING 25 tries per start....hahahaha |
#3 |
At least you're not alone, last week picked up a $600 96 XJ for my gf, no floors, no rockers, beat to hell. Next day saw a 95 for $1200 in WAY better shape, bought the 95, sold the 96. 5 minutes after we bought it, drove across the street to fill it up to get it home, wondered why I smelled gas...hole in the tank (near the top luckily). This one the hood doesn't open (broken cable), front u-joints are shot, and tons of other little things.
Trust me man, right now I feel your pain! lol |
#4 |
hahahahaha.... I feel the love
![]() I have one that I WANTED to pick up for $900 that is in WAY better shape inside and out cosmetically, but isn't running. From the sound of it all he needs is a CPS (I think that's what it is....some sensor...) or a fuel pump. I won't have the cash to get that one until I either sell some more motorcycle parts or get my TJ sold. Hopefully the TJ is gone this week. Well....hopefully....but really sad about that as well ![]() |
#5 |
Took some pics real quick earlier today to show the condition of it when I brought it home yesterday. That's the step I usually forget. I USUALLY dive right into it and forget the before pics.
Anyway, real quick today I pulled down the rest of the headliner. They had just pulled some of the cloth down. I removed the rest of it and also all the insulation that was ****ty. Then I removed the sunroof. I wasn't sure what I was doing at the time. I wasn't sure if it was all one piece, but found out quickly when I removed the last screw I'm contemplating just rigging up the sunroof to be a moonroof now. I think that would be the easiest thing to do to fix it, get the headliner area looking clean, and taking care of the roof leak.Pics to follow tonight. |
#6 |
oh and I posted this in another thread, but you guys can help me out here too....
If I get these will I be able to install myself with clamps or something or will they need to be welded? Walker Exhaust 15042 - Walker Super Converters - Overview - SummitRacing.com |
#7 |
i feel y our pain man, i bought a lifted 96 XJ for $800 with 31" tires, love the truck but the rockers are rusted out no headliner and the worst part its over heating like you wouldnt belive- should bout the one for $1300
in theory with the exhaust you can get clamps and over the cours eof about 6-12 months they will fuse together caus eof the heat, when that happens you can take the clamps off... |
#8 |
Yeah, The guys from Summit just emailed me and told me it comes with clamps. Even if it does fuse together there really isn't a need to ever remove the clamps, right? Not that I can think of anyway. SO, I am going to swing by a muffler shop to get a quote. If it's close to the price of the stuff from Summit I may just have them do it. If it's going to be like $100 more or so I'm going to order the stuff in the links I posted above and do it myself.
NOW....do I get someone to weld the door hinges back on for me, attempt to JB weld them myself for a temp fix and see if it can hold that much weight.....OR just take them off and ride open If that's the case I will be removing the carpet and spraying the bucket with U-POL Raptor like I did with my TJ Pics are coming later tonight....be patient ![]() |
#9 |
Ok....I have a ton of pictures from earlier.
Here is the Jeep before I did anything to it.... Rear with great stickers ![]() ![]() Both sides. Notice the big dents in the doors. That's from having to throw your hip into getting the door closed ![]() ![]() ![]() Leaky Sunroof with silicon around it and freakin aluminum tape ![]() ![]() Rotten Headliner partially removed by PO ![]() I was told that the exhaust just came undone.... not that it was GONE ![]() and after sitting all night this is all that had leaked onto the driveway. I didn't check the oil level yet though. Maybe that's all that is left in there TO leak out ![]() *edit* ah crap....forgot I had my photobucket set to upload pics so small. I'll change it and repost these bigger. You need to see the bullet holes on the RHS to get the full effect ![]() I'll post a few of what I did today. Not much, but a start. Last edited by koolaid5; 11-16-2009 at 08:52 PM.. |
#10 |
forum supporter
I would remove the front fenders, then drive it to a welding shop and have the door hinges welded back on. Removing the fenders will give good access to the hinges and allow proper alignment of the doors before welding. That is how I did mine and it worked great. I welded all the way around the hinge too. The factory just puts a short bead on top and bottom of the hinge.
#11 | |
#12 |
Oh, wow....I deleted the pics on facebook and then started uploading them at the larger size and it's just fixing the links as it goes in my post above. I thought I was going to have to redo all of them. NICE!
#13 |
I forsee raptor lined headliner in the future
SUPPORT THE TROOPS 2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear -Zach
#14 |
OK, and here is what I did to it today.....
I ripped down all of the headliner and removed the sunroof assy. Just doing that and not having rotten insulation hanging down already made a HUGE difference. In my mind anyway Now I just need to get that sunroof hole plugged somehow. That....install the new starter, exhaust, and door hinges are top on the list. Then we'll move to more cosmetic enhancements when I know it's actually going to be driveable.![]() ![]() ![]() ![]() ![]() AND I removed all the stickers, but didn't take any pics after that. Last edited by koolaid5; 11-16-2009 at 08:56 PM.. |
#15 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
