3" Bastard Pack, which leafs of an S10? - JeepForum.com
post #1 of 15 Old 08-22-2008, 12:24 PM Thread Starter
1996BlackXJ
I am trying to find a 3" lift for cheap, and I think I want to do a S10 (or similar leaf) bastard pack. There's a junkyard a few towns north that must have every vehicle ever made (their junk yard is like 10 acres) and they have every part usually in their warehouse.
So if I want 3" i know I will want to add the main leaf, but from what I have searched through, that only gives ~2", correct me if I am wrong, and if I am right what else do I add.
As for the rest of the 3" I was thinking 3" coils, shocks and maybe a steering stabilizer all from rustys.
Oh and my stock leaf packs are sagging about an inch
-Max Black 1996 XJ
4.5" lift of assorted brands, 33x10.5 KM2s on D-Windows, JCR rear bumper, Nates Slimline w/Champion 8k winch, custom half doors, roof rack, and tire carrier, Maine Woods dents and pin striping, and various other cool things.
Maine Jeep Club Member #1 Firefighter Jeep Club Member Black Jeep Society Member #163Survivalist Jeep Club Member #14
1996BlackXJ is offline
post #2 of 15 Old 08-22-2008, 06:25 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
If the main leaf on your stock pack is bent over the end 1", the Bastard pack might not work.
If this yard has a LOT of jeep vehicles, I woudl suggest this:
S10 packs. You just nee dthe mains from these packs.
MJ (Jeep comanche pickup) rear shakle.
That combo in the rear will give about 3-3.5" of lift depending on the condition of the S10 packs mains.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 15 Old 08-22-2008, 06:32 PM
sbs10v8
1991 XJ Cherokee
i just put s10 leafs in the back of mine and used this order xj main-s10 main-xj second- s10 second- s10 third- s10 overload... and it netted me about 4.5 inches in the rear. i know that doesn't really help you that much but atleast you know not to put those leaves in.
sbs10v8 is offline
post #4 of 15 Old 08-22-2008, 07:36 PM Thread Starter
1996BlackXJ
My rear leafs are flat, not inverted (yet) so I should be ALRIGHT for the time being, in the future (8-12mo) I may just buy new 3" XJ packs regardless of the condition of the bastard pack (unless they are holding up perfectly)
Thanks for the help, doing this should save me around $200 on my lift.
-Max Black 1996 XJ
post #5 of 15 Old 08-22-2008, 10:53 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I helped a member here build a set using just the S10 mains and his netted a hair under 3" of lift. With luck the mains will be all you need.
93 Sport
Specs in Profile.
balloo93 is offline
post #6 of 15 Old 08-23-2008, 09:10 AM Thread Starter
1996BlackXJ
I asked my brother about it and he said its too much work, that I need to rivet the leafs and what not. Is it true that I can just put it in there and use some new brackets or whatever they are called and be fine, or do I have to be all fancy like my brother says?
Thanks
Oh and my brother is in college to be a machinist and my dads a machinist so I got help from them if I need it lol.
-Max Black 1996 XJ
post #7 of 15 Old 08-23-2008, 09:51 AM
danw77
1994 ZJ
Here is a WORKING link to a PDF of the S-10 BB on NAXJA that is linked in the stickies.
http://webpages.charter.net/laurajef...0_pack_PDF.pdf
This should help you out too.
http://fitchva.com/jeep/?p=56
he uses another jeep main to get 2" but using the S-10 main instead shoul dget you around 3" like baloo said.
1983 CJ7 & 1998 ZJ
Hello, my name is Dan, and I have a Jeep problem.
danw77 is offline
post #8 of 15 Old 08-23-2008, 08:21 PM Thread Starter
1996BlackXJ
Cool! That first pdf is extremely thorough and tells me everything (I hope) I need to know. It looks easier than I thought, now to find some packs, some spare time, and some elbow grease. School is starting tuesday, and with football too, I think time will be the limiting factor lol.
Thanks for the help guys!
-Max Black 1996 XJ
post #9 of 15 Old 08-23-2008, 09:21 PM
HeepToJeep
1982 CJ8
HeepToJeep is offline
post #10 of 15 Old 08-24-2008, 07:58 PM Thread Starter
1996BlackXJ
Originally Posted by HeepToJeep View Post
Looks interesting but I would rather just pay $100 for new XJ 3" coils then try to find some of those T-bird used coils and have to still pay probably $35+ for em, not knowing how well they will ride.
Leaf springs are the most expensive part of a 3" lift, thats why I want to do some bastard packs.
-Max Black 1996 XJ
post #11 of 15 Old 08-24-2008, 10:33 PM
HeepToJeep
1982 CJ8
Have any idea what the MJ shackle measurements are or what amount of lift they offer? I snagged mine from a mid 90s fullsize GM pickup because they're heavier built and add roughly 1.5in
Wm
post #12 of 15 Old 08-24-2008, 11:50 PM
Mr_Random
1986 XJ Cherokee
Wm
1.5" longer than the XJ shackle? I'm only basing that off of the 3/4" of lift you can supposedly get from them, you know; 1" = 1/2" of lift when it comes to shackles.
oh and I forgot to say that adding leafs shouldn't be too hard, doing it the "right" way would require finding a leaf spring bolt, but I just took some grade 8 bolts of the correct length, ground the sharp edges of the head a little, and torqued it down! Works perfectly, will never break, and fit right into the little hole on the spring perch, haha.
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline
post #13 of 15 Old 08-24-2008, 11:53 PM
CKUPQ
Here is my recommendation for bastard back. I did this with a 3 leaf pack w/overload. I am very happy with this setup and I didn't need spring retainers. I just bent the old retainers straight, drilled them after I got them back together and cut off the excess. I've seen people cut them off only to replace them with cheap sheet metal crap.
My stackup
XJ Main
S-10 3leaf pack main
S-10 3leaf pack Intermediate
S-10 3leaf pack small with retainers bent straight up and drilled for 5/16" cross bolts
XJ small Leaf
Either our language or our culture needs to be expanded/improved so that there is a polite way to say:
Stop talking now, because I am going to stop listening.
99 XJ 3" Rusty's coils DT3000 front shocks, 3" S-10 bastard back, Homemade T-case drop, recovery points front and rear.
CKUPQ is offline
post #14 of 15 Old 03-26-2009, 10:58 PM
XJoutlaw
saving this
XJoutlaw is offline
post #15 of 15 Old 12-05-2011, 02:05 AM
Ibnzmonkey
2002 KJ Liberty
Ibnzmonkey is offline
Is it possible to use YJ leafs as a bastard pack? Jameslol XJ Cherokee Technical Forum 1 05-12-2009 08:18 AM
MJ leafs for bastard pack 3fifty XJ Cherokee Technical Forum 1 02-01-2009 11:47 AM
Getting s10 leafs for $25. Bastard pack ahoy! keepishop XJ Cherokee Technical Forum 12 01-31-2009 08:36 AM
Bastard pack on slightly inverted stock rear leafs akxj01 XJ Cherokee Technical Forum 2 10-27-2008 09:35 PM
2000 explorer leafs work on my 89 bastard pack? broncofire75 XJ Cherokee Technical Forum 7 10-11-2007 11:13 PM
