3.5 RE lift start / stop vibrations - JeepForum.com
post #1 of 20 Old 11-30-2013, 02:51 PM Thread Starter
kaktus
After I installed my RE 3.5 lift with full leafs I started to get start and stop vibrations. I only have vibrations / low growling noise at around 5 mph than they go away. It's really annoying when I'm doing city driving. Its really loud in the cab.
So far I have:
-Installed SYE used front drive shaft from a XJ replaced all U JOINTS
-Installed 4 degree shim's did not work
-installed 4 degree shims with 1' inch transfer case drop
-tried 6 degree shims
-tried 6 degree shims with transfer case drop
-Replaced all fluids in diffs and transfer case/tranny
-Replaced transmission mount.
-Removed front driveshaft/ noise is defiantly coming from the rear.
The 3.5 RE full leafs I put on make my jeep sit high in the rear right now after finding my angles I need a 6" degree shim to be 1' degree under.
Any other idea's? I have a 8.25 rear diff this is on a 98 Cherokee without ABS
kaktus is offline
post #2 of 20 Old 11-30-2013, 03:50 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
6* of shim seems like an excessive amount for 3.5" of lift. If you have an SYE you do not need any amount of T-Case drop. Have you tried swapping the front and rear driveshafts ?
Where approximately, is this noise coming from ? Is your exhaust system touching anywhere ?
CJ7-Tim is offline
post #3 of 20 Old 11-30-2013, 03:55 PM
krawler510
I have a 2 shim on my 4.5 lift and it's buttery smooth. The pinion is a bit low so I'm switching to a 4 soon.
Drive shaft vibrations are usually very strongly felt, not a grind.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #4 of 20 Old 11-30-2013, 04:17 PM Thread Starter
kaktus
I thought 6* shim was aggressive to that's why I started with 4* shim. When I measure I'm about 1* down with 6* if I put 4* shim on I'm 3* degree down. Honestly I didn't feel a difference between 4* and 6* just 6* makes the driveshaft straighter towards transfer case. I can not put front drive shaft on as my SYE is flange style and my driveshaft needs to connect to a flange not a yoke and only my rear driveshaft is setup to do so. Yes I also thought I did not need a transfercase drop if I have a SYE but if I take transferscase drop off I start get vibes at 50+? So I know something's not right? I was getting ONLY low speed vibes before SYE as well so I installed SYE to try and get rid of the vibrations and nothing changed. Its a really low deep sound honestly it sounds like I have a subwoofer in my jeep than it instantly disappears when I go above 5 mph. It really sounds like it has to do something with the rear part of the jeep. I have brand new MT tires I have tried them at every air pressure possible but still no luck.
kaktus is offline
post #5 of 20 Old 11-30-2013, 04:24 PM
krawler510
3 down sounds good for leaf springs.
I wish we could hear/feel what you're describing.
post #6 of 20 Old 11-30-2013, 04:33 PM
CJ7-Tim
CJ7-Tim's Avatar
Me too.
MT's will growl/rumble at low speeds, but you feel it more than you hear it.
CJ7-Tim is offline
post #7 of 20 Old 11-30-2013, 04:38 PM Thread Starter
kaktus
It could very possibly be my MT's. This is my first time owning MT's so I guess I don't know what to expect. My MT are quite on the freeway just when I'm coming to a stop or taking off from a stop. Right around 5 mph I hear the noise and feel slight vibrations in my jeep. Its really just the noise the bothers me the most. If I take off quick and stop quick I don't hear it.
kaktus is offline
post #8 of 20 Old 12-02-2013, 08:06 PM
Modstock
Could you swap wheels/tires with someone that have At's for a day or two .
At least ya might be able to see if its those.
I have a noise kinda similar but its at 40mph. I did a axle swap from my YJ and the gears are set up one-thousants too tight (still in spec) . Didn't hear it while under the YJ but Im told unidodys are more sensitive to certain kind of vibrations/frequencys . So next spring im getting the rear rebuilt. I just ignor it for now.
Modstock is offline
post #9 of 20 Old 12-02-2013, 10:38 PM
M35A2
1995 XJ Cherokee
Try loosening the bolts for the rear shackles, then get a friend and yourself and bounce the rear of the truck by standing on the rear bumper and jumping on it. Re torque the shackle and see what happens.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #10 of 20 Old 01-02-2014, 12:30 PM Thread Starter
kaktus
Update: I bought a toms wood shaft. That fixed all my freeway vibrations and is extremely smooth now. Well worth the money. I was even able to take off my SYE. I still have this low speed/rumble when I start and stop. I tried shackle thing. Still no luck.
kaktus is offline
post #11 of 20 Old 01-02-2014, 07:33 PM
AmbuGrl
AmbuGrl's Avatar
You 'took off' your sye? Those are installed inside a transfer case... you sure?
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #12 of 20 Old 01-02-2014, 08:08 PM Thread Starter
kaktus
I took my Transfercase drop off lol. Not my SYE.
kaktus is offline
post #13 of 20 Old 01-02-2014, 09:08 PM
sAe23
1995 XJ Cherokee
Um, if it ain't broke, don't "fix" it ...
My KM2's cause a low speed ...grumble... kinda noise and a faint feeling like I'm driving on a cobble stone road.
If that's all you're feeling then you probably needn't worry about it.
sAe23 is offline
post #14 of 20 Old 01-03-2014, 02:02 AM
Timo_90xj
Timo_90xj's Avatar
IMO there is no way the 5mph rumble/ vibes are from your driveline. Apart from the engine/ tranny, the RPMs on the driveline (driveshafts, tires, axle shafts, etc.) you see at those speeds are so low you won't be getting vibes from them even if they were out of whack.
I'm guessing it's the MTs you're driving, or a resonation from somewhere (exhaust, etc.) that causes the annoying sound.
***Under construction***
Timo_90xj is offline
post #15 of 20 Old 01-03-2014, 07:12 AM
krawler510
I almost always agree with that but with a bad pinion angle I'm taking miles off the life of those U joints.
