3.5" lift with Cragar soft 8 - rubbing - JeepForum.com
post #1 of 5 Old 08-26-2012, 03:58 PM Thread Starter
TheOoz
1995 XJ Cherokee
I have a 1995 XJ with Cragar soft 8 wheels and metric tyres equivalent to 31". I have 3.5" of lift with 2" dropped bump stops and it appears that the tyres are rubbing on the flare mounting bolts (stock flares - the thread protruding on inner side of the guard).
Will trimming the threads down suffice, or do I need to change to aftermarket flares?
Any experience appreciated.
TheOoz is offline
post #2 of 5 Old 08-26-2012, 10:08 PM
Timo_90xj
Timo_90xj's Avatar
You do not specify the wheel width, backspacing nor the tire size. What tyre size exactly are you running?
***Under construction***
Timo_90xj is offline
post #3 of 5 Old 08-26-2012, 11:36 PM Thread Starter
TheOoz
1995 XJ Cherokee
4" backspacing, 16 x 7" wheel, tyres are 245/75/16
TheOoz is offline
post #4 of 5 Old 08-27-2012, 02:01 AM
Timo_90xj
Timo_90xj's Avatar
Shouldn't really rub with those tires on 3.5" lift and bumpstopped that much.. size is closer to 30 x 9.5 than a 31" high tire. Are they new, or regrooved budget tires (regrooved are usually much larger in diameter than advertised)?
Try trimming the mounting stud threads first. If that doesn't help then trim the sheetmetal, and move the flares higher up if the traffic laws there in Australia require them.
post #5 of 5 Old 08-27-2012, 01:45 PM Thread Starter
TheOoz
1995 XJ Cherokee
The tyres are Cooper ST. I'll have another look at full flex and see if I can see exactly what is touching.
TheOoz is offline
4" back space, cragar d-windows, enough back space for 31" tires, and 3" lift? Grip XJ Cherokee Technical Forum 10 02-06-2010 04:57 PM
Cragar soft 8 XscottJ XJ Cherokee Technical Forum 1 12-08-2008 06:37 PM
rubbing with factory wheels on 4" lift Hugger XJ Cherokee Technical Forum 7 10-26-2008 09:00 AM
3.5" lift kit, rear sway bar rubbing tires rosader XJ Cherokee Technical Forum 4 09-28-2006 09:36 AM
4.5" Lift 33" Tires, Will fit with no rubbing and be a daily driver? Iwantawrangler XJ Cherokee Technical Forum 8 05-09-2006 09:37 PM
