3/4 Ton Brakes on a Chrysler 8.25? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 3/4 Ton Brakes on a Chrysler 8.25?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHutMemorial Day Weekend Sale Starts Friday-Tuesday 10% off +
Unread 06-06-2011, 02:02 PM   #1
NHJeep4x4
Looking at disc brake conversions for D60s, can a similar method for disc brake conversion be done on an 8.25? In other words, is it possible to weld on caliper brackets and attach '75 Chevy 3/4 ton calipers?
4.0L Auto D60/14B, 4.10, spools, 3 link and leaves, 38s, homemade bumpers, Warn X8000i
Build Thread
NHJeep4x4 is offline   Reply With Quote
Unread 06-06-2011, 02:05 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Scroll to the bottom of this very page and also see the FAQ's ( http://www.jeepforum.com/forum/f11/t...ks-tsbs-89273/ ) to read up on disk brakes.
KJ Liberty brakes bolt on the 8.25, and ZJ and Ford Crown Vic or 8.8 disks are easy to adapt.
Any of the above will be easier to install and are guaranteed to work with 15-16" rims.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 06-06-2011, 03:27 PM   #3
justanotherjpr
I suppose as long as the caliper would fit in the wheel you could do this but you might have a hard time finding a rotor that is 5x4.5 that is big enough.
justanotherjpr is offline   Reply With Quote
