Quantcast 3-4 inch lift questions ?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 3-4 inch lift questions ??
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 11-03-2009, 02:35 PM   #1
taylorC
1997 XJ Cherokee
hey guys
im looking to make my jeep taller but i really dont have the money to buy an expensive lift kit. Currently I have a 2 inch budget boost from iron rock off road. im wondering if it would be possible to add another inch or two using the same type of spacers in the front and then by using a leaf spring lift block in the back.
also if i could do this without buying new shocks springs.
if this is way off can anybody show me were i could get a quality 3-4 inch lift kit en-expensively?
97 Cherokee sport-4x4/2"BB /Kumho AT's/ Hella 770ff
taylorC is offline   Reply With Quote
Old 11-03-2009, 03:05 PM   #2
deathstarxj
1994 XJ Cherokee
Well, i think almost everyone on here will tell you to definitely steer clear of blocks in the rear, my self included. Granted ive never had any experience with them, but still i wouldnt do it.. as for the front i wouldn't want to do too much more than 2 inches with spacers, but again, just my opinion. I know the popular choice in this area will always be rubicon express, its probably the best in quality and completeness but its just out of my price range, and it sounds like it might be out of yours as well. i would suggest Rusty's 3" with full leafs, and it comes with shocks so youre good there, i think i will be ordering that myself pretty soon, i have found it to be the best deal for the money, and most porple are very satisfied with Rusty's springs. there are tons of options for home made lifts around this hieght, you might try a search, because there are lots of threads about this stuff. Any way, this is all just my opinion on it, i know there are a lot of different ones out there on this, but i hope this helps
deathstarxj is offline   Reply With Quote
Old 11-03-2009, 03:14 PM   #3
SkinnyMe97
1997 XJ Cherokee
S-10 leafs and F-150 coils from the local pick & pull would be the cheapest , if you dont mind a rough ride.
SkinnyMe97 is offline   Reply With Quote
Old 11-03-2009, 03:31 PM   #4
taylorC
1997 XJ Cherokee
hmmmm
thats all i would have to replace? the leafs and coils?
no new shocks?
and that would put it up to 3"
Old 11-03-2009, 03:33 PM   #5
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
I think you should wait until you can afford to lift the jeep before lifting the jeep. For 4" of lift you need new lower control arms, adjustable trac-bar, longer shocks, longer swaybar endlinks or disconnects, longer brakelines, and likely a slip yoke eliminator and cv driveshaft. Stacking spacers for 4" of lift is dangerous, 3" is really too much in my opinion. I would just wait and save some money then do it right. There are ways to get 3" of lift on a budget, but you can't stack two budget boosts without adding all the other neccesary components.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 11-03-2009, 03:36 PM   #6
taylorC
1997 XJ Cherokee
I was looking at rusty's offroad and i saw this
Rustys Offroad: XJ Cherokee 3" Add-A-Leaf Kit
and i liked the price of it. what do you guys think of it?
Old 11-03-2009, 03:39 PM   #7
DC4W-93XJ
1990 XJ Cherokee
dont do the F150 coils.... that ruins your ride.... stick with coil pucks before you do that
THIS AIN'T YOUR MAMA'S STATION WAGON!!
Built Jeep Tough With Chevy Stuff
"Tater 2" '91 2 door XJ chopped and bobbed, 4.0, AW4, dana 300, GM 60/70HD, 40" IROKs on H1s
SEE THE BUILD HERE
DC4W-93XJ is offline   Reply With Quote
Old 11-03-2009, 03:42 PM   #8
SkinnyMe97
1997 XJ Cherokee
Like XJfever said there is alot to consider when liffting any vehicle . I'm sorry if you missunderstood my previous post. Even a "complete" lift kit will not have all the necessary components to do it right . Do your research , decide what you want then buy pieces as you can until you have everything you need .
Old 11-03-2009, 03:45 PM   #9
DC4W-93XJ
1990 XJ Cherokee
even though the "nice" kits are a little more expensive... i think it comes out to be cheaper in the long run.. my frist XJ had about 5 or 6 different lift setups on it..
save up an buy a nice long arm kit.. such as the BDS true four link kit
SEE THE BUILD HERE
Old 11-03-2009, 03:55 PM   #10
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
That kit is fine for 3" of lift. You may need to redrill the axle mounting hole for the trac-bar to center the axle under the jeep. And I would suggest adding to the rear bumpstops to keep from inverting the leafs, this will help the AAL to last longer. You don't have to redrill the trac-bar mount but if you don't the axle will be pulled toward the drivers side by 3/4" or so. And you will need the front-end aligned after the lift, but you can do that yourself. http://www.4x4xplor.com/alignment.html
Old 11-12-2009, 08:11 PM   #11
ScorpionsXJ
Dont let money be an issue if you have any second thoughts just go bigger
*RE 3.5 Super Flex* 31x10.5 BFG KM2* Crager Street Locks* TeraFlex Track Bar* JCR Rear Bumper
ScorpionsXJ is offline   Reply With Quote
Old 11-12-2009, 10:35 PM   #12
ELEVATIONOFFRD
what i did with mine was went to fastenal and got a 4" washer with a 2" hole in the middle of it for the bump stops and welded a piece of 4" tube to the end and then put it in between my coil and the body on the front for a 4" lift and in the rear i did a bastard pack using the stock top leaf and the stock bottom leaf i sandwiched over a set of leaf springs from a chevy s15 blazer it gave me about 4" lift in the rear I think if I would only put 1 of the s15 leafs in there if i did it again because it is a little stiff in the rear but i have trailed it for about 2 years now with no prolems just a little clanking in the front from the control arms but thats because i havent lengthend my track bar i think total it cost me $27 buck the washers were 5 and the leaves were 22 thats with 50% off at u-pull-it in oregon
ELEVATIONOFFRD is offline   Reply With Quote
Old 11-13-2009, 05:03 PM   #13
taylorC
1997 XJ Cherokee
any pictures from installation?
and do you have pics of the finished project?
does death wobble occur? did you upgrade springs,shocks,etc?
sorry for the 20 Q's.
Glock Forum
