2WD transmission tail shaft leak - JeepForum.com
post #1 of 6 Old 08-24-2009, 11:28 AM Thread Starter
sebastian22
Spent some time under the XJ this weekend (99, 4.0, Auto, 2wd) and noticed that the tail shaft seal is leaking. (I think that's what its called, where the driveshaft goes into the transmission).
Any advice on how I can fix this. Is it as simple as pulling drive shaft, replacing the seal, and putting DS back in?
Also anyone have any info (write-up) on how to service the automatic transmission (fluid change).
thanks for any help.
95 Black YJ
sebastian22 is offline
post #2 of 6 Old 08-24-2009, 12:12 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
As far as the output shaft seal, yes it really is that easy. Make sure to lube the sealing surface of the new seal before reinstalling the driveshaft.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 6 Old 12-01-2009, 01:59 PM Thread Starter
sebastian22
I think Ive procrastinated long enough... Anyone know where i can get this stupid seal?
Parts stores dont seem to have it and I'm afraid to go to the dealer.
95 Black YJ
post #4 of 6 Old 12-01-2009, 03:10 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Try www.rockauto.com for the best prices.
Max
Mean Max is offline
post #5 of 6 Old 12-02-2009, 06:58 AM
rjfster
theyre really easy to change, pull the shaft out, pry out the old seal, then tap the new one in with an oversized socket or something. As far as purchasing one, I ran into the same problem, but Napa seems to always have them in stock, if not they can get them within a day or 2.
rjfster is offline
post #6 of 6 Old 12-02-2009, 08:19 AM
rpriore
There is also a brass bushing in there that could be causing the leak, I had the seal replaced first but the leak is still there and I found out it is that bushing that is worn. Do not call the dealer about the bushing because they do not sell it, they will tell you that whole tailshaft housing needs to be replaced and it costs an arm and a leg. A transmission shop can press that bushing out and press it back in for a small fee. I still need to get it done on my 2000 2wd, I was quoted $150.
rpriore is offline
Manual transmission leak and differential leak bbal XJ Cherokee Technical Forum 3 10-11-2009 01:59 PM
Passenger Wheel Wobble and Shaft Leak beaver24 XJ Cherokee Technical Forum 5 07-18-2009 11:41 AM
where can i get a new x-fer tail shaft? XJ96PA XJ Cherokee Technical Forum 2 05-11-2008 10:00 AM
Tail shaft seal + cone from a 99 on an 89 B-mac XJ Cherokee Technical Forum 5 04-13-2006 01:59 PM
Front Axle Shaft seal leak dcuballa XJ Cherokee Technical Forum 2 03-02-2006 09:25 PM
