Quantcast 2006 Cherokee of the Year **Modified Class** vote here - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 2006 Cherokee of the Year **Modified Class** vote here
View Poll Results: vote for the 2006 Cherokee of the Year **Modified Class**
Fullsizexj 44 18.33%
extankerguy 9 3.75%
HeavyMetal 31 12.92%
Jeepernick 2 0.83%
BlueGerbil 63 26.25%
Twisted 30 12.50%
Ex CCS Racer 8 3.33%
boise49ers 5 2.08%
COJeepin 19 7.92%
XJ_Jeeper01 0 0%
commandtoad 18 7.50%
GottaBeJeep 11 4.58%
Voters: 240. You may not vote on this poll
Old 12-10-2006, 07:51 PM   #1
EricsXJ
The Post man
EricsXJ's Avatar
Fullsizexj (January)
1989 Jeep Cherokee
16" Sway-Away Duel Rate Remote Resevoir Coil-Over Shocks With Eibach Springs On All 4 Corners
Mid arm 4-Link front Suspension
Wishbone 3-Link Rear Suspension
Dana 60 Reverse Cut Kingpin Front Axle
With Detroit Locker and 5:38 gears with 35 Spline Axles
Full Floating Dana 60 Rear Axle 35 Spline Superior Evolution series Chromo Axles and Loc-Rite Locker with 5:38 gears
NP231 Transfer Case with Advance Adapters Heavy Duty SYE Kit
Tom Woods Drive Shafts Front And Rear
40 x 13.5 x17" Good Year MTR's
Trail Ready Beadlocks
Full Hydro Steering
EXO Cage
extankerguy (February)
'87 XJ Wagoneer
4.0 litre 6 cylinder w/340,000 miles
AW4 Transmission
NP242 Transfer Case
33x10.50 BFG Mud Terrains
TJ Canyon Wheels
4.5" lift (Rusty's 3" lift with 1.75" spacer up front)
DPG adjustable rear bumpstops
YJ brake lines
Rusty's adjustable lower control arms
Rusty's adjustable upper control arms
Custom transfer case skid
Custom rocker protection
Rusty's adjustable track bar
ARB air compressor
ARB front locker
ARB rear locker
Dana 30 front axle w/4.56 gears
Dana 44 rear axle w/4.56 gears
K&N open element air filter
Flowmaster 50 series muffler
Draw-Tite front receiver hitch
Hidden Hitch rear receiver hitch
receiver shackle mounts
30,000 lb recovery strap
Hi-lift jack
Panasonic CD/MP3 player
Uniden CB w/weather radio
fire extinguisher
first aid kit
Trail Rated Badge
Rock Rash
HeavyMetal (March)
1997 Cherokee
RE 4.5"
d30/d44 4.56 gears, powertrax no-slip locker in rear, aussie locker in the d30
33x10.5 BFG MTs, 3.25" Backspacing
T-case & Engine/Tranny/Oil Pan Skid
Rocklizard Gas Tank skid
JCR Stage 2 Sliders
Full PMW Side Armor Plate
Custom Fab Front Recovery bumper
Hella Rallye 4000 lights
Jeepernick (April)
1991 Jeep Cherokee
1996 4.0L I-6 w/ 50,000 Miles
1997 AW-4 Transmission w/ 75,000 Miles
Laredo Edition
DynoMax Exhaust (no CAT)
Rubicon Express 4.5inch Lift with Heavy Duty Trac-Bar
Custom Intake K&N
Custom Roof Rack
Custom Front Bumper (w/ bolt on chrome hooks)
35x12.5x15 GoodYear MTRs on RockKrawlers w/ 3.75"BS
D-30 front LockRight Locker
D-35 Limited slip (D44 will be in after the new year)
All the recovery gear needed, straps, 60" HI Lift, Shovel... ect
Air
KenWood Deck
Infinity 5 1/4" Speakers
CB Radio
Rusty's LED Tail Light Mod
EricsXJ is offline   Reply With Quote
Old 12-10-2006, 07:54 PM   #2
EricsXJ
The Post man
EricsXJ's Avatar
BlueGerbil (May)
- RubiconExpress 7.5" TJ coils
- RubiconExpress 5.5" XD leafs
- Rusty 1.75" shakles
- Rusty Heavy Duty Adjustable Trac-Bar and Frame Mount
- RubiconExpress SuperFlex lower control arms, long arms in the works
- Rusty upper control arms
- Rusty steering box brace
- OME steering stabilizer
- BFG MT 35x12.5 on AR767 8x15 rims
- Bilstein 5150 shocks, 12"
- Tom Woods driveshaft & SYE
- Dana 30 (HP, Detroit Locker, Warn axles, 4.56 ratio, 1.25" wheel spacer)
- Ford 8.8 (31 spline, Detroit Locker, 4.56 ratio, 1.25" wheel spacer, Super88 Kit in the works)
- ARB front bumper with modified mounting and integrated steering box reinforcment
- Kaymar rear bumper with spare tire, jerry can carrier, work light, relocated license plate holder and a shakle receiver
- clear turning signals and side markers
- clear turning signals in ARB bumper w/ parking light
- Hella Rallye 4000 HID lights
- PIAA 1900x fog lights
- Warn 9.5 XP winch
- Mopar front skid
- Mopar tank skid
- Rusty transfer case skid
- Optima BlueTop 5.5 in custom mount, dual battery system in the works
- Safari Snorkel
- JKS Quick Disconnects
- BushWhacker fender flares
- Twister XL cone air filter
- MeanGreen 160A alternator w/ custom cabling
- Alpine sound system
- Hannibal roof rack with camping table
- Maggiolina roof tent
- Garmin GPSMAP 278 w/ 2GB memory and marine mounting system, external antenna in the works
- Husky liners
- Hood scoops, custom hood in the works
- High flow thermostat
- Cupholder
- stainless steel brake lines
- Scheelmann seats w/ mounting for fire ext. and MagLite
- Osram UltraBright H4 bulbs
- Rustys engine mounts
- 2 Mopar storage boxes in the rear
- front and rear headlight protection
- Rustys steering box brace
- relocated vacuum canister, horn, and winch relay
- 51l LongRanger auxilliary fuel tank
- Mopar stainless steel headers
- Raptor muffler
Twisted (June)
1997 Cherokee - 4.0HO, AW4, NP231 (purchased bone stock in May 2005)
Suspension:
RE 3.5" leaf packs
Added a Dakota leaf to the rear
RE 1.25" shackle
RE 4.5" coils up front
Daystar 1.75" poly spacer
RE adjustable trackbar
RE UCA and LCA
RE CA drop brackets and braces
RE extended SS brake lines
Doestch Tech shocks
RE Gen2 quick discos
Drivetrain/Powertrain:
K&N drop in filter
Magnaflow exhaust with hi flow cat
RE HnT SYE
Modified front driveshaft in the rear
Yukon 4.56 gears front and rear
Lockrite locker in front D30
Full Detroit locker in rear 8.25
Recovery:
Drawtite front hitch
EZ Lift rear hitch
Hi Lift Jack and assortment of straps, chains, and come alongs.
Lighting:
Hella H4 headlight housings
Hella 85/115w H4 headlight bulbs
Homebrew heavy duty headlight harness
Hella 500 amber fogs w/ homebrew heavy duty harness
4 Wal-mart special roof lights
Other:
33x12.50x15 Trxus MT tires
15x8 Cragar Soft 8 wheels
Lebaron Hood Vents
Cut front bumper
Trimmed fenders and reattached stock flares
Pioneer CD player, Rockford amps, Rockford sub
Garmin GPS with mapping
Cobra 75 CB
Remote start
Yakima gutter mounts and cross bars
Husky liner floor mats
Fire extnguisher
First aid kit
Surco Rack
Fitch inspired switchbox
AJ's Super Rails
Laptop based GPS with Holux GR-213 reciever
Ex CCS Racer (July)
1998 Cherokee SE
Rusty's 4.5" leaf pack lift
Rusty's HD track bar
1.75" front spacers
Rusty's rear bumpstops
Pacer 15x8 wheels with 3.75" bs
BFG 33x12.5 MT's
ARB front bumper
C-rok rear bumper
Tomken sliders
Lock-rite front locker
Powertrax rear locker
29 spl 8.25 swapped in
ZJ tie-rod
Tabor 9k winch
Kenwood CD player
Cobra CB
Tinted windows
Removed front and rear swaybars
LOTS of trimming
boise49ers (August)
1988 Jeep XJ Cherokee (Pioneer)
"Engine, Trans,TC"
Fresh 4.0: in-line 6
( K&N ) ( Banks headers ) ( flowmaster)
( HiFlow cat ) ( 3 Row CSF Radiator)
AW4: 4 speed auto trans
N231: Command Trac
"Suspension"
Front
(4" Trailmaster Coils)
(Trailmaster Drop Brackets shaved)
( TeraFlex Adjustable LCAs)
(2" Spacers )
(5.5" Total Lift)
(5" Daystar bumpstops)
( Rancho 5000 )
(C-Rok steering reinforcing)
(JKS style HD Tie Rod & Moog Ends)
(YJ brakelines)
Rear
( 2.5" Performance ***. shackles)
( 2" BDS add a leaf & 1" Block/Shim)
(5.5" Total Lift)
(Added 2" to bumpstops)
( Pro-Comp shocks )
(YJ Brakeline)
" Assessories, Armor & Recovery"
Safari Rack
( w/Hella lamps )
Rear Rock bumper
Warn Front bumper
( w/8000 lb Ramsey winch )
Rigidco Rock Rails
BDS Front Diff Guard
Home Fabbed Rear Rocker Guards
Home Fabbed Rear 1/4 Armour
(Assorted Recovery Equipment)
(Hi-lift on Receiver Mount)
(Shovel, Tools, First aid)
(Masterflow Air Compressor)
" Sound "
JVC 180 watt CD/CD-RW/MP3/WMA
( Infinity Front & Rear )
JBL 300 watt amp
(Infinity 1030W 10" Sub)
(bandpass enclosure)
Uniden CB
" Tires & Wheels "
34"x 10.5"x 15" Bias Ply
(LTB Super Swampers)
15" x 7" Wheels 3 11/16" bs
( Ultra "Rock Rash" 62 Alloy)
" Axles & Gears"
4.56 to 1
" Rear" Shaved Dana 44
(Detroit Locker)
"Front" Hi-Pinion Dana 30
(Aussie locker)
Old 12-10-2006, 07:55 PM   #3
EricsXJ
The Post man
EricsXJ's Avatar
COJeepin (September)
Jeep 2001 XJ Sport
- Ford 8.8 Rear axle with ARB and Superlift diff skid (2.5" spacers (until I swap in a wider axle))
- Currie Hi-Pinion 9” front axle (5” wider than stock axle width) with flat-top knuckles, chromoly inners and outer axles, 4.88 gears, ¾ ton Chevrolet disc brakes, ARB locker and WARN premium manual hubs
- Custom cross over steering with hydro assist
- Express 7.5” long arm lift with Bilstein shocks
- 35x12.5R15 TrXus Mud Terrains mounted on black steel 15x8 rims with a 3.75” back spacing
- TNT Customs front tube bumper and unibody stiffeners
- TNT Customs steering box brace
- Rock Hard 4x4 internal roll cage tied in to the unibody stiffeners
- Warn XD9000I winch
- Custom 4x4 Fabrication rear bumper with tire carrier (4" higher than their stock carrier)
- Rocky Road rocker rails (tied into unibody stiffners)
- Stock gas tank skids
- CO2 tank
- Bushwhacker flares (now modified to allow better wheel clearance)
- Atlas 4-spd transfer case (1:1, 2:1, 2.72:1 & 5.44:1 ratios)
- KC 150watt off-road driving lights
XJ_Jeeper01 (October)
2001 Cherokee Sport
Suspension:
Rubicon Express 3.5" Kit with 1.75" Spacers and Shackles
RE Adjustable Track Bar
RE Gen II Discos
RE Monotube Shocks
Rock Krawler 3-Link Longarm Kit
Stock Steering with Old Man Emu Stabilizer
Drivetrain:
Stock 4.0 with Airaid Intake
Gibson Exhaust
Dana30/ 29 spline Chrysler 8.25 with stock 3.55 gearing
Advanced Adapters SYE and C.V. Driveshaft
Wheels and Tires:
33x12.50" BFG Mud Terrains on 15x8" American Racing Outlaw II Wheels
with
3.75" Backspacing
Armor:
C4x4 Front Winch Bumper
C4x4 Rear Bumper with Tire Carrier
Misc:
Trimmed Fenders with Stock Flares Trimmed and Relocated up front
commandtoad (November)
89' xj limited
4.6l stroker, AW4 tranny, 231 x-fer case.
D-30 front w/ 4340 TJ shafts, 4.10 gears and a lock-rite.
ford 8.8 rear, 4.10 gear, ESAB locker, skid plates and a fat cover
4" lift, 33 10.50 and 33 13.50 swampers.
HD track bar and tie rod.
home made bumpers.
on board air.
warn XD 9000 winch.
custom "high clearance" rockers
one auto zone fog light and a CD player that won't play CD's
GottaBeJeep (December)
1998 Classic
Engine/Drivetrain/Wheels and tires:
4.0L
AW4
231 w/ RE Hack and Tap SYE and RE CV Driveshaft
2.5" Exhaust with MagnaFlow HighFlow Cat and 12" long Glass Pack
HPD30, 4:88's, Aussie locker
Ford 8.8, disc brakes, 4:88's, Aussie locker
35x12.5 GoodYear MT/R's
15x10 AR Bajas with 3.5" Backspacing and a lot of rock rash
Suspension:
5" Lift (Rubicon Express Super Flex Adjustable short arms, Control Arm Drop Brackets/Braces, RE 3.5" ZJ coils, RE 4.5" leaf packs, stock shackles)
TNT Customs HD Trackbar and Bracket
OME LT shocks
JKS discos
Custom HD tie rod with 3/4 ton Dodge TRE's
YJ brakelines
Lots of bumpstop
Armor:
Rock Lizard Fab Rock Monitor Front Bumper
Rock Lizard Fab Super Skink Sliders
Rock Lizard Fab Tortoise Gas Tank Skid
Rock Lizard Fab Gila Monster Upper and Lower Quarter Guards
Rock Lizard Fab custom rear hitch tire carrier
Rock Lizard Fab custom TCase skid
Misc:
Rock Lizard Fab Gecko A-Pillar Light Mounts w/ IPF 968 lights
Rock Lizard Fab Gecko CB Mount with Unidon Pro510XL
Rock Lizard Fab Custom Gila Monster Guard CB Antenna Mount w/ 4' Wilson Fiberglass Whip Antenna
Fenders trimmed and finished with Proteko-Trim 5/8" Black Band Molding
Lots of stock roof rack bars
B&M transmission cooler
Old 12-10-2006, 07:55 PM   #4
EricsXJ
The Post man
EricsXJ's Avatar
PRIZES
The winner will receive the following:
- signed copy of High-Performance Jeep Cherokee XJ Builder's Guide
- $100 gift certificate toward any Rock Lizard "Exclusive" product compliments of GottaBeJeep. (Does not apply toward any other company's product that he is a distributor of.)
And last but not least, the winner gets the prestigious honor of being the first ever JeepForum 2006 "Cherokee of the Year"!
Good Luck!
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
Old 12-10-2006, 08:22 PM   #5
olds442
wow this one is gonna be hard...hmmmm i just dont know.....
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
olds442 is offline   Reply With Quote
Old 12-10-2006, 09:15 PM   #6
Twisted
Man, there are some very capable rigs up there. I feel like an underdog here cause mine isn't built to be a hardcore rig, just a very capable daily driver. Something that won't get stopped by any natural disaster or crappy weather. But thats ok, someday I'm gonna build a buggy.
Good luck to everyone up there. We've got some quality XJ's on here.
[size=1][URL=http://www.twisted-productions.com][B]Twisted Productions[/B] [/URL] - My photography and web design
[U]My vehicles[/U]
97 Cherokee: 4.0, RE Lift, 33" Trxus MT's, Yukon 4.56's, and locked front and rear...
87 Mazda Extra cab p/u: 2.5" body drop and full air ride
99 Honda Civic SI: Electron Blue Pearl - [color=red]Sold[/color][/size]
Twisted is offline   Reply With Quote
Old 12-10-2006, 10:00 PM   #7
gregmondro
I'd like to see what a d30/d35 running 35s with a 4.5" rubicon express kit beat out to win that month in the modified class here on Jeepforum.... lol.
best of luck to everyone
99 Jeep XJ - NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
FiveZeroFive
XJ 8.25 Rear End Disc Brake Conversion For Sale!
gregmondro is offline   Reply With Quote
Old 12-10-2006, 10:19 PM   #8
EricsXJ
The Post man
EricsXJ's Avatar
April COM.........
Eric
Old 12-11-2006, 01:05 AM   #9
Jeepernick
2008 XJ Cherokee
You got my Vote GOOD LUCK BUDDY
Jeepernick is offline   Reply With Quote
Old 12-11-2006, 01:06 AM   #10
Jeepernick
2008 XJ Cherokee
That isnt very nice
Give me a year and I will come and park my Heep on ur pile
OH and btw, I dont even see ur rig in the bunch
Old 12-11-2006, 08:34 AM   #11
HeavyMetal
Forum God
HeavyMetal's Avatar
1997 XJ Cherokee
i think its time to start praying to the forum gods
Though I wheel through the valley of the shadow of death,
I will fear no evil: For thou lockers are with me;
Thy lift and thy tires, they comfort me.
Thou preparest a spotter before me in the presence of mine obstacles;
HeavyMetal is offline   Reply With Quote
Old 12-11-2006, 02:45 PM   #12
BlueGerbil
Wow, I haven´t seen Fullsizexj´s rig before...
BlueGerbil
| Our 3 XJs | My weblog |
BlueGerbil is offline   Reply With Quote
Old 12-11-2006, 03:13 PM   #13
tennis203
Yea... His is like the best ever.
89 XJ 4.0, NP231, D44/Ford9, Detroit F&R, Yukon Shafts F&R, 4.56's, 5.5" lift, 37x13.5R15 Radial Claws, ArMoR Front/Rear/Side
99 Dub Ya Jay Limited Daily Driver
tennis203 is offline   Reply With Quote
Old 12-11-2006, 03:56 PM   #14
creature
You should see the updated pics, I don't think it's supposed to be done for a while but you can see the man has some plans.
-Shawn
creature is offline   Reply With Quote
Old 12-11-2006, 04:37 PM   #15
Jeepernick
2008 XJ Cherokee
THE BEST EVER?
is heep is in sheets now
updated pictures of his are kinda hard to get a hold of even from him, what you going to take a picture of his ego cage
Glock Forum
