2004 Jeep Cherokee Coolant Leak w/ (Video) - JeepForum.com
post #1 of 10 Old 04-16-2012, 12:01 PM Thread Starter
slindsey3000
2004 FSJ Cherokee
Hi all!
[EDIT] OK... see my replay about 8 down... How much will this cost to do??? [EDIT]
[Original]
Love my jeep and this forum! Can anyone help with what might be going on here and
how it needs to be fixed?
I have been topping off coolant for a few years, seems like there has always been some kind of SLOW leak... now however the leak is very noticeable.
Here is video.
Anyone have any ideas?
Thanks so much!
Shawn
slindsey3000 is offline
post #2 of 10 Old 04-16-2012, 12:08 PM
blue96jeep
well in order for you to pinpoint the leak you need to pressure test the system. But by judging where it leaking from I'm going to guess its the water pump.
blue96jeep is offline
post #3 of 10 Old 04-16-2012, 01:12 PM
chiefbill1959
Agree, waterpump. I have just gone thru my whole cooling system and replaced everything but the heater core. I didn't just throw money at it, I checked everything out and being as the Jeep has 215,xxx, I was having some overheating issues and did have some leaks. In fact I had to replace 4 out of the 5 freeze out plugs on the side of the block. But do some testing as blue96jeep said. Looking at it can be difficult to actually see it leaking but from where it is dripping I would go with the water pump too.
96 XJ, 3 in. Rustys full pack lift, 4.0, AW4, D35, C8.25
86 XJ, 3 in. RC, bb rear pack, 3.4 L engine
chiefbill1959 is offline
post #4 of 10 Old 04-16-2012, 01:26 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Looks like the pump to me also, but I would get in there with a good light and make sure. If it is coming from the weep hole in the bottom of the waterpump it won't last much longer. It would be best to swap it out before it goes out and leaves you stranded with an overheated engine.
xjfever is offline
post #5 of 10 Old 04-16-2012, 02:17 PM
Azzy
Shawn...
Looks like a water pump to me. I would get ready to do the full cooling system and fan clutch while you are at it. Not too pricey fi you do it yourself, and its a simple job with standard tools.
BTW, thats a Grand Cherokee... wrong forums. But welcome to the boards!
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #6 of 10 Old 04-16-2012, 02:19 PM
djb383
The t-stat is almost in the way of changing the water pump.....why not change them both.....I mean it does run down hill, no? Coolant leaks r not to be neglected.
djb383 is offline
post #7 of 10 Old 04-16-2012, 04:17 PM
chiefbill1959
Like Azzy said, go ahead and do as much as the $$$ will let you do, but atleast the pump and thermostat. They are right there together and as they said, it is not that hard to do at all.
post #8 of 10 Old 04-16-2012, 05:31 PM
Azzy
And your radiator and hoses, probably original, will be in teh next round of "look ma! I'm a sprinkler!"
Azzy is offline
post #9 of 10 Old 04-23-2012, 06:43 PM Thread Starter
slindsey3000
2004 FSJ Cherokee
OK wow thanks for the answers. You all seem to agree!
How much will a shop charge to do this work? Give me your best guess to change the water pump, hoses, and thermostat?
Just a ballpark figure would be great... assume nothing crazy turns up... just what is talked about here.
Thanks!
Shawn
post #10 of 10 Old 04-23-2012, 09:53 PM
Azzy
Dunno... Probably too much. If you take your time with basic hand tools, you are looking at probably $200 in parts and fluid to do it yourself.
I can pull a rad and pump, and reverse in 2 hours, but I've done it a few times.
Azzy is offline
2004 , cherokee , coolant , jeep , leak
94 Jeep Grand Laredo (5.2L V8) coolant leak rayraychapman XJ Cherokee Technical Forum 1 11-04-2010 10:18 AM
Dismal Defrost & Coolant Leak? - '99 Cherokee UNHCLL XJ Cherokee Technical Forum 4 12-09-2009 05:59 PM
coolant leak but cannot find lost coolant Jhatke XJ Cherokee Technical Forum 12 03-21-2009 06:54 PM
Jeep Coolant Leak XJAl XJ Cherokee Technical Forum 9 07-05-2008 05:33 PM
New 2004 Jeep Cherokee Extreme Sport Chrisca XJ Cherokee Technical Forum 11 11-10-2004 08:46 PM
