2001 XJ Transmission Cooler Options - JeepForum.com
post #1 of 5 Old 11-25-2012, 08:58 PM Thread Starter
who_datjeep
I would like to get a transmission cooler for my vehicle. It appears that when you have transmission oil that is at a lower temperature the transmission will last longer. I am pretty sure my transmission gets pretty hot because I can even feel the heat through the floor and on the shift lever handle (the metal part). What are the recommendations for a good transmission cooler at a good price with high quality? Also how easy will it be to install?
who_datjeep is offline
post #2 of 5 Old 11-25-2012, 08:58 PM Thread Starter
who_datjeep
My transmission is an AW4.
post #3 of 5 Old 11-25-2012, 09:05 PM
djb383
I've mounted a B&M #70264 auxiliary cooler to numerous vehicles including the XJ. I mount them in-line with and after the factory rad cooler.
djb383 is offline
post #4 of 5 Old 11-25-2012, 09:11 PM Thread Starter
who_datjeep
How easy are they to install?
post #5 of 5 Old 11-26-2012, 08:51 AM
DNFJ
They're very easy to install. It's literally a total two lines, as you should have the stock (radiator) cooler and the aux cooler run in parallel.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
cherokee , cooler , oil , options , transmission
