-   -   2001 XJ Step/Courtesy Lights (http://www.jeepforum.com/forum/f11/2001-xj-step-courtesy-lights-1529013/)
toothraptor 05-27-2013 08:40 PM
New to this forum,
I have recently swapped out my stock dome lights for white LED's and had no problem doing so. After scouring the web I cannot however find the correct LED's or even regular bulbs for the step lights under the dash on the right and left sides. Anybody know what bulb number they are? Everywhere I look has a wedge LED but that is not the case, its a round connection on the bottom. I have a 2001 Cherokee limited. Any advice would be great!
Thanks!
-toothraptor
lazyxj 05-28-2013 12:13 AM
My 2001 Owner's manual shows a #168 bulb for the "Underpanel Courtesy Lamps" - 2 required.
Lets us know what you find and, if available, color temperature of the lamp.
I dislike the blueish 6000K bulbs, preferring something in the 4000k range.
I have run my battery down leaving a door open more than once. Interior LEDs would be helpful in preventing dead batteries. We all need to use interior lights on, at times, when the engine isn't running.
I added a switch that shuts off the lights, when the doors are open.
The interior lights can still be turned on normally using the headlight switch. It's left in the 'off' position most of the time.
squirlgod 05-28-2013 10:19 AM
You can always just tap into those wires and put some of those cheap LED strips under there. I have seen plenty of people do this with nice results. Some even pick different colors then the white....I'm sure someone will chime in with pictures of this if your interested
toothraptor 06-03-2013 09:04 PM
No luck
Still having trouble looking for the right LED. The strips would look pretty cool, I'm going to put some in. Thanks for the advice!
The time now is 12:01 AM.
