2001 XJ Factory Fog Lights Not Working - Page 2 - JeepForum.com
post #16 of 18 Old 01-10-2013, 10:05 PM
NOTNSUV
You know the fog lights only have power on low beam headlights correct? So they will be off if you're on Hi beam
NOTNSUV is offline
post #17 of 18 Old 01-10-2013, 10:25 PM
95_xj_country
1995 XJ Cherokee
Yeah I know. Was your switch on or off when you blew the fuse? Were the headlights on? Im confused as to why you asked me that question. The high beam relay should be good if you have power at the lights.
95_xj_country is offline
post #18 of 18 Old 01-15-2013, 06:03 PM
bobbo_xj
Seriously think of replacing both lamp assemblies. I found a quality pair of replacements off of amazon for $50-60. If u buy replacements, just remember to salvage your working bulbs u put into the existing lamps,lol.
Old housings are usually not great in terms of reflective material and corrosion. And the access seals can leak over time. New housings make bright white light. Old ones are tinted on the yellowish side. New ones make the front of jeep look fresh.
2001 XJ Sport, 173k mi.
bobbo_xj is offline
bulb , cherokee , fog , fog light switch
