2001 XJ Factory Fog Lights Not Working - JeepForum.com
post #1 of 18 Old 01-09-2013, 10:42 AM Thread Starter
who_datjeep
I've looked around this forum and a whole bunch of others and all the solutions I have tried weren't any good. I have cleaned the switch of any corrosion so that is out of the equation. Also, the relays and fuse for the fog lights are good. I did notice when I opened the bottom of the fog light that there was one blue wire that was connected to the bulb and another black one that a rusted out connector. I tried connecting the bulb to both of the wires and nothing happened. Any help with this?
who_datjeep is offline
post #2 of 18 Old 01-09-2013, 10:51 AM
bigbill888
Are bulbs good?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #3 of 18 Old 01-09-2013, 10:53 AM Thread Starter
who_datjeep
Yes. I just bought new ones to make sure that wasn't the problem.
post #4 of 18 Old 01-09-2013, 11:48 AM Thread Starter
who_datjeep
So what might the problem be?
post #5 of 18 Old 01-09-2013, 02:56 PM
RedRyderXJ
1994 XJ Cherokee
Are you getting voltage to the lights? Switch work?
RedRyderXJ is offline
post #6 of 18 Old 01-09-2013, 04:03 PM Thread Starter
who_datjeep
Switch works and I know there is power between one of the two wires because when I contacted both wires with the contact on the light bulb it made a spark at the contact and the bulb started to glow and went out.
post #7 of 18 Old 01-09-2013, 04:04 PM
Dwatts5250
1997 XJ Cherokee
You can clean the corrosion out of the switch, but it can still fail. (I went nuts with this on my Wrangler, cleaned all the corrosion out with a wire brush, it turned out to be the switch), also, trace the wires from end to end, I had one ground out on another lead shorted the darn things out.
Good luck
"A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America' for an amount of up to and including my life. That is Honor, and there are way too many people in this country who no longer understand it."
Dwatts5250 is offline
post #8 of 18 Old 01-09-2013, 04:29 PM Thread Starter
who_datjeep
Seems like the next thing I have to do. Thanks.
post #9 of 18 Old 01-09-2013, 05:09 PM Thread Starter
who_datjeep
There do not appear to be any shorts. Any other solutions? What is the second spade connector for? It has black insulation and has some rusted up piece of metal in it. Is that ground or the original connector? Is the cleaner looking blue wire new or extra?
post #10 of 18 Old 01-09-2013, 06:00 PM
NOTNSUV
Odds are the black connector ground is your problem. If I'm not mistaken the blue wire goes to your low beam power so the fogs turn off when highbeams are activated. Ground is probably the most common problem with any wiring issues.
NOTNSUV is offline
post #11 of 18 Old 01-09-2013, 06:34 PM Thread Starter
who_datjeep
How do I ground the black wire? I accidentally touched the two wires together and I blew a fuse. It is getting very foggy here right now....
post #12 of 18 Old 01-09-2013, 06:44 PM
NOTNSUV
By touching the two wires you grounded 12 V which will pop a fuse every time. Find a place to screw the black wire to the frame or chassis or a clean spot on the body no paint, no rust .. a nice clean spot. there are existing holes in front Behind the bumper
NOTNSUV is offline
post #13 of 18 Old 01-10-2013, 07:27 PM
95_xj_country
1995 XJ Cherokee
do you have a multimeter?
95_xj_country is offline
post #14 of 18 Old 01-10-2013, 08:55 PM Thread Starter
who_datjeep
no but I know there is power. It sparked and blew my fuse.
post #15 of 18 Old 01-10-2013, 09:51 PM
95_xj_country
1995 XJ Cherokee
I would clean the ground. If you know there's power at the lights it could be the connectors for the light bulbs. Or any connector after the lights.
bulb , cherokee , fog , fog light switch
