2001 XJ boys.... - JeepForum.com
post #1 of 9 Old 07-07-2005, 03:54 PM Thread Starter
FlippinJeeps12
Exclamation 2001 XJ boys....
I have made the decision that it is time to lift my Jeep. I bought the XJ back in January and I have seen everyone else's jeeps around and i wanna lift it...ive been wheelin with my buddies. I would like to run 35's but im not sure what combination of stuff to get....can you guys with 35's help me out and tell me what you have with ur lift and stuff???
FlippinJeeps12 is offline
post #2 of 9 Old 07-07-2005, 04:21 PM
Sierra Drifter
Well I have 2001 XJ with Rubicon Express 5.5" lift, RE HacknTap SYE, RE CV rear driveshaft, and I"m running 35 inch tires. This setup functions great on the trail.
I think RE's springs are a bit stiff so the on-road ride is a bit rough. Also I have to keep tightening the track bar frame mount, it seems to loosen and start making creaking/poping noises, I'm going to get it welded soon. I have never had death wobble or any steering issues. I do run a steering box brace, and will be adding the C-Rock steering box reinforcing plate soon.
I assume from what I've read that the long arm kits are superior for ride and flex, but they are pricey and I passed on them. I ran 33's for a year before regearing and experienced significant power loss, with 35's you will have to regear to 4.56.
Oh yeah, you will also have to trim your fenders and install correct bumpstops to run 35's.
Sierra Drifter is offline
post #3 of 9 Old 07-07-2005, 04:41 PM Thread Starter
FlippinJeeps12
well i guess it would be a better idea to go with 33's first to get some experience...but my mind just keeps tellin me 35's but i appreciate the input...
post #4 of 9 Old 07-07-2005, 05:52 PM
Dannyboy18
Hell, I'd def. regear with 33s. After seeing what my 31s did to power and stuff, I couldn't stand a bigger tire on the stock 3.55 gears.
--Dan
1999 Cherokee Sport - Black; 4.0L AW4, NP231 w/ D30 and 8.25C.
RE 3.5" Super Ride w/ full packs (4* shims) + OME shocks + RE SYE w/ Tom Woods CV
Yukon 4.10s
AR Baja Alloy Wheels - 15x8 + Bridgestone Dueler Revo A/Ts - 31x10.50x15
TeraFlex Adj. Trackbar + TeraFlex Quick Disconnects & WARN T-case skid
Dannyboy18 is offline
post #5 of 9 Old 07-07-2005, 05:56 PM
Blake
Redefining body roll
Blake's Avatar
Try 31's with 3.07 gears...ugh.
1991 Lexus LS400
Daily Beater
2006 Ford F250 Larait
6.0 Powerstroke | 4x4 | Crew Cab
Blake is offline
post #6 of 9 Old 07-07-2005, 09:17 PM
MDP_JeepN
I would start out with a RE4.5 Lift per say, and run some 33's, that would give you a good size lift. Then if you want to go higher and run 35's, you could easily add a couple more inches with spacers.
www.redrock4x4.com has good deals.
MDP_JeepN is offline
post #7 of 9 Old 07-07-2005, 11:46 PM
burby
Here's a place to get a lot of answers for your questions: http://www.jeepforum.com/forum/search.php Seriously, though, there are a TON of posts asking about 35's, etc and you'll find many people that say 1)it get's pretty expensive, and b)would suggest you start out with 31's on about 3" of lift before heading on up to 35's. What do I wheel on, you ask? Why 235's of course
Here's a (not necessarily complete) list of things you'll need to get started:
-Lift kit of your choice, either mix'n'match or complete kit. Kit will likely include new front coil springs and rear leaf packs, some combo of new upper/lower control arms.
-Shocks (some kits are not sold with shocks)
-brake lines
-trackbar upgrades (new bar and/or mount)
-extended sway bar mounts (for front, most ditch the rear after installing new rear leaf spring packs)
-SYE (slip yoke eliminator) or your choice; either a Hack'n'tap or an actual kit, plus a new CV rear drive shaft
-new gearing (and while you're in there, may as well throw in a locker or two! )
-Tires and wheels
HTH...
Even a blind squirrel gets a nut every now and then...
burby is offline
post #8 of 9 Old 07-07-2005, 11:54 PM Thread Starter
FlippinJeeps12
hey thanks guys i appreciate the help alot....i always like hearing suggestions
post #9 of 9 Old 07-08-2005, 12:05 AM
BrunoS
Thumbs up
the forum has it right:
to keep overall street driveability with some aggressiveness, get:
1) 3" lift kit professionally installed. most 4x4 shops are happy to do this.
2) stick with 31" tires and no larger. this is the largest you can go, after that, like the forum says, you need to open the wallet fully and don't say stop.
3) personally, I think that 31" is about max for basic daily driving....my 3.07 gears and 5-speed acceleration is no problem...but my next tires will be 30"
4) 35" tires on street driving....is a bit extreme for an XJ....kinda like lowering a 'vette, or putting 27" rims on a suburban, or 200hp nitrous oxide boost kit in a dodge neon that has 190,000 miles on it with a rough idle.....
5) but if you do it, the 35"s would look killer! just remember to do the whole thing right!
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
Why such a difference in power between my 2001 Sport and 2001 Laredo jlefever XJ Cherokee Technical Forum 11 11-20-2009 09:18 AM
LETS SEE EM BOYS (before/after) cherokeeman90 XJ Cherokee Technical Forum 16 01-22-2008 09:03 PM
well boys and girls....... olds442 XJ Cherokee Technical Forum 22 11-30-2006 03:44 PM
Alright boys, wtf did I do? SlimGoaty XJ Cherokee Technical Forum 15 11-13-2006 06:48 PM
Smokin the BIG BOYS AllXJ96 XJ Cherokee Technical Forum 18 04-23-2006 08:05 PM
