2001 Limited - Questions and help ! - JeepForum.com
post #1 of 6 Old 12-28-2003, 05:49 PM Thread Starter
creekxj
creekxj's Avatar
Looking to swap the rear dana 35 with a ford 8.8.
Is the 8.8 the same length as the dana35? Also how can I disable the ABS system?
Thanks
Scott
The Canuck XJ project
creekxj is offline
post #2 of 6 Old 12-28-2003, 07:59 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
The 8.8 is narraower than the factory XJ 8.25 or D35 rear end. I believe it's 1/4 inch shorter on each side. Use google and search for " jeep cherokee 8.8 axle swap" and some articles should show up. If not I can gather some up for you tomorrow.
As far as ABS, I'm not sure. I 've heard of people just taking the ABS relay out, but again, I'm not sure. Do a search in the cheroke section for ABS* disable and something should show up.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 6 Old 12-28-2003, 08:10 PM Thread Starter
creekxj
creekxj's Avatar
Thanks, I'm going to re think the axle swap options. I wanted to re gear now, but not sure if I want to put any money into the dana35.
creekxj is offline
post #4 of 6 Old 12-28-2003, 08:22 PM
ChrisinVA
Yeah, just hold off doing anything with that D35. Give it some time, do your research. You could certainly put an 8.25 29 spline in there very easily.
94 XJ, 4.0/AW4/8.25/242. 145k miles, bought it in march of '02. Rusty's towhook on front, Hidden Hitch out back with shackle. Rebuilt AW4 in January, '03. Kumho MT's on AR767.
ChrisinVA is offline
post #5 of 6 Old 12-28-2003, 10:49 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
True, the newer (96+) 8.25 Chrysler rear end would be a good choice. No mod necessary as long as you get the rear driveshaft that goes with it.
I have read that the 8.25 rear pinion is longer than the D35C pinion. If your XJ is lifted, it probubly wouldn't matter, but stock the extra length might push the yoke in too much.
Anybody out there with a tape measure want to measure thier drive shaft? I'd like to know if the D35C shaft is longer than the 8.25 shaft.
93 Sport
Specs in Profile.
balloo93 is offline
post #6 of 6 Old 12-29-2003, 10:40 AM Thread Starter
creekxj
creekxj's Avatar
Thanks, How bout disabling the ABS system?
This project is going back on hold, as I'm still having problems with the handling and cluncking noises coming from the passenger side control arms or drop brakets. I have bump steer and wandering the cracks in the road.
Not sure, but my alignment may be a problem as well (still, after 2 different shops).
Thanks
creekxj is offline
My 2001 Blue Limited with Pics D-BOI XJ Cherokee Technical Forum 124 11-01-2012 08:15 PM
I've Got a 2001 Cherokee Limited (STOCK) and.. G3ORG1A XJ Cherokee Technical Forum 10 06-24-2008 10:31 AM
2001 Limited exhaust crosbike3688 XJ Cherokee Technical Forum 4 08-29-2007 02:11 PM
Just picked up 2001 xj limited! JeepTransformer XJ Cherokee Technical Forum 17 02-26-2007 02:15 PM
2001 Cherokee Limited Problems GNelson XJ Cherokee Technical Forum 6 06-29-2001 09:24 PM
