2001 Cherokee Sport spark plugs - JeepForum.com
post #1 of 44 Old 06-28-2005, 03:59 PM Thread Starter
archygyrl
Question 2001 Cherokee Sport spark plugs
Quick question...
I've had my 2001 Jeep Cherokee Sport since last August and have had to replace my spark plugs 3 times due to misfires. Has anyone had a similar problem with theirs? Is there a larger problem that I need to be worrying about that the diagnostic checks are not catching?
Someone please help...
Thanks
archygyrl
archygyrl is offline
post #2 of 44 Old 06-28-2005, 04:09 PM
ChiTown'01XJ
ChiTown'01XJ's Avatar
Try replacing the coil pack. You should be able to find a mopar one for around $50-75 from a dealer or parts store.
Blue Jeep Club Member #73
'01 XJ Sport
235/75/15 BFG All Terrain T/A KO, C4X4 tow hooks, rear hitch, 2 x 55 Bosch Lights, Cobra 19+ (waiting on antenna)
"Let's do it in the dirt"
ChiTown'01XJ is offline
post #3 of 44 Old 06-28-2005, 04:13 PM Thread Starter
archygyrl
Thanks a lot!
I'll try that out next payday.
Have a great day!
post #4 of 44 Old 06-28-2005, 05:09 PM
anony91xj
What plugs are you using? You should only be using Champion Truck Plugs. If you're using anything else, you're going to have misfires.
Also be careful not to dink a plug when putting it in and close the gap, this can cause misfire codes and a stumble at idle.
1998 VW GTI 2.0
anony91xj is offline
post #5 of 44 Old 06-28-2005, 05:15 PM
Jenner
You know I hear that a lot. But when my pepboys didn't have the any cheap plugs in stock I got the $5 a piece non gapable deals and I have to say my Jeep runs better than it did. I guess ever Truck is different.
1998 Jeep Wrangler SE
Project.
Mods so far...none
Maintenance to keep it on the road...Oh my god.
Jenner is offline
post #6 of 44 Old 06-28-2005, 05:17 PM
wipedawg
wipedawg's Avatar
i have autolite single platinum tip and they work better than the champion plugs i used before.
Silver Jeep Club Member # 829.3
6 in lift, 35" Interco Trxus MT's, long armed, Bushwacker cut-out flares, Skyjacker coils(powdercoated grey), RE 4.5 extreme duty leaf packs, Tera 1.5in shackles, AJ's Superrails, AA SYE, TW DS, Blacked out all around. and a buncha RE trackbar stuff, and the infamous ZJ tierod :)
wipedawg is offline
post #7 of 44 Old 06-28-2005, 05:20 PM
ChiTown'01XJ
I've put about 30,000 miles on Bosch II platinums and jus until recently haven't had any problems. I'm probably going to switch over to something else when I change them next.
'01 XJ Sport
post #8 of 44 Old 06-28-2005, 06:43 PM
tangofox007
Really? Tell us, how exactly does a spark plug know whether it's in a truck or not?
tangofox007 is offline
post #9 of 44 Old 06-29-2005, 06:09 AM
anony91xj
"Truck Plug" just the name on the plug.
All I can tell you is from experience. Countless times I've seen cars (Jeeps and others) come in with misfires due simply to the wrong spark plugs. Jeep's 4.0 is one of the more common ones, seems to only like the Champion plugs. If you don't believe me, ask any Jeep/Dodge technician.
There are other examples out there as well. Nissan's 3.3 comes to mind, as it requires NGK Platinum's and will misfire on AutoLites.
1998 VW GTI 2.0
post #10 of 44 Old 06-29-2005, 08:21 AM Thread Starter
archygyrl
Smile
I'll check what kind they used. If it keeps happening I'll just replace them all and the coil pack and see how it goes. I was just worried that there was something going seriously wrong that I just wasn't seeing.
Thanks a lot!
post #11 of 44 Old 06-29-2005, 08:23 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
I'm running the "Truck Plugs" because of reccommendations that I got from people on the forum. I have to say, that the Jeep ran better with the Bosch Platinum spark plugs. The wonderous Champion Truck Plug has been a big let down.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #12 of 44 Old 06-29-2005, 09:02 AM Thread Starter
archygyrl
Did you get misfires with the Champion Truck plugs?
post #13 of 44 Old 06-29-2005, 01:02 PM
mhall02
I've certainly had good luck with the plain Champion plugs recommend on the sticker under the hood. I don't know if they are 'truck' plugs or not but have 108,000 miles, on my third set (changed factory ones at 35,000, then next seat at 90,000 miles) and no missfires or poor idle. Is that ignition coil bar $50 - $75, has anyone bought one yet, if so how many miles did you get out of it?
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
Original Owner 308,000 miles
mhall02 is offline
post #14 of 44 Old 06-29-2005, 02:38 PM
SS01XJ
[QUOTE=archygyrl]Quick question...
You didn't mention when the misfires are occuring. The later year 4.0 engines have had a misfire problem during hot restarts. This kind of misfire is caused by the injectors absorbing the engine heat and causing a vapor lock in the injector, most often in injector no. 3. If this sounds like your symptoms, there is a fix that involves putting a shield around the injector to insulate it from the engine heat.
HTH.............Stan
SS01XJ is offline
post #15 of 44 Old 06-29-2005, 03:16 PM
Matt Gertsch
www.lp.org
No misfires, but it has noticably less get up than it did with the Bosch plugs, which also caused no misfires. I have a lot of MSD equipment, so i could use any plugs and get no misfire. I've just always used Bosch Platinums in all of my vehicles for the extra couple of horses and never had a problem with them.
How To Replace Spark Plugs On 1996 Cherokee Sport? wick001 XJ Cherokee Technical Forum 15 11-12-2013 09:12 PM
Which spark plugs work best for my Cherokee? krazykawl18 XJ/MJ Cherokee Non-Technical Forum 15 03-15-2012 06:46 PM
What spark plugs do you recommend for 2000 Cherokee Sport ayeroff XJ Cherokee Technical Forum 3 07-07-2008 06:36 PM
Spark Plug Change and Error Code on 2001 Sport rmangru XJ Cherokee Technical Forum 4 01-14-2008 09:48 PM
2000 Cherokee Spark Plugs BTK681 XJ Cherokee Technical Forum 5 09-25-2003 12:29 PM
