2001 cherokee sport engine replacement - JeepForum.com
post #1 of 8 Old 11-02-2012, 09:40 PM Thread Starter
faering
Hey everybody,
I'm about to embark on an engine replacement for my beloved 2001 Cherokee Sport (409,000 happy miles). I'm going with the ATK engine (4.0 in-line 6). I do all the work I can on the car (brakes, water pump, radiator, alternator, etc), but have never done an engine swap. I'm not doing this to be overly-ambitious or cocky...I'm a (temporarily?) unemployed teacher and I HAVE to do this myself. My question is, does anyone know of a link or another source for a step by step guide for this, just to be sure I cover all the bases? I just bought the Daimler-Chrysler manual for the car. Any thoughts would be appreciated. Thanks
faering is offline
post #2 of 8 Old 11-05-2012, 01:30 PM
zeaman
Honestly, the answer is no. There is no total complete set of instructions that I know of, I did my 99 two years ago and I had to piece together about 4 different tutorials to get anywhere. I would suggest just taking a lot of pictures as you take it apart for reference. Everything is pretty easy until you have to seperate the engine from the transmission. The flex plat bolts arent bad, the but reverse torx bolts holding the tranny on are so squished under the firewall, you almost have to take your front motor mounts out first. Other than that, its kind of fun. Just get the engine down to the block and be VERY careful when taking all of those little black plugs off on the wiring harness. Good luck!
zeaman is offline
post #3 of 8 Old 11-05-2012, 02:04 PM
loztoree
1997 XJ Cherokee
Swapped the motor in my 97 just a couple months ago. Hubby & I tackled it from start to finish in about 21 hours. No repair manual either. Best advice I have....get a good supply of plastic cups to keep track of all the bolts, nuts, screws, etc & label them with a sharpie as you disassemble the motor. And take pix to refer back to.
Hardest bolts were the 2 reverse torx on the top of the tranny at the firewall. There is almost NO room to get to them.
Good luck!
loztoree is offline
post #4 of 8 Old 11-05-2012, 02:12 PM
AZ Jeff
2014 JK Wrangler
The FSM covers the R&R of an engine in it's entirety. However, you will need either (1) a very good memory, or (2) take pictures as you go, and separate and label fasteners and other parts into small containers.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 8 Old 11-05-2012, 05:08 PM
Millermagic
400k on the original engine? Nice! Why are you swapping it out? Also - are you going to be swapping the trans too?
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #6 of 8 Old 11-05-2012, 07:07 PM Thread Starter
faering
It's using water to the tune of a half-gallon per day, but no visible leaks (blown head gasket?). Turkey gravy under the valve cover last July, although the last 2 oil changes since then (2,000 mile intervals), the used oil has looked fairly normal. Also, recent lifter noise has become quite loud. I guess I figured it doesn't make sense to do half a re-build. The transmission has no issues.
faering is offline
post #7 of 8 Old 11-06-2012, 07:40 AM
Millermagic
The head is cracked ... 2000s like to crack heads (symptoms of a bad head gasket).
post #8 of 8 Old 02-10-2013, 09:26 PM Thread Starter
faering
Finally getting around to this job. Have everything stripped down to the block. How do I get at the two bolts at the top of the tranny? And..what exactly does "reverse torx" mean. Thanks
faering is offline
