2001 Cherokee Sport # 3 misfire - JeepForum.com
post #1 of 16 Old 10-12-2009, 06:14 PM Thread Starter
missjeepgal
My engine light came on yesterday so I took it to Autozone and they checked the computer and it showed # 3 misfire. Also, since this has happened my turn signals are not working correctly. When I turn them on they will work for about 5 seconds and then just "go out". If I turn the signal off and then back on the same thing happens. Could these two problems be connected? Thanks in advance for your assistance!
missjeepgal is offline
post #2 of 16 Old 10-12-2009, 06:20 PM
XJNUTTIER
Well, I would check the obvious first, and that is spark plugs, replace if you have done so in a while, and make sure you double check the gap. for the blinkers my 98 gets a lil squirley if I try to use the 4 way flashers, but mine seems to be a bad connection in the column. I would check you blinker in yours first, that would seem to be the most logical issue. I hope this helps a lil....
XJNUTTIER is offline
post #3 of 16 Old 10-12-2009, 06:24 PM
XJNUTTIER
Hey just did a thread search, adn I knew this was a familiar code, here is the logical issue on your year..
http://www.jeepforum.com/forum/f11/p...isfire-394071/
post #4 of 16 Old 10-12-2009, 06:28 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
There is a little heat sheild that you canget at the dealer to fix the misfire. It isn't connected to the turn signal problem though. The multi-function switch, which works the turn signals may be bad.IDK
xjfever is offline
post #5 of 16 Old 10-12-2009, 06:28 PM Thread Starter
missjeepgal
Thank you so much for your help! I will get those plugs changed. I have had her for 2 years and I have never replaced them.
post #6 of 16 Old 10-12-2009, 06:30 PM
XJNUTTIER
Hey read the other post I linked you to, that I beleive will be your issue, but definatley change them plugs if you are not sure the last time they were changed, and stick with the copper core plugs, DONT buy any fancy plugs, IE: iridium, platnium, 12 electrodes..etc.. Jeeps are plain and dont play well with anything else...LOL
post #7 of 16 Old 10-12-2009, 06:44 PM Thread Starter
missjeepgal
LOL.... CJ, (Cheap Jeep) does not play well with others!!
post #8 of 16 Old 10-12-2009, 06:47 PM
XJNUTTIER
and dont forget Just Empty Every Pocket, or Junk Each & Every Part.... But the CJ is very nice..LOL
post #9 of 16 Old 10-12-2009, 06:57 PM Thread Starter
missjeepgal
Thanks! Two years ago, I totaled my other car (Grand Am) so I was in a hurry to obtain a car and I saw CJ on a local lot. I took her for a test drive and fell in love. The price I paid for her was very low and that is how she got the name CJ....This is my first Jeep, and really can't see myself owning anything else. Besides oil changes the only thing I have had to replace is an AC condensor.
post #10 of 16 Old 10-13-2009, 10:16 AM
XJNUTTIER
Welcome to the family, and glad to hear you were OK... So you have a Cherokee or a CJ? LOL I am confused.. Do you have any pics of it? LOL some of my best Jeeps I have owned i purchased on the lower end, adn got many years of great service out of them.. You really shoudl go over her, and start chanign all the fluids if you have not done so. The transmission, transfer case, both diff's, coolant and flush, and have her greased up in the front end and driveshafts... and if you have not done the plugs, you should probably do wires and cap and rotor.. All the basic maintence stuff... If you need more help just drop a line..
post #11 of 16 Old 10-13-2009, 12:29 PM
Deezelweazel
It's a 2001, they don't have wires...
but do the rest. Welcome
Go hard, go Diesel! - Turbocooled and Intercharged...
Deezelweazel is offline
post #12 of 16 Old 10-13-2009, 03:59 PM
XJNUTTIER
LOL, my bad, those couple of years always throws me off...
post #13 of 16 Old 10-13-2009, 04:05 PM
justanotherjpr
Very common problem. It's a heat soak issue on injector number 3. Some say the heat shield works, it didn't for me. Some say the heat wrap on the injector works, it didn't for me. Some say the hood vents work, they helped a little for me. I ended up wiring a switch to turn on my auxiliary e-fan manually. If I'm in a store for less than 10 minutes, I leave it on (when the ambient temp is above 85 or so). This has done the trick every time.
Failing that, you can try replacing the injector(s) or even try moving them around to isolate the problem. From what I can gather, the insulation in the injectors breaks down over time and the heat soaking into them causes it to misfire until it is able to 'clear'.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #14 of 16 Old 10-13-2009, 04:53 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
There was no mention if there are any "symptoms" such as misfires, stumbling, etc. Are there any? Also, does the check engine light come on and off or does it stay on? The devil is in the details here.
I agree that the#1 thing is to definitely change out those spark plugs. The #3 fuel injector is suspect to heat soak as already mentioned. The other thing that is related to that specific cylinder would be the fuel injector itself.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #15 of 16 Old 10-13-2009, 06:39 PM
XJNUTTIER
Hey I also checked with the service manager here at my dealership. The 4.0 misfire on cylinder #3 often times is also carbon build up on the valves. They have a kit they do at the dealeship to clear it up, but I think you can seafoam the engine thro the intake and get very similar results. You should also give that a shot, That is right along the lines of maintence. Drop me a line if you need a better explanation of the seafoam process..
2001 Cherokee Sport Misfire jakegxj XJ Cherokee Technical Forum 14 03-29-2017 09:30 AM
2000 Cherokee Sport, misfire cylinder 3 hckrach XJ Cherokee Technical Forum 23 03-08-2016 04:05 AM
2001 Cherokee Sport chicagoniner XJ Cherokee Technical Forum 6 12-29-2009 03:14 PM
2001 Cherokee sport......I did it Carhlr XJ Cherokee Technical Forum 3 10-11-2009 09:49 PM
New (to me) 2001 Cherokee sport whatsleft XJ Cherokee Technical Forum 8 01-06-2009 05:46 PM
