2001 Cherokee Cooling Fan Issues - Page 2 - JeepForum.com
post #16 of 19 Old 10-30-2014, 04:35 PM
willysdude
+Cooling fan goes off and on all the time
New to the site here. I have a 99 Jeep Cherokee Sport 4x4 with the 4.0 in line. My cooling fan starts to go on and off from the time I turn the motor on and shut down after use. The temps have never gone over 210. What would be the cause of this? I'm open for suggestions. Thanks
willysdude is offline
post #17 of 19 Old 10-30-2014, 05:13 PM
Holder350
1995 XJ Cherokee
Make sure your AC is not on, (this includes defrost)
If your ac clutch is cycling then your aux fan will too.
And if your ac clutch is cycling, your likely low on refrigerant.
Holder350 is offline
post #18 of 19 Old 03-14-2017, 05:55 PM
rocknchevy372
I have a 2000 xj should the electric fan stay running when you shut the jeep off then shut off when it cools down?
rocknchevy372 is offline
post #19 of 19 Old 03-15-2017, 07:24 AM
CCKen
CCKen's Avatar
No. Not unless the radiator electric fan relay sticks.
There has to be a reason the fan was turned on to begin with. Engine coolant temp too high [?]
CCKen is offline
cherokee , cooling , fan
Cherokee cooling issues pghtech XJ Cherokee Technical Forum 5 03-31-2010 08:41 PM
2001 Jeep Cherokee Sport AC issues... Squid78 XJ Cherokee Technical Forum 6 07-24-2009 08:47 PM
cooling issues 92 cherokee odd... jeeptorino68 XJ Cherokee Technical Forum 7 05-10-2009 10:59 AM
More Cooling Issues... jdearmitt XJ Cherokee Technical Forum 5 02-08-2009 06:26 PM
1998 Cherokee cooling issues- Looking for the best bang for buck radiator 93ZJbeast XJ Cherokee Technical Forum 12 07-28-2008 02:43 AM
