Quantcast 2000 XJ wont Start, No Fuel Pressure - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 2000 XJ wont Start, No Fuel Pressure
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 04-26-2008, 07:33 AM   #1
EC1384
I went out to start the 2000 Cherokee this morning and it would not start. The easiest thing for me to check was fuel at the time. I turned the key to on and didn't hear the fuel pump, I then check the bleeder valve and no fuel. I drove it the night before with no problems at all. I checked the fuses under the passengers dash and all fuses were good. I then checked the relays and noticed the cover to the fuel pump relay was lifted up and slides right off so my guess is the relay but is there anything else I could check? also how do the relays come out it didn't seem like it wanted to just pull out and i didn't want to force it. Thanks i am hoping to get it back up and running soon.
94 XJ - 4.0L - RE 4.5" - 33x12.5 - K&N Filter - Dynomax catback - 185xxxmi
00 XJ - Stock for Now
EC1384 is offline   Reply With Quote
Old 04-26-2008, 09:00 AM   #2
SilverXJ
Just wiggle and pull they come up. You may be able to swap the relay with something else for testing purposes.
SilverXJ is offline   Reply With Quote
Old 04-26-2008, 06:40 PM   #3
EC1384
Ok thanks thats what i was looking at trying to do one cause my local advanced auto parts said they aren't even able to get that relay in for me which is weird, which means that i will have to start calling around or order one. I also noticed that when the key is in the start position usually the gas gauge moves but now nothing happens if anyone has any other ideas. Thanks..
Old 04-27-2008, 07:02 AM   #4
x99j
check for spark! a bad cps will knock out spark and fuel. here is a similiar story cps fixed it!
Link:
http://www.jeepforum.com/forum/showthread.php?t=430512&highlight=crank+position+s ensor
99xj, 4.0, aw4, nv 231 d-30, 8.25. dessert sand pearl. former rent a car from Enterprise. great shape!
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
x99j is offline   Reply With Quote
Glock Forum
