2000 XJ Thermostat Help - JeepForum.com
post #1 of 10 Old 05-25-2010, 11:02 PM Thread Starter
WVFishandHunt
Hey everyone i just got done swapping the engine in my xj and now my dad went out and bought a 165 thermostat to install instead of the stock thermostat. Any thoughts on this? Will this negatively effect anything? Any and all help is appreciated
WVFishandHunt is offline
post #2 of 10 Old 05-25-2010, 11:08 PM
troys96xj
It'll be fine. I would run a 180 or 190 though.
troys96xj is offline
post #3 of 10 Old 05-26-2010, 10:32 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
For a daily driver, use the 195 degree stat. Don't install the 165.
Your engine is designed to run most efficinetly with the 195. Don't second guess the design engineers on this one.....
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #4 of 10 Old 05-26-2010, 04:04 PM
djb383
Everybody second guesses the design engineers............it's called "mods". LOL
djb383 is offline
post #5 of 10 Old 05-26-2010, 04:06 PM
kbad
no way 165....listen to TJ or go at least 180+, dude! ....and upgrade your water pump while you are at it - much better for your engine than the stock crap - better turbine, larger volume, higher performance rating to match up to the 195 thermo and upgrade your rad hoses too.
also....consider running synthetic oil and use a high performance/higher capacity oil filter (e.g. fram fr-hp1 or mopar performance) - more oil to keep your engine cooler
and...hope you are not using the stock, bulky motor fan and the useless electric fan?!?....get rid of both and instead use dual 16" electric fans - a lot less load on your engine and it will run more efficiently, plus you can automatically/manually run them individually/together...
hey TJ, what's up? ...my 96 stock was 165??? and i replaced it with 190....does stock 2000 come with 195? wow!
...and where are you at up there in MN?...i used to go to BSU up in berrrrmidji back in 82-84, my uncle used to own the Chief Motel in town.
kbad is offline
post #6 of 10 Old 05-26-2010, 04:17 PM
z06rider
excatly, if the engine never warms up the computer stays in "warm up" mode, then you end up with worse gas mileage and emissions output.
in OBD1 and 2 cars they are programmed/desigend to run within the original thermostat temp range installed...
it could always be re-programmed though, but i wouldnt waste you money.
01 XJ- RE 3.5, SYE, Twoods DS
04 Z06-some goodies
07-G35x
92-Accord
z06rider is offline
post #7 of 10 Old 05-26-2010, 06:44 PM
djb383
The computer leaves "warm up" mode and enters "closed loop" or "clean/lean" mode when the O2 sensor(s) reach operating temp. This is less than a minute after engine start-up and well before coolant temp reaches normal.
Click to enlarge
Uploaded with ImageShack.us
djb383 is offline
post #8 of 10 Old 05-26-2010, 10:26 PM Thread Starter
WVFishandHunt
thanks everyone...he told me that he bought the 165 and i knew from reading enough threads that it wasnt a great idea. i just wanted to double check. kbad he did buy a better water pump and radiator and we have always ran synthetic and high quality oil filters. I am also planning on swapping the fans. i just need to get it back first. it is in erie pa and i am in morgantown wv cuz i dont have the space to do an engine swap. once again thanks everyone for confirming what i though
post #9 of 10 Old 05-26-2010, 10:53 PM
kbad
....clarification on the oil filter....the high performance ones have a larger capacity than stock...about a 3/4 to 1 qt more or so.....more oil to protect your engine.
kbad is offline
post #10 of 10 Old 05-27-2010, 10:01 AM
tjwalker
tjwalker's Avatar
Originally Posted by kbad View Post
hey TJ, what's up? ...my 96 stock was 165??? and i replaced it with ....does stock 2000 come with 195? wow!
I wasn't aware that any of the 4.0 engines came with the 165 degree stat from the factory.....My understanding is that they were all 195. It is the only temp stat I've ever installed on the 4.0.
kbad...I live near Melrose MN on Big Birch Lake. I used to date a girl from BSU back in my college days. Yup, it is still referred to as brrrrrrmidji! It can be ridiculously cold here some winter days (-30 f not unusual) but is pretty nice spring through fall.
bad thermostat? medicbear XJ Cherokee Technical Forum 8 03-03-2008 11:48 PM
Thermostat and MPG crumb XJ Cherokee Technical Forum 25 01-17-2008 05:15 PM
Best Thermostat to get? TMXONR XJ Cherokee Technical Forum 62 10-06-2007 02:56 PM
thermostat rick32 XJ Cherokee Technical Forum 4 01-30-2007 10:08 AM
180 deg thermostat savage1978 XJ Cherokee Technical Forum 18 09-22-2005 06:55 PM
