2000 XJ steering will not return to center - JeepForum.com
post #1 of 9 Old 10-10-2009, 09:29 PM Thread Starter
MichiganXJ
Vehicle: 2000 Cherokee, 100% stock.
Symptoms: When I turn a corner, the steering does not return to center on its own, and I have to turn the wheel back the other direction to go straight again.
The Jeep has just under 150,000 miles on it. Tires are new, and are balanced. I also put new outer TRE's on it at the same time I did the tires. The symptoms were there before the tires and TREs, but to a slightly greater extent.
Other info: My front passenger side axle joint looks awfully rusty, and I plan to replace it next weekend. Sometimes there is also an audible "pop" when I turn the wheel to full lock at low (i.e. parking lot) speeds. I figure this is the track bar bushing, and I also plan to fix that soon.
So, what is the likely cause of the steering issue? I know that caster is usually the cause of these issues, but the balljoints seem OK (no wobbling etc). Could the u-joint be causing this? I really don't want to tear the Jeep apart for balljoints if its not really necessary.
Thanks in advance!
MichiganXJ is offline
post #2 of 9 Old 10-10-2009, 09:39 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Balljoints will control camber.
Control arms will control caster.
Take it for an alignment if you cant do it yourself.
Only thing I have heard of, or had experience with, is caster for not returning to center. I assume there are parts that would wear and give the symptoms you have, but I have never ran into them personally.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 9 Old 10-10-2009, 09:43 PM Thread Starter
MichiganXJ
I forgot to mention that I got it aligned when I did the TREs. The shop didn't mention any difficulties in getting it aligned to specs, but that doesn't necessarily mean anything.
Are the control arm bushings difficult to replace? Anything I should know before starting? I figure given the mileage, they probably are about done anyways.
post #4 of 9 Old 10-10-2009, 10:24 PM
leftlanetruckin
XJ on 37's
A bushing is a bushing IMHO.
Any suspension bushing can either be a complete PIA, or go like clock work.
If you had an alignment done, what were the measurements they gave you?
Specifically the caster?
Martin
post #5 of 9 Old 10-10-2009, 10:44 PM Thread Starter
MichiganXJ
Opps-give me one sec.
post #6 of 9 Old 10-10-2009, 10:46 PM Thread Starter
MichiganXJ
Left Front
Actual Before Range
7.5 7.5 5.3-8.5
Right Front
Actual Before Range
7.2 7.2 5.3-8.5
post #7 of 9 Old 10-10-2009, 11:02 PM
leftlanetruckin
XJ on 37's
Measure your toe in for me please?
I run @1/8" toe in myself with success. What are the degree numbers they gave you for toe in?
I may need you to measure it for me too. A level on each wheel and a tape measure is all it takes.
Martin
post #8 of 9 Old 10-10-2009, 11:07 PM Thread Starter
MichiganXJ
Toe is 0.10 degrees left, and 0.11 degrees on the right.
I would have to get back to you on the actual measurement in inches-I just did the "count the threads to get it close enough to drive to the alignment shop method" when I did the tie rods.
post #9 of 9 Old 10-11-2009, 09:11 AM
leftlanetruckin
XJ on 37's
See what it is measuring at for me?
You could try turning the tie rod, say one complete turn, and go test drive it. Doing it one complete turn will allow you to return it to where it is right now with ease and accuracy.
Martin
Stiff steering and no return to center blk01xj XJ Cherokee Technical Forum 6 10-16-2011 11:16 PM
Steering wheel feel tight and won't return to center crowncaprice XJ Cherokee Technical Forum 15 06-01-2011 08:07 AM
Lifted 4.5", aligned, steering won't return to center bourgeoe XJ Cherokee Technical Forum 14 08-15-2007 06:34 AM
Return-to-Center Steering Damper LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 4 03-02-2006 10:56 AM
Stearing won't return to center husker25 XJ Cherokee Technical Forum 3 09-08-2004 05:41 PM
