2000 xj, re-wiring front door speakers - JeepForum.com
post #1 of 12 Old 10-30-2010, 01:55 PM Thread Starter
matty8199
driver side door speaker does not work, read on here all about how the wire gets broken inside the boot between the door and the body...so i'm trying to rewire it. problem is, the wires in the door (where it connects to the speaker) are black and green, but i can't find any black/green combination inside the vehicle. what wires should i be splicing into?
i haven't started the passenger door yet, but i'm assuming it's probably the same...please help! i've seen so many people here say to just rewire it, but i can't for the life of me find anything that says what color i should be splicing into, or where...i really don't want to have to run new wires all the way to the head unit...
matty8199 is offline
post #2 of 12 Old 10-30-2010, 02:15 PM
GregB_00XJ
Are you still using the stock head unit, or an aftermarket one? You should not splice into anything if you are running new wiring. You should run new wires on both sides from the speakers right to the head unit. Get some good quality speaker wire, and it should stand up better than the factory stuff.
In this case the extra work is worth it...and really, it is like 15-20 minutes more work.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #3 of 12 Old 10-30-2010, 02:21 PM Thread Starter
matty8199
it's an aftermarket HU, but i don't have enough speaker wire at the moment to run new wires to the HU even if i wanted to...i only ordered enough from crutchfield to re-wire just the section that goes through the boot, because that's what all the posts i had found in the search told me to do.
the problem is that i can't for the life of me figure out which are the correct wires...
post #4 of 12 Old 10-30-2010, 03:03 PM Thread Starter
matty8199
not to mention i can't figure out how to get the wire through the grommet...there's not even enough room to get my wire worm through.
every post i've seen says what an easy job this is, but i just can't see it...i'm getting so frustrated i want to break something.
post #5 of 12 Old 10-30-2010, 04:00 PM Thread Starter
matty8199
can someone tell me how to get the wire through the boot/grommet before i end up smashing all or some part of the jeep? i'm so frustrated right now...
post #6 of 12 Old 10-30-2010, 04:41 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Click here -> 1984-2001 Cherokee Stereo and Alarm wire colors
CJ7-Tim is offline
post #7 of 12 Old 10-30-2010, 04:51 PM Thread Starter
matty8199
Originally Posted by CJ7-Tim View Post
yeah, found that earlier thanks...but i'm still stumped on how people are getting the wire through the grommet that goes from the inside of the vehicle into the rubber boot between the door and body. i can't get my wire worm through there, it's packed too tight...
post #8 of 12 Old 10-30-2010, 04:59 PM
CJ7-Tim
CJ7-Tim's Avatar
The boot will come out of the door and the body if you tug on it. Run your wires and then work the boot back into the holes. You might have to push on the boot with something that is sort of pointy, but not sharp.
CJ7-Tim is offline
post #9 of 12 Old 10-30-2010, 05:02 PM Thread Starter
matty8199
no, the boot between the door and body isn't the one i'm having the issue with...that one i can get out and back in (and get the wire worm through). the one i'm having an issue with is the little boot that goes from the inside of the vehicle to the outside, the one right behind the kick panel...the wires are packed in there so tightly that i can't get anything else through there.
post #10 of 12 Old 10-30-2010, 05:04 PM
shaman1204
-remove inside door panel, remove speaker from door frame.
-cut the long bottom piece from a wire hanger
-fish the hanger from inside the door through the grommet down into the kick panel area
-Tape the speaker wire to the hanger TIGHTLY down near the kick panel. Tape as much speaker wire to the hanger as possible so it doesn't pull off easily.
-Carefully pull the hanger that is sticking out of the inside of the door panel so the speaker wire comes with it.
This is what I did and it took about 20 minutes per door.
shaman1204 is offline
post #11 of 12 Old 10-30-2010, 05:07 PM
shaman1204
Disregard my last post then. I don't remember what I did there, but i don't recall having an issue with this area. If the grommet is big enough take an exacto knife/utility knife and make a small X and push your wire worm through.
post #12 of 12 Old 10-31-2010, 08:50 PM Thread Starter
matty8199
that's what i ended up doing...i cut a small slit in the grommet above where the rest of the door wires go through...then i cut the speaker wires and spliced a new wire, and ran it through the newly cut slit in the grommet.
eventually i'll run new wires back to the head unit, but for now this was/is a quick fix for the winter.
2000 Jeep Cherokee Sport Front Speakers JonV XJ Cherokee Technical Forum 10 09-01-2012 09:14 PM
Replacing Wiring to Front Speakers Jeff9 XJ/MJ Cherokee Non-Technical Forum 3 07-12-2010 10:46 AM
Wiring front speakers DreamsOfMoab XJ Cherokee Technical Forum 1 01-06-2008 03:16 PM
2000 front door wiring XJmudder12 XJ Cherokee Technical Forum 1 07-24-2006 06:31 PM
Wiring Speakers in Front doors? dameono4 XJ Cherokee Technical Forum 8 05-09-2005 12:10 AM
