2000 XJ "no bus" and no gauges????? - JeepForum.com
post #1 of 4 Old 12-12-2008, 01:17 PM Thread Starter
UNLIMITLESS
The other night I stopped to get Pizza with the kids. Trucks running same as ever on the way there. I go to leave and the truck starts fine but none of the gauges are working. They are all lit but none of the needles moved. I jiggled the key thinking it was something in the switch. And instead of the miles showing it said "no bus", I was afraid to shut it off with my kids in the Jeep. When I got it home I shut it off and restarted it and it was fine.
I figured it was nothing, but then this morning on my way to work the "check Gauges" light came on and my Voltmeter wasnt working at all. I was afraid to shut it off with the freezing rain and it being 2 in the morning. I got to work shut it off and restarted it and it was fine again.
Anyone know what the no bus is all about?
Any other ideas?
2005 WRANGLER LJ
BLACK JACK
UNLIMITLESS is offline
post #2 of 4 Old 12-12-2008, 01:34 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You may need to remove the guage cluster, then remove the electrical connection, carefully clean the connector pins, add some dielectric grease, then reassemble. then check the ground strap behind the drivers side kick panel, make sure it's clean and secure. This procedure will fix your symptoms most of the time.
xjfever is offline
post #3 of 4 Old 12-12-2008, 01:57 PM Thread Starter
UNLIMITLESS
Behind the drivers kickpanel?Is it a braided style strap or something else? I waqsa thinking I would pull the custer over the weekend and see if that fixes it.
2005 WRANGLER LJ
BLACK JACK
post #4 of 4 Old 12-12-2008, 03:33 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Pull the cluster.
See this thread, the Cherokee is very similar - http://www.jeepforum.com/forum/f9/fix-your-tj-s-dead-gauges-write-up-179282/
CJ7-Tim is offline
HELP, my odometer says "no BuS" and gauges all stopped working....................... andromeda XJ Cherokee Technical Forum 9 06-19-2010 01:36 AM
"Invisible" water leak in 2000 Cherokee 6 cyl Redux032 XJ Cherokee Technical Forum 11 01-31-2010 09:47 PM
I need help: My "Check gauges" light went on Bluebell XJ Cherokee Technical Forum 10 01-05-2008 11:06 AM
what gauges do you have in your "gauge cluster" dcdude XJ Cherokee Technical Forum 1 05-07-2004 10:30 PM
Bought 2000 Cherokee and it "Clucks" when put in gear 88xj XJ Cherokee Technical Forum 32 10-18-2002 07:39 PM
