2000 v6 gauges going crazy - JeepForum.com
post #1 of 5 Old 08-10-2009, 01:34 AM Thread Starter
ss44camaro
friend of mine just traded for a 2000 cherokee v6. the temp gauge sometimes goes up like its over heating but its not and comes back down. also the oil pressure gauge will go down to 0 then come back up to normal. im hoping that the pressure gauge is wrong and the oil pump is working right. is this a common issue with these cars? any ideas to diagnose whats going on? if you guys can give me some tips it would help me be ready for when he brings it over and hopefully we can fix it.
ss44camaro is offline
post #2 of 5 Old 08-10-2009, 07:22 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The oil pressure sending gauge or the wires leading to it are known to have problems and the oil gauge will go to the end of the scale. This is not a real problem but is a pretty simple fix.
If the temp gauge is quickly rising and falling, you need to service the cooling
system.
The cooling system is just that, a system, which depends on proper function from each of its component parts to keep the engine cool. Service the cooling system and replace any under performing or suspected weak parts. Any component part of the cooling system that is not fully doing its job will stress the others and your cooling system will overheat.
-Use a flushing/cleaning solution and then drain and fill the radiator with a fresh 50/50 coolant and water mix.
-Replace the thermostat with a STANT brand 195*.
-Replace the radiator cap. An old worn out cap will allow boil overs as the coolant flashes to steam. You will see the coolant temps suddenly jump from 210* to the Red Zone if your radiator cap is weak.
-Inspect or replace the mechanical fan clutch. A worn clutch will allow temperature creep at stoplights and in heavy traffic. Looking OK and working OK is not the same thing.
-Inspect the electric cooling fan. Apply 12 volts and make sure it runs. Confirm that the e-fan starts when engine temps reach 215-218*. Repair or replace as needed.
-Inspect or replace the coolant temperature sensor that activates the e-fan.
-Replace the water pump. The pumping fins can deteriorate over time and the pump will not flow enough coolant to keep the temps under control.
-Inspect the radiator for mud/bugs/grass clogging the outside and mineral deposits clogging the inside.
-Inspect/replace the radiator hoses. Make sure the coiled wire is installed in the lower hose.
Read more about cooling systems here - http://www.offroaders.com/tech/engine-overheating.htm
CJ7-Tim is offline
post #3 of 5 Old 08-10-2009, 07:24 AM
theducksguts
For the Oil Pressure check the Oil Pressure Sending Unit on your friend's I6 then educate them to never say Cherokee V6 ever again. Unless they bought it from 84-86.
People get worked up about that around here.
Check out my
theducksguts is offline
post #4 of 5 Old 08-10-2009, 08:34 AM
jeepkid03
Winning
jeepkid03's Avatar
go to your local autoparts store and rent a mechanical oil pressure gauge and verify the pressure. Make sure that the sending unit is at fault and that your oil pressure really isnt going down to zero. Your 2000 model has the weaker #0331 cylinder head and if its overheating with very low oil pressure you could have coolant in the oil and a cracked head. Not saying its your problem but I would just check the obvious (milky oil and low coolant, verify oil pressure with mechanical gauge) before sinking money into sensors.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #5 of 5 Old 08-10-2009, 09:25 AM Thread Starter
ss44camaro
wow that would suck. ill do just that and get back to yall.
(1997) How would I convert idiot light gauges to needle gauges? xjse XJ Cherokee Technical Forum 18 02-11-2013 09:21 AM
gauges, SE to full gauges (tach, oil,temp, etc Xjay96 XJ Cherokee Technical Forum 2 02-08-2010 12:00 PM
2000 XJ "no bus" and no gauges????? UNLIMITLESS XJ Cherokee Technical Forum 3 12-12-2008 03:33 PM
Will a 2000 grand cherokee cd player work in a 2000 cherokee sport? soonernort XJ Cherokee Technical Forum 1 03-01-2007 11:00 AM
crazy gauges. inkslinger XJ Cherokee Technical Forum 2 06-21-2005 03:07 PM
