#1 | |
2000 TJ D44...under XJ
hey i just found a smokin deal on a dana 44 out of a 2000 TJ and i was wondering if anyone had info on this axle....width.....leafs or coils and so on cause for 350 im findin it hard to pass up if it'll fit under my 89 XJ
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit My Jeep's Page |
#2 |
theres no reason as to why it wouldnt fit, the only things you have to consider is the gear ratio, and you will have to cut off the tj bracketry and weld on leaf perches.
98 XJ classic - 3" rustys springs, 2" tnt shackle and spacer, RK 3 link longarms, 33 x 12.5 BFG MT's, buncha other stuff. Totaled, will be missed 99 TJ Sahara - 3" FT economy lift, JKS disco's, 33 x 12.50 BFG MT's on silver D-windows, 1" BL/MML, smittybilt tire carrier |
#3 |
The yoke will use the 1310 u-joints, but as mentioned above, the TJ has coil suspension, so you will need to take the buckets and control arm mounts off and have spring perches for the leaf springs welded on. Width should be the same as well as bolt pattern.
Shawn '00 TJ Sahara (RC 4" LA kit) '06 Grand Cherokee Limited '07 Ram 1500 quad cab Heritage Region Jeep Alliance |
#4 |
1310 u-joints?.....could you give me a little more info on those..good..bad and as for gear ratio im movin up to 4.56s soon anyway im just lookin for a better axle than the 35 cause i really dont wanna dump money into that pile
#5 |
well so much for that the guy just emailed me and said its sold a day ago....
....knew it was to good of a deal
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
