2000 sport heater problem - JeepForum.com
post #1 of 9 Old 02-01-2007, 01:39 PM Thread Starter
b15618
My 2000 cherokee sport seems to not want to provide hot heat. I have replaced all hoses, thermostat, and coolant. Heater core has been blown out with air; and I'm still getting just warm, almost hot air.
Any suggestions as to the cause of this problem??
b15618 is offline
post #2 of 9 Old 02-01-2007, 02:08 PM
kg4kzv
1995 XJ Cherokee
Have you tried to burp the cooling system? There is a sticky under tech on how to do it if not.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #3 of 9 Old 02-01-2007, 03:41 PM
JEEPZZ
JEEPZZ's Avatar
No need to 'burp' to cooling system, his 2000 has a radiator cap. The system self purges the air out the very first time the t-stat opens up.
I would suggest back flushing the heater core with water (not air) until all of the crud comes out. Once the water comes out clear, alternate flushing it forward and then backwards until you have a clean, high volume flow coming out of the core. It's a piece of cake to do with a garden hose and should only take you about 10-15 minutes.
[FONT=Trebuchet MS][size=1]97XJ RENEGADE
JEEPZZ is offline
post #4 of 9 Old 02-01-2009, 03:15 PM
sofixj
sofixj's Avatar
when flushing the heater core where do you hook up your water supply line i jhave a 97 sport and i have the same issue ill be replacing the hoses and clamps and t stat this week i wanna FLUSH THE HEATER CORE BUT NOT SURE HOW TO
,=====o00o
//___l__,\____\,___
l_--- \___l---[]lllllll[] _
_(o)_)___(o)_)--o-)_) only in a JEEP
sofixj is offline
post #5 of 9 Old 02-01-2009, 03:21 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would also suggest looking into the blend door to see if it is closing off properly. your problem may not be related to the coolant flow.
xjfever is offline
post #6 of 9 Old 02-01-2009, 03:39 PM
sofixj
sofixj's Avatar
ok what are the hints for the blend door where should i hear it .. and my 97 sport has 125000 miles on it i just bought her so not sure of past maintance
,=====o00o
//___l__,\____\,___
sofixj is offline
post #7 of 9 Old 02-06-2009, 12:37 AM
sofixj
sofixj's Avatar
holy heat batman!!!!!!!!!!!!!! well i flushed the heater core and the entire cooling system out to night and wow was it brown and kinda chunky refilled it with fresh 50-50 mix and so far its blowing nice hot air.... still waiting to get all the bubbles out... i also replaced the thermostat and rad cap....
,=====o00o
//___l__,\____\,___
sofixj is offline
post #8 of 9 Old 02-06-2009, 06:14 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Glad you got it fixed. I know it's cold up there.
xjfever is offline
post #9 of 9 Old 02-06-2009, 07:53 AM
duke000088
Neat. Any tips on procedure? I'd like to do this too... my heat seems to be degrading (but the blend doors are working OK).
I've read you should pull the heater hoses off the water pump rather than from the core itself (at the firewall). Does a lot of coolant spill out? What's the best way to link up a garden hose to a heater hose? I was going to look around for a brass barb end that would stuff into the heater hose and thread onto the garden hose...
duke000088 is offline
2000 Xj Sport Electrical Problem Same As Petmac DylanYazel XJ Cherokee Technical Forum 2 09-01-2009 10:39 AM
Major Electrical problem with 2000 Jeep Sport coloradojeepgrl XJ Cherokee Technical Forum 1 03-13-2009 04:51 PM
Steering problem in 2000 Jeep Cherokee Sport sm40oztofreedom XJ Cherokee Technical Forum 5 08-22-2007 07:07 PM
Will a 2000 grand cherokee cd player work in a 2000 cherokee sport? soonernort XJ Cherokee Technical Forum 1 03-01-2007 11:00 AM
98' cherokee sport heater and electric window problem..need suggestions guzoo XJ Cherokee Technical Forum 2 09-13-2006 06:41 PM
