2000 rpm idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 2000 rpm idle
JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFAlloy usa heavy duty ball joint kitsROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 04-14-2014, 07:27 PM   #1
scupking
2000 rpm idle
Just replaced my tb tonight with a 62mm. Also put a new tps and iac on it (NAPA Echlin). Started the jeep and idles at 2000 rpm. What could be the issue?
scupking is offline   Reply With Quote Quick reply to this message
Unread 04-15-2014, 01:45 PM   #2
scupking
Just took her out for a test drive. Started and idled just fine. Guess I should have let it run a little while last night to let the computer catch on to the new clean sensors.
