2000 limited electrical issue - JeepForum.com
post #1 of 9 Old 05-17-2011, 09:03 PM Thread Starter
robswampthing
I dont want to make this to broad. but my wife was driving my xj yesterday. no issue's. no funny noises. parked it. went inside the shoppette, came out one click. no start. no voltage. headlights wont turn on, no power at all. Tried getting a jump from a 4runner. nothing. starter didn't even try. but no aux power in any key position. im going to try a borrowed full charged battery. and check the terminal's in the morning. was just hoping for some more input and hot ticket area's to check. thanks in advance gentleman.
robswampthing is offline
post #2 of 9 Old 05-17-2011, 09:08 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Clicking and not starting is a lack of voltage. Either a bad battery or more likely, bad connections. Naturally you should check all the fuses in both fuse boxes.
Begin with basic trouble shooting of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Do the same for the grounding wires from the starter to engine block, and from the battery and engine to the Jeep's frame/body. You must remove, scrape, and clean until shiny, the cable/wire ends, and whatever they bolt to. Jeeps do not tolerate low voltage, bad connections, or poor grounds.
CJ7-Tim is offline
post #3 of 9 Old 05-18-2011, 12:18 AM
filluptrk
Put a voltmeter on the battery and see what it shows. Even if it shows 12V pull the light switch and see if it goes to 0. Had this happen to my Triumph battery, and last week the jeep made a pop and everything went off. In both cases the initial reading was 12V. But you could could put the tiniest load on the battery and it went to nothing.
filluptrk is offline
post #4 of 9 Old 05-18-2011, 12:46 AM
Reptile
1991 XJ Cherokee
You need at least a good 12.6 - 12.7 V to be able to start it, nothing less. It's very odd that you did not get warning signs and have no power at all. This is too weird. Could be one of the main fuse, or the ignition switch or something. If the battery reads good then the problem's elsewhere.
Reptile is offline
post #5 of 9 Old 05-18-2011, 05:06 AM Thread Starter
robswampthing
thanks for reply's all. I am going to go to the gas station and check it out after work. at least it's on base so it's fairly safe. ill definitely let everyone know what i deduct from my troubleshooting today
post #6 of 9 Old 05-18-2011, 06:12 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
A main fuse or a possible "ground" issue come to mind, along with a catastrophic battery failure (have it load tested) And of course, battery connections MUST be shiny clean!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #7 of 9 Old 05-18-2011, 01:40 PM Thread Starter
robswampthing
so i ended up removing the positive cable from the battery. reseating the cable's in the coupling and voila. fired up. it was finger tight. no idea how that happened. going to go to auto zone to get the alt and battery tested though to see if maybe i just got lucky with the start
post #8 of 9 Old 05-18-2011, 03:23 PM
Kettles
Its amazing how little it takes for nothing to work with the battery connections. Clean and tight is important!!
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #9 of 9 Old 05-18-2011, 03:51 PM Thread Starter
robswampthing
amen brother
alternator , battery , starter , wont start , xj
My 2000 XJ Limited Build!! OneW1ckedXJ XJ/MJ Cherokee Non-Technical Forum 132 02-05-2014 06:46 PM
2000 Grand Cherokee Electrical Issue bp1104 XJ Cherokee Technical Forum 2 01-22-2010 10:28 AM
2000 XJ Limited? FXSTCHEWY XJ Cherokee Technical Forum 8 08-29-2009 04:58 PM
99 Limited Electrical RP_Offroad XJ Cherokee Technical Forum 3 08-05-2006 11:01 PM
98 Cherokee Limited electrical issues ultrajosh XJ Cherokee Technical Forum 10 10-13-2005 06:58 PM
